Water drains in wash cycle
When I start the wash cycle of my digital top loader washing machine all the water drains out as fast as it pours in, so need help in finding a solution. The spin cycle works but not the wash or rince. I downloaded the manual but the troubleshooting section refers to various sites that cannot help me as I live in the Dominican Republic.
The washing machine in question is a Samsung digital top loader Model No. WA80n3
  • justin150 Dec 02, 2008
    Literally same deal, anyone been able to remedy the drain plug issue with any simplified solution? Does it require taking the machine apart, easy to find compartment where the drain plug is? Be a hero and help me (look like I know what I'm talking about in front of my girlfriend). Thanks!
  • 549 Answers
It is probably a solenoid valve for the drain that is stuck open. There could be an object in it or may be defective.
Posted on Jun 12, 2008
How to clean wash machine tub
with acetic or formic acid its clean the calk residu
Jun 28, 2014 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Samsung wa13g7q1 top loader
UNPLUG and lean forwards. sounds like a blocked pump. look underneath for the pump and remove it, check out inside and remove any blockages.
Nov 18, 2013 | Samsung WE356A5W Washer/Dryer Laundry...
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
My bravos top loader will not fill up with water. The water drains as fast as it is trying to fill up. As a result, the wash cycle never completes.
You must make sure the drain hose is above teh water level and not in the water in the "P" trap of the house drain. There must be air to prevent siphoning. The drain hose should not go more than about 12" down in the drain tube.
Kelly
Mar 27, 2011 | Maytag Bravos MTW6600T Top Load Washer
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
I have an LG Fuzzy Logic top loader. it keeps draining water out
If it's really as you described, when draining at the same time filling up, then it's a problem in the main control board. You'll need some electronics knowledge to repair it, or just replace the main board
Aug 07, 2009 | Washing Machines
Kenmore washing machine will not fill with water.
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Jun 01, 2009 | Kenmore Washing Machines
Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Jan 13, 2009 | LG WFT1071TP Top Load Washer
Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Sep 12, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
158 people viewed this question
Top Washing Machines Experts
