Question about LG WM1814CW Front Load Washer
LE comes up on the display window halfway through cicle.
I noticed that a lot of other people had this same problem and just unplugged it for 10 min. and then plugged it back in, but the manual says that their is a filter on the back of the machine where you screw the hot/cold hose into the machine that needs to be cleaned every couple of months. I tried all the above solutions, and they worked for a couple months, then out of the blue again it would send the same error code, until I read about these filters. I did as the manual says to and cleaned them up, also ran 4 cups of vinegar into the drum and ran it for a full cycle to clean up any soap scum build-up. now the machine is working like brand new!! when taking the hose off the machine don't forget to turn the water source off. the filter is in the machine, not the hose so you have to really get back there and look to see them.
  • carrie092878 Jun 12, 2008
    its more like |E that is displayed. on the machine, not LE.
  • 210 Answers
IE is a water inlet error. It could be that your water valves are plugged as you suspect. What you can do is put the unit into a test mode and check your valves to see that they are working once you have checked your hoses and connections.
Make sure unit is empty and never try this with anything inside.
press and hold Spin Speed and Soil Level then press on and release
press the start button to advance
1 time tumbles
2 low spin
3 high spin
4 prewash valve (once spinning has stopped valve will turn on)
5 main wash
6 hot water
7 bleach, should be a lesser flow as it has a restrictor
8 tumble counter clockwise
9 temp in tub
10 drain
11 off
if your hoses are clean and the filters, and your water pressure is good, you may have a bad valve.
note, before it starts the door lock will engage.
Sgt 48
Posted on Jun 18, 2008
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ... > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during > ... > Scanning / Faxing
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
Washer stops cycleing
First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
Jun 24, 2017 | LG WT4870CW 4.5 Cu. Ft. Top Load White...
Is not want to star the cicle. and apper the letters "le''
Thanks for using FixYa. The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the Hall Effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. To resolve this check the wire harness connecting both of them and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Jun 03, 2010 | LG WM-1832C Front Load Washer
A new T7316 set comes up as a 7310 on a MICS 6.1
Thats because the set is a T7316 and not a T7316e set. The T7316 is seen by the system as a 10 button set. You'll also notice that the lines start about halfway down the display and can't be moved.
Oct 14, 2009 | NorStar Meridian M7310 Phone
Electronic display was flashing LE. Unable to open front load visible water. Tried to restart...unable. What is your best solution to open front and get washer working again? washer is...
Waht make? Model?
Sounds like an LG
You might want to unplug the unit for 10 min -then plug it back in and then power up , then press pause.
LE- could be a motor sensor, main board issue - wiring issue
Affordable Appliance repair
Orange County, CA.
Aug 22, 2009 | Washing Machines
Discoloration - No display of RED Color
unplug for 10 min to reset then plug back in go to menu and configure the color
Jun 06, 2009 | Microsoft Windows XP Media Center Edition...
Have picture lose picture tv turns off and on
the lamp has a life cicle. if yours is been used a lot. then the lamp has to be changed. when the tv cannot turn on steady and gets off imm. the computer inside the tv tries to turn off the set but the lamp charges again and the micro tends to keep working. the first step to take in this tv is to change the lamp to eliminate this common source of problems
Jan 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Keg freezing!!!!
Same problem here. Can you give me their number?
Feb 20, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Error message when trying to wash
Unplug the machine and spun the drum few times by hand, wait 10-15 min. and plug it back. Good luck!
Aug 06, 2007 | LG WM-2077C Front Load Washer
LG WM1814CW Front Load Washer Logo
130 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
