Gateway One Fan Problem
When I power down my Gateway One and it completely shuts down, the fan starts running and runs all the time. I never hear it running when the Gateway One is powered on.
Fred
    Scholar:
  • 94 Answers
Hi, there is a possibility that the fan is self is defective or power supply cannot supply the fan completely thats why when you turned it on you never hear it running. ICheck the fan connection if is properly connected then using a voltmeter check the voltage supply in the fan it should be +12V or you can replace the it with a reliable one so that you can determin if the fan is defective or not.
Tirzo
Posted on Jun 13, 2008
Gateway gt4016 desktop, s/n gcm64 110 54982 unit will not boot up, pressing power button, fans starts, yellow light comes on, then shuts down. cleared cmos, pressed power button unit will boot up but...
the cpu could be over heating make sure its secure if you like get some thermal paste from your local pc world put a little on the top of the cpu under the cpu fan and replace fan securely might work be carefull....bonnell
Sep 17, 2011 | Gateway GT4016 Desktop PC
Thermal shut down on Gateway 500r
Have you checked whether the CPU fan is working or not
Sep 27, 2008 | Gateway 500GR PC Desktop
I have a gateway m series laptop. the cpu fan was making a bunch of noise. I don't know much bout fixing laptops but i opened the panel n took the fan out completely blew out the dust and put...
if your pc shuts down in 10 second with black sreen it means that your laptop memory was not detected. solution: reinsert your laptop memory (RAM) .. be sure to clean it especially at the contact points.
Jul 05, 2011 | Gateway Computers & Internet
My gateway mx laptop gets so hot you can fry an egg on it and the fan runs all the time and shuts down when its hit its hottest what can be done about this i have to shut it off or the fan will still...
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Mar 26, 2011 | Gateway Computers & Internet
My Gateway 7405 randomly shuts down. It does not matter how long it has been running for. It has shutdown during bootup and after running for many hours. Just before it shutsdown the fan accelerates to...
You might try changing the Power Options (its in the Control Panel) Properties so that all windows are set to NEVER. That is, so that it will never automatically turn off monitor, hard disks or go to standby. Also turn off all the alarms. This worked for my Presario R3000 running WinXP Sp2 which would shut off for no apparent reason. Having said that, you should blow out your fan with compressed air occasionally. And check that your power cord is OK. When you pull out your power cord, the battery icon should show operation.
Feb 12, 2011 | Gateway 7405GX Notebook
My gateway MA1 laptop running win xp has cooling problems
Contact GATEWAY, and get them to fix your laptop.
The fan is designed to run at "full-speed" when you first turn it on, and then there are temperature sensors that slow the fan down, to minimize noise, while the computer is "cool" enough that the fan does not need to run. The sensor is malfunctioning, and is not turning-on (or turning-up) the fan when the computer gets "warm".
Jul 17, 2010 | Gateway Computers & Internet
Gateway GT4010 boots then starts beeping and shuts off
First check your power supply section and check your power fan that is running properly. if ok then the suspected area is your processor section. please check it if its collar fan nor running properly then clean up or change that. and the other advice is please check your processor pin which are too tiny. be careful about these.
Apr 08, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Error code of 6 flashing light on circuit board,
There appears to be a short in the unit. Not sure where. The power to the fan is not interrupted completly when the fan shuts down, still feeding voltage to the fan, keeping it running slow. Before checking the wiring, please turn off power first.
Nov 19, 2008 | Heating & Cooling
Gateway 7405 GX Fully shuts down at random intervals
It sounds like a thermal shut down when the processor over heats,one thing it might be is that the heat sink is not seated properly on the processor.When removing the heat sink make sure you have thermal paste to place between the processor and heat sink.That should give you a good starting point.
Jul 28, 2008 | Gateway 7405GX Notebook
I have a Gateway One Model GZ7220. When it powers down the fan starts once the power is off and runs continously. I don't think it ever runs when the Gateway One is on. Can you help?
Wow that is strange. When the power supply turns off there cant be any more power.
Are you sure you dont log off or go to stand by? My computer does that to. Since I reinstalled windows my cpu fan stays running and my 2 case fans. Just go to power options to adjust your standy by options.
Jun 12, 2008 | Gateway Computers & Internet
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
