Question about Toshiba CZ36V51 36" TV
No Color It is a color tv that I got from my grandmother. It used to be just fine. I brought it home the other day and the picture is black and white. I dont know what happened. PLEASE HELP!
    Scholar:
  • 186 Answers
How is everything cabled? Is this over the air or using composite cables (yellow/red/white). Sometimes this will happen when you plug  a component cable into a composite connection or vis versa. If it's over the air signal or cable tv, check and see if the on screen menu for the tv is also in B&W. If the menu is B&W, it could something else.
Posted on Jun 12, 2008
Why does my KD-32FS170 32" Sony Trinitron screen have blue hues
If you turn all of the color out of the TV, the picture should be black and white. If that picture is not a true black and white picture, the TV will produce a color picture that has that behind it. It takes the proper mixture of red, green and blue light to produce white. This is something that is done inside the glass picture tube.
In your case, one color (blue is stronger) and the others are weaker.
It probably had not been used for a while. SOMETIMES, the weaker colors will get stronger with use. Adjust the brightness and picture controls to get the closest you can to a black and white picture, and then add the amount of color that seems right to you. Use the TV and hope for the best. It will improve, but 2%, 10%, or 50%; I do not know. The proper repair is to replace the glass picture tube, which is not an option at this time. So, turn it on, play games, and HOPE for the best.
Dec 04, 2014 | Sony Televison & Video
I just got a new player. Worked perfectly in the shop but brought it home and have a problem. After plugging it in it plays the DVD fine EXCEPT, the picture is in black and white. This was not a problem...
Select the type of video your TV requires within the menu of the DVD player and match it.
If the TV requires CVBS input and you are supplying S-Video, then you will get a monochrome picture because the chroma content is not being used.
Hope that helps.
Feb 27, 2011 | Televison & Video
Tv went to black and white
It may be a wire has come loose. Check your video inputs. Especially if you have animals or small children. On certain video inputs you lose color if one wire comes loose.
Jul 20, 2009 | LG RU-44SZ63D Television
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Our Color TV is now Black & White
It could be the color wheel and in fact probably is. I've seen them shatter which would explain the noise. They are glass and spinn at 9000 rpm. An involved repair though definatley a job for a pro. It could be worse, probably a few hundred will do it. Was the TV begining to be a little loud before the failure? Could be a sign, i've seen many noisy color wheels.
May 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
it sounds like the main board to me, I can purchase them if you want one let me know
May 22, 2007 | Samsung HLN617W 61" Rear Projection HDTV
NO Picture in Color except for PIP
have a tech check your tv the color circuit needs to be looked upon.good luck
Apr 29, 2007 | Akai PT5492S 54" Rear Projection...
Black and white picture on the JVC TH-505
If you hold the VFP button while a movie is on, you will get a small box on the corner that shows your color. My default color also turned black and white. I just moved over to a user1 color setting (push the right arrow on your remote), and it allows to the change the colors. You might be able to put the colors to come out through here. Hope this helps.
Jan 28, 2007 | JVC TH-M505 System
Hitachi pj-tx100 black and white picture when using s-video
s-video carries luminance and chromanance. In simple terms, luma provides a a black and white picture, chroma the color data. without chroma, you get no color. Either - the cable is bad (usually in the form of bent/broken pins in the connector ends - the source device is bad - the projector input is bad
Sep 21, 2006 | Hitachi PJTX100 Multimedia Projector
Toshiba CZ36V51 36" TV Logo
128 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
