Question about Canon imageRUNNER C3220 Color Copier
Printer networking can't print from my computer
    Master:
  • 638 Answers
  1. THERE MAY BE THE PROBLEM WITH USB DRIVERS IN UR PC .
  2. TO RECTIFY --- RIGHT CLICK THE MY COMPUTER ICON
  3. CLICK PROPERTIES AND THEN CLICK HARDWARE N GO TO DEVICE MANAGER
  4. UNINSTALL ALL USB PORTS AND THEN SCAN FOR HARD WARE CHANGES
  5. UR PC WILL DETECT UR PRINTER N ASK FOR PRINTER DRIVERS
  6. RELOAD DRIVERS N UR PC WILL COMMNICATE WITH UR PRINTER.
  7. FOR FURTHER ASSISTANCE FEEL FREE TO ASK AND WISH U SUCCESS -BYE
rate this solution as fixya if its help ful to u and encourage us to serve u better in future
Posted on Jun 12, 2008
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Apr 16, 2013 | HP Color LaserJet 2600n Printer
Tip
INSTALLING A NETWORK PRINTER These instructions generally apply to all network...
These instructions generally apply to all network printers with built-in network cards (print servers) such as HP Laserjet printers, IBM Infoprint laser printers etc.
This example is for a network HP Laserjet printer.
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network).
If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer’s network configuration accordingly.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
on Dec 06, 2009 | Computers & Internet
Set up wirelessprinter hp
Jan 28, 2013 | Office Equipment & Supplies
Ph8000 prints a network configuration page every time I print
Go into your settings under reports. You should be able to adjust to your liking.
Sep 28, 2012 | HP Officejet Pro 8000 Wireless InkJet...
Wireless printer configura
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc.This example is for a network HP LaserJet printer.To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly.
2. Install the HP printer driver onyour computer/s using the LPT printer port.
3. Connect the printer with a LAN cableto the network hub/router.
4. Click on Printers and Faxes - rightclick on the HP printer and click on Properties.
5. Click on Ports and click on AddPort.
6. In available ports - click onStandard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IPaddress of the HP's printer IP address.
8. Click OK and tick Enablebi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printerprints correctly.
Install the HP printer driver on every computer on your network and configurethe printer's TCP/IP port as previously detailed.Do a test print page to check the printer.
Jul 31, 2012 | HP Office Equipment & Supplies
CAN YOU PRINT DIRECTLY TO A WIRED PRINTER FROM THE ARCHOS 501594 TABLET
SETTING UP A SHARED NETWORK PRINTER
Any printer that isconnected to a computer and is connected on a LAN can be configured so allother computers on the same network can print to this printer. This means thecomputer with the printer attached to it MUST be booted up at all times whenother computers want to access the printer.You need to install theprinter driver on the computer and configure it as a Shared printer.The other computers on thenetwork need to add this printer to their computer.Follow these steps toset-up a shared network printer :-1. Connect the printer tothe computer and install the printer driver.2. Open Printers and Faxes- right click on this printer and click Sharing - click Sharing tab and click Share this printer, and then if you wish you could change theShare name, then click OK3. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation.Follow these steps toconfigure the computers on your network :-1. Open Printers and Faxes- click Add a printer - Next - select a network printer, or a printer attached to another computer - Next.2. Select Browser for aprinter - Next3. Click on and expand theMicrosoft Windows Network down to the computer with the printer - Next4. Select Yes for - Usethis printer as the default printer - Next - Finish5.Right click on the printer - click Properties - click Print Test Page toconfirm printer installation.
Jul 15, 2012 | Archos 101 Internet Tablet Notebook
How can I set up wireless printing?
Hi Brenda,
Considering that your printer has an in-built Ethernet feature means no need for external print servers.
  • Take the printers network/Ethernet cable and then plug it into a router/network Hub.
  • Once you've connected the computer to the network,install the printers software in all the[networked] computers that will use it.
  • Now try printing.Note that,the networked computers print jobs will be printed in order received.
Hope this helps.Thanks!
Oct 09, 2011 | HP Deskjet 6940 InkJet Printer
Can HP 1410 printer support LAN.
HP 1410 is not a network printer. If you want network printing, you must purchase a printer that features network printing.
You can designate a pc to act as network server and plug printer into that server, and then print from another computer on the same network
May 28, 2009 | HP PSC 1410v All-in-One Printer
How to install the lexmark E120 network printer
to clarify this, you need to install the printer in a computer that is connected to a Local Area Network lets call it computer 1. Once the printer is connected to the computer 1, share the printer by going to the start/settings/ printers. Right click on the lexmark e120 printer and click share. Click share this printer. Once done the printer that is connect to computer 1 is now on the network. on the other computer lets call it computer 2, to to start/settings/printer and click add printer/ select network printer and then browse the printer in the network and select it so that it will be added. Now you computer 2 has a network printer installed. try printing, make sure not to turn off the computer 1 when printing, or else it wont print.
Dec 22, 2008 | Lexmark E120n Laser Printer
Network printe on vista
Accessing a Shared Printer To access a shared printer from a computer running Windows Vista, do the following:
  1. Click Start, and then click Network. The Network window displays a list of computers in the workgroup of the computer.
  2. Double-click the name of the computer containing the shared printer that you want to access.
  3. Right-click the shared printer that you want to access, and then click Connect. Alternately, you can double-click on Printers to see just the list of shared printers, and then right-click the shared printer that you want to access, and then click Connect.
After you have connected to the shared printer, you will be able to print to this shared printer as long as the printer and the computer sharing the printer are turned on.
please note that in network the computer that has the network printer if it is running XP may take as long as 15minutes to be recognized.
Apr 09, 2008 | Samsung ML 1610 Laser Printer
Canon imageRUNNER C3220 Color Copier Logo
99 people viewed this question
old marine
old marine
