Linksys Wireless-G WRT54G Router Logo
Posted on Jun 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Network printer i can't print anymore. changed internet provider and since then i can't print to the network printer
Anonymous
Level 3:
Brigadier General:
  • Master 6,966 Answers
  • Posted on Jun 13, 2008
Anonymous
Master
Level 3:
Brigadier General:
Answers
6966
Questions
17
Helped
3090184
Points
19604
The only possibility that I can think of is that the printer is not being assigned an IP add by your router. This could probably be cause by the DHCP not working right possibly due to another DHCP that from your new modem. Shouold this be the case, may I suggest that the DHCP function/feature of the modem be disabled and assigned an appropriate static IP add to the WAN of your router.
Alternately, you can assign a static IP add to your printer say 192.168.1.200 following the other IP configuration of your PC/network. Of course, you would have to reconfigure the shared TCP/IP add of the printer to be known/recognized by your PCs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Anonymous Jun 15, 2008
    Appreciate the rating.
My lexmark printer will not print recently moved using new provider for internet computer is mac os x
If your printer was connected wireless to your system prior to changing internet provider, you may need to reset your printer's wireless network adapter first and then reconfigure it to reconnect to your new wireless network.
If you need the Lexmark printer driver for your Mac, please visit www.lexmark.com.
I have changed my Internet provider and it has a different IP address than before and my bizhub 250 cannot print now
Press Utility/Counter
Press Administrator
Input code 12345678 or 00000000
Select admin 2
Select Network
Here you can change the network settings to match you new Network scheme. You will have to reinstall the print drivers after you correct the network settings. If you have the driver disk it will auto run and find the machine, if you don't have the disk you can download the drivers at kmbs.konicaminolta.com where you can also download the user manuals in PDF format that will go into more detail on changing the network settings.
2answers
I changed internet providers and now my wirless printer doesn't work
STEP1: Print "Network Configuration Page"
  • Make sure paper is loaded.
  • Push the Setup Button on the all-In-one.
  • Use the Down Arrow key to highlight the Network menu.Push Ok
  • Push Ok again to select View Network Settings .
  • Push Ok again to select Print Network Configuration page .
  • A network configuration page will print.
STEP 2: Check the Printer Connectivity
  • From the printed Network configuration page, note down the printer IP address, (example : 192.168.1.6).
  • Click start, and then click "RUN".
  • In the RUN box, type "CMD" press OK.
  • In the command screen, type "Ping IP address" (Example: Ping 192.168.1.6). Hit Enter.
  • You must get output similar to below.
Pinging 192.168.1.6 with 32 bytes of data:
Reply from 192.168.1.6: bytes=32 time=1ms TTL=64
Reply from 192.168.1.6: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.1.6:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
STEP 3: Configure Port.
  • Click on start >> Control Panel >> Printers and Faxes.
  • Right click on printer icon, select "Properties".
  • Click the PORTS tab on the top.
  • Select your product under the Printer column, and then click Configure Port . The Configure Standard TCP/IP Port Monitor dialog box opens.
  • Look in the Printer Name or IP Address box. This value should match either the MAC or IP Address on your network configuration page. If the values match delete the printer and install it again.
  • If the values does not match,Click inside the Printer Name or IP Address box, and then type the appropriate value (IP address / MAC address) as listed in network config page.
  • Click OK , and then try printing again.
Regards
Riztech
1helpful
2answers
I have a sony vaio VGN-FZ430E for a year now. It is set up on a new printer, a lexmark X4690 wireless. Right now we don't have wireless internet so we have to computer hooked up to a non-wireless network....
If you're on a wired network now and the Printer used to be on a wireless network, your computer may not know where to print to anymore. You might want to try uninstalling the printer in full and then reinstalling it making sure to do it directly connected to the computer you want to print from.
2answers
I just changed from DSL to FIOS, and now my fax/printer/scanner (all-in-one) will not print. I have an ethernet cable connected from the printer to the FIOS router, and who knows where to plug in the phone...
First, the phone connection to the fax simply needs to come from a regular phone jack. You will need to have a regular telephone number in order for it to work. As I understand it, FIOS is a fiber network, which means everything is comming to you via the internet. Faxing does not work over internet telephony
On to your printer.
If you had connected the printer through ethernet before, the IP your computer thinks the printer is on is most likely no longer valid. You will need to either reinstall your printer (easiest solution - recommended), or re-connect to it manually (requires much greater skill and knowledge).
I cannot assist you with re-connecting it manually, so your best bet is to simply re-install the printer.
Good Luck!
HP printer will not print over wireless network using Belkin hub
Try turning everything off, wait a couple of seconds and then turn it back on.  Also try disabling McAffee to test.  When you go to printers and faxes on the PC, what is the status of your printer?
1helpful
Toshiba E-Studio 160 network print?
Go to Control Panel -> Printers. Select Add Printer... When it prompts for a local printer or a network printer, select network. Follow the prompts from there.
2answers
Connecting Brother MFC 7420 thru Dlink DP301P Print Server to home network with ONLY dynamic addressing
I went and got static IP addresses from internet provider...Must of caught them on a good day
1helpful
3answers
Printer busy/or error
Sounds like your machine is using DHCP, not a static IP address?
Print your network settings from the Printer, then try to Ping from a computer on the network.
Check the Network setting of the machine, make sure it is set to a fixed (static) IP Address.
If this is the problem, you can go into your PC printers port and change the port to the reassigned IP Address of the machine.
If you reinstall the drivers then you will have this installed twice, one will work one will not, so delete it from the printers folder before you reinstall before you reinstall
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
