Question about NetGear RangeMax NEXT WNR834B Wireless Router
How to install if i don't have the installation cd?
I got a problem to connect the internet to the router, WNR834B. This is my first time to install the router without the installation cd. Can anyone teach me how to install it?
  • estandridge Aug 26, 2008
    i cant seem to find the setup cd that came with this wireless router. is there any way to intall it without the disk?
  • nad ezhda May 11, 2010
    how many desktop and laptops do u have? what is the version of windows(like xp,vista) running on those?
Yoiu can download the online manual @ http://documentation.netgear.com/wnr834b/enu/202-10171-01/index.htm
I'd also recommend you download the updated firmwire located here:
http://kbserver.netgear.com/products/wnr834bv1.asp
Hope this helps.
Posted on Sep 19, 2008
Tp link tl-wr740n how to install without cd
simply, connect it via network cable (LAN socket), turn on, check your gateway ip address, then type it in web browser, name/password should be admin/1234 or admin/admin, inside set what you need...
Apr 25, 2014 | NetGear RangeMax NEXT WNR834B Wireless...
How to install netgear wnr834b without cd
It depends on the ISP:
If it's DSL (verizon, att, centurylink, etc)
then you will need dsl login and password credentials. (PPPoE or PPPoA)
some others dont require it (DHCP) so you need to call and ask themt o confirm these.
you might also want to ask them about the ADSL settings: Multiplexng Method, VPI and VCI numbers. This will be very helpful.
For CABLE connections (comcast, time warner, etc)
it should be automatic. but if not try to search for MacSpoofing.
http://kb.netgear.com/app/answers/detail/a_id/1086
Oct 29, 2012 | NetGear RangeMax NEXT WNR834B Wireless...
Is a warmstart or soft reset on a netgear wnr834b possible ?? i hate the switch on / off procedure ( coldstart) to get my internet connection back ! THANx
There are times when the easiest method to reset the router is to power it down and then back up. You will not loose any of your settings on the router. They are stored in memory. You should not fear the power down.
Jan 28, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Need to know how to install rounter with out start
following are steps for manualy setup of router
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
regards
prakash
Dec 23, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
Cant connect to internet
Hi Keshavm,
Reset the router using the reset hole on the back panel of the router for 10 seconds.
Do not use the CD for installation. Instead follow the steps below:
1. Connect the modem to the internet port of the router. Connect the computer to the one of the 4 lan ports of the router.
2. Access the router using http://www.routerlogin.com or http://192.168.1.1
3. Login using username of admin and password as password.
4. Click on basic settings in the left hand side menu.
5. Under router mac address select use computer mac address and click apply.
This should do the trick. If not then turn off the modem and the router and then turn them back on. you should be online by now.
If not then call me at 9891323541 (Delhi, during working hours) and I will be glad to help u.
moz-screenshot.jpgmoz-screenshot-1.jpgmoz-screenshot-2.jpgmoz-screenshot-3.jpgmoz-screenshot-4.jpg
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 10, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Msg. conntected with limited access
Try this.
Unplug the Router.
Unplug the modem.
Wait about 15-20 secs.
Reconnect the modem.
wait about a minute or until all the lights are solid on the display.
Reconnect the Router.
Wait about another minute until everything is given time to start up.
Try connecting again.
If it still does that, it may be a problem with your computer that your trying to access with wirelessly.
My mother had that problem on one of her laptops, it turned out that her particular installation didn't support WPA or WEP incryption. I did a full reinstall and now it works.
If you want to avoid a full reinstall you can try uninstalling the wireless network card, then reinstalling it.(Make sure you go to your manufacturers web site first to download the proper driver for your model)
I hope this helps,
Simon.
Nov 19, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
I installed Netgear wnr834b on time warner cable. it works for a minute but then power and link lights go orange and i lose connection. have replaced router but still same thing. also replaced modem and...
If you already replace the modem and the router so it only means that the problem is with your Time warner internet connection line , did you already contact time warner and let them check your internet line to make sure the signal from them is strong and working fine if not contact them...
Oct 24, 2008 | Computers & Internet
Hi there, I just bought a netgear Rangemax next wireless router WNR834B with RANGEMAX™ NEXT WIRELESS N USB 2.0 ADAPTER – WN121T with no installation CD and i have connected the router to my modem and its...
Get the driver for the WN121T from the NetGear webset and install it before pluging the adapter into the notebook. Use a wired connection on the notebook until you have the drive downloaded.
Jun 19, 2008 | Computers & Internet
How to install if i don't have the installation cd of the router?
Here is a link to the setup manual. If you follow that step by step it is a piece of cake. If you still need help do not hesitate to ask and I will then walk you through it.
http://static.tigerdirect.com/pdf/netgear-WNR834B-manual.pdf
enjoy,
Lee
Jun 12, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
131 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
