Question about GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer
GE Unitized Spacemaker
How the heck do I get to the Heater coil?  I took the bak off but can not find it.  What does it look like?
  • 725 Answers
WSM2480D0WW is a gas dryer there is no heater coil... but it has a burner and igniter...if you have a electric dryer it is at the end of the blower
Posted on Dec 25, 2008
GE spacemaker Washer Dryer Combo don't drain properly?
Check the drain hose for obstructions. Is it being pinched where it goes over the top of the drain pipe behind the washer?
The pump may be going bad...
Jul 29, 2014 | GE WSM2700W Unitized Spacemaker Washer and...
The dryer timer stopped working
Is that a temperature senor in the GE spacemaker Laundry dryer? My dryer stops spinning when it gets too hot. After it cools down, it will spin and dry again.
Jan 05, 2013 | GE WSM2700W Unitized Spacemaker Washer and...
Dryer has cold air
You might need to replace the heater coil or coils....I had to do that on a previous dryer.
Sep 21, 2012 | GE WSM2480DWW Unitized Spacemaker Washer...
How do I remove the front panel of a GE SpaceMaker washing machine?
Washer panel can be removed by removing the 2 screws at the bottom and push the panel down then pull forward.
Feb 26, 2010 | GE WSM2480DWW Unitized Spacemaker Washer...
My GE Spacemaker Dryer Model WSM 2700 DA no longer heats up. HOw difficult is it to change the heater element or is that the problem? P.S. I have cleaned all the vents out with very little material found.
either the heating element, hi-limit switch, thermal fuse (on some), cycling switch,or a burned neutral power wire in the unit, first, make sure you have 240 volts input power
Oct 22, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Dryer doesn't heat up
Take the back off the dryer and then take the heating element out and look for the coil wire to have a break in it. I have replaced serveral heating elements.
Sep 03, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
New GE Dryer Not Heating
Sounds like the HEATER COIL is bad or not connected properly on the inside. I would call the place where you purchased and exchange it ASAP.
May 29, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Pump leakage
yes but the coin trap just may be misaligned try to open it and lock it back in place...let me know
Sep 27, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer Logo
106 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
