Question about Samsung Televison & Video
Can't get tv out of store demo mode. 40in lcd series 5-550
5 Suggested Answers
SOURCE: I bought a Sharp 52" LCD stuck in demo mode
Hi jmartinezua,
Here is how you fix this:
Go to menu--> setup --> reset
This will reset your TV to factory settings. The Demo Mode will cease.
JJ
Posted on May 07, 2010
  • 3 Answers
SOURCE: 42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
Posted on Nov 30, 2009
SOURCE: samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Posted on Mar 29, 2010
SOURCE: how do I remove demo
enter to Menu... Adjust... Atomatic start... later select Domestic Mode. It´s ready!!
See ya!!
Posted on Nov 25, 2010
My tv model number is 60lb5900-uv how do I get it off of store demo
How To Take Your Tv Out Of "Demo Mode"
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMay 21, 2012 - There are 2 ways to take your tv out of demo mode. ... When the message, "Menu language, store demo, and time will be set", and then press ...
Samsung: LN46B650 is stuck in Store Demo mode - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI just bought a Samsung LN46B650 and it is stuck in Store Demo mode. ... If you do get prompted to choose between HOME or STORE mode (and you might), ... on the tvfor 10-15 sec(i did almost 30)...but the store demo mode wont turn off.
Samsung HDTV - Disable Store Demo Mode (UN46D6003 ...
? 0:39
https://www.youtube.com/watch?v=emPw3NkUuss
Nov 28, 2011 - Uploaded by SPSN
Jan 19, 2016 | Televison & Video
Sony bravia lcd digital color tv
Press and hold the HOME button on bottom right side of TV for 10 seconds. It will toggle the demo mode ON/OFF
http://community.sony.com/t5/Television-General/How-do-I-get-out-of-quot-Store-Display-Mode-quot-Demo-mode/td-p/29979
Jan 21, 2014 | Televison & Video
Samsung series 5 lcd tv
Look for setup in the menu . See if it is set to store or demo mode. Does it do this on all sources? have you connected any new devices? Go to Samsung web sight and look for software upgrade for this model. Model and version number are on back side of set. If none of these things work replace the main board.
Jan 06, 2014 | Samsung Televison & Video
Digital noise filter off and on comes back after removing demo settings from picture options...how can i get rid of it off my screen permanently!!! i have series 5 samsung LED 40"
You have set up your tv in store (demo) mode. Go to settings then plug and play and scan channels again but this time select home mode before it searches for channels.
Aug 16, 2011 | Samsung UE40B7020 40 in. LED TV
How to remove auto visualisation n digital noise filter on and digital noise filter off features from screen of samsung lcd 21 inch....this feature is always there on the screen..........
My TV had the same problem and I have managede to get rid of it. The solution is very simple. This displays mean that your TV is in the " Store Demo" mode and any changes you make will last only for 30 minutes and when the TV is turned off the settings will change back to the normal. Whether you TV is in the "Store Demo" mode can be confirmed by pressing the "Info" button on the remote and you will see that "store demo" appears on the screen. To change this mode to the "home mode" you will have to press the "Volume button" on the TV and when the volume sign appears on the screen then you will have to press the "Menu" button on the TV (not on the remote)and hold it down for about 7to 10 seconds. This changes your TV mode from "store demo" mode to the home mode. Confrim whether the store demo mode has been put off by pressing the "Info" button on the remote to see whether the store demo sign appears on the screen. The store demo is set by sales persons in the shops so that any demonstratation/changes that they make while showing to customers will be temporary as the settings revert back to the original.
Aug 03, 2011 | Samsung SyncMaster 215TW 21" LCD Monitor
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
Digital Noise filter off , digital noise filter on and auto visualization is always displayed in my Lcd samsung series 4 even though i turned it off in Picture options , digital noise filter is changed to...
Aug 13, 2010 | Samsung LE40R74BDX 40 in. LCD Television
My toshiba 36in crt tv's demo mode keeps turning it self on
Since I do not have your tv model number so can't be specific, check Demo mode option in Menu and turn it off. Some tvs have selection like Store/ Display and Home mode, store or display mode is demo mode so set tv on home mode to turn off demo mode.
Let me know model number of your tv if you have additional question.
Thanks.
Jul 22, 2010 | Toshiba Televison & Video
Samsung ln-t4053h 40in lcd will not power on
my samsung when switched to the hdmi inputs comes up with a box saying not supported mode?? how ever shall i play my ps3 now?? can anyone help??
Feb 08, 2010 | Samsung LN-T4053H 40 in. LCD Television
Store Mode is ON.
for Bravia's.. To turn off the demo mode, press and hold the MENU button on the TV for more than 10 seconds. The message Demo mode: Off will appear on the screen.
Let me know if this helps.
Feb 21, 2018 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Televison & Video Logo
239 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
