Question about HP LaserJet 4350dtn Printer
Printing error need to take out and put printer's memory back , where is memory card in hp laser jet 4350
  • najijaqmil Jun 12, 2008
    how to change memory card of the hp laserjet 4350dtn
  • HP Expert
  • 141 Answers
Right side of the machine rear panel comes off, open metal door, there are your memory dimm slots. good luck!
Posted on Aug 26, 2008
LaserJet 4350 Printer: 49.2f02 service error on hp 4100 printer...
Turn the printer off for a few minutes and then back on. If that does not fix the problem, try to have the print queue cleared and tray again. Most of the time it's a PDF file that causes this problem. If that does not fix it, it may need a new Jetdirect card.
May 16, 2010 | HP LaserJet 4350 Printer
LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Jan 05, 2010 | HP LaserJet 4350dtn Printer
HP Laser Jet 4250/4350 series says its ready then it prints blank page and sends a message 51.20
Try a replacement toner cartridge first.If this fails, then i suspect it's a laser scanner fault. The error denotes beam detect error which is more than likely a laser scanner fault
Oct 12, 2009 | HP Office Equipment & Supplies
52.00 error
Hp says you have a bad scanner unit(laser unit) or DC controller, but first reseat all your connectors on your scanner unit(laser) and DC controller. Your scanner is located under the top cover and the DC controller is located behind the right cover. If the problem still persist replace the scanner first.
Apr 23, 2009 | HP LaserJet 4350n Printer
Double printing on single jobs.
You have software setting problem Check and double check your print dialogue box
Apr 21, 2009 | HP LaserJet 4350 Printer
49.ff04 service error
Check and remove the HDD and try it for a while. Replace the jet direct card and try (if you have one installed) and try. Update the firmware. If that fails then someone is sending a corrupt file\print job to the printer.
Oct 10, 2008 | HP LaserJet 4350 Printer
HP Colour LaserJet 4600dn printer problem
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Oct 29, 2007 | Office Equipment & Supplies
HP laser Jet 2840
Try using a different Memory card and see if it reads it, if not you might need to replace the memory card reader.
Oct 26, 2007 | HP LaserJet 2840 Printer
HP LaserJet 4350dtn Printer Logo
83 people viewed this question
Ben Johnson
