Question about Pantech Duo Smartphone
Water Damage? I was going boating with some friends over the weekend. Just before I put my Duo in the lockbox of the boat, a friend asked me to help unload his jet ski. Well... my Duo was in my board shorts and got every so lightly wet. The keys still illuminated and the phone still vibrated when I was receiving a call, but the screen had no display on a back illumination. I took it apart to try to let it dry, but I got the same results... lit keys, but no display. Now I have nothing. When I try to charge it, the screen backlights for a few seconds (no display) and then it goes dark. Any ideas what I can do? Also, what color does the dot turn on a cell phone battery when it has sustained water damage? Thanks for the input.
Today i went on my slip n slide with it in my pocket annd it got all wet. but then to make it worse i dove into my pool not even knowing it was in my pocket. but it works completely now=)))
Posted on Jul 19, 2009
I just bought a new boat and need to buy a boat trailer. Should I buy a boat trailer with the weight capacity of my new boat, or do I need to make sure it can tow more than that just in case?
First of all you should know the height, length, width, and weight of your trailer, which is important and it will make it possible for you to transport your boat. Or if you want you can hire a boat transport services, by taking reference from the Internet or you may ask your friends or relatives if they had ever shipped a boat from transporters, because a boat delivery company had an experience in transporting boats and yacht safely.
Oct 16, 2013 | Boating
How do i launch a 22ft birchwood ruiser and how do i get it out of the water when there are only 2 people present, one female
only assume your female friend can drive. stage your boat at ramp you get in boat, she backs down into water, you drive boat off trailer. if she has trouble driving with trailer then you dock up boat and go park. OR you could let her handle the boat. just repeat process to load.
Jul 22, 2011 | Boating
All I need to know is a 2004 4wd 6cyl vortex 4wd chevy able to pull a 17ft fiberglasboat with 90 horsepwer ob single axle boat and trailer
look up your pulling capacity power of your truck.i had a four wheel drive v-6.ford ranger could not pull my 17 foot v-6 malibu boat. i allways had to ask my friends they had v-8 type trucks no problem.if my friends wanted to enjoy them selfs at the lake and water sky no problem.
Jan 29, 2011 | 2004 Chevrolet S-10
Is this kayak very stable in the ocean
Hwello
I read all the reviews of the boat I could find, all were VERY positive, all said the boat was very stable in all water conditions, the only draw back comment I ran across is that it is fairly heavy, but that is due to its rugged design, so really you can't have it both ways.
Having Kayaked in the Ocean many time myself I would buy this boat for that purpose after what I read. Here are some transcripts of the reviews I read
"used one of these while on vacation in canada,and i'm hooked it was very sable on rough waters,and we also took it out and went fishing ."
Bottom Line Yes, I would recommend this to a friend
"The Future Beach Freedom 160 is a nice stable boat with a rugged and durable build. Due to it's weight the boat is a bit on the slow side and a challenge to move around. Storage at the front of the boat is limited but could be expanded with a small modification. I am sure that this would be a great boat for fishing and other water sports (i.e. snorkling, SCUBA)."
"Love this boat, Amazing Quality, superb tracking
An absolute pleasure to use !!!!!!!!"
Dec 08, 2010 | Future Beach Freedom 160 DLX Kayak
My bass boat sat for about 8 months. I had it on the water this weekend and it was not idling well and had trouble starting. Once started, the boat ran well when i was in the throttle. I ran the old gas...
SOUNDS LIKE THE CARB LOW SPEED JETS ARE CLOGGED , THANKS TO THIS PITIFUL GAS WE GET TODAY ,I USE A ADDITIVE CALLED SEA FOAM IT WORKS GREAT JUST ADD TO FUEL EVEN WORKS FOR WINTER SET UP TOO
HOPE THIS HELPS
Aug 10, 2010 | Light Outboard Motor Boat Bass Fishing...
Prop not turning
if the prop spins out of the water but not in
it could just be a bad hub inside the prop
good luck with it
Jul 05, 2009 | Boating
Bravo one water on tiller arm
Assuming "tiller arm" is the steering arm (connects to steering actuator and disappears into transom plate, lay on top of engine - not running - and have a friend turn steering wheel, black arm that is coming out of transom and moving is steering arm), problem is most likely the seal on the vertical steering shaft. This shaft connects the steering arm to the gimble ring. Problem can be confirmed by visually checking for water coming from just below the steering arm with boat in water, or residue starting in same area with boat out of water. If this is confirmed to be the problem, repair is quite extensive. Entire transom assembly needs to be taken apart - sometimes requires removal of engine - then the seal can be replaced and the transom assembly put back together. Other items to check in the area would be the wiring for trim sender and limit switch and through hull gear lube fitting (if boat is new enough).
Mar 18, 2009 | Boating
MK Maxxun 74 run at high speed
A boat owner friend of mine is going to fix it in exchange I take him to my favorite fishing hole.
Thanks
Dec 09, 2008 | Boating
Balt 25 ft cabin cruiser batterys
To locate the batteries, all you need to do is follow the large red cable from either the starter motor or the battery switch. In both cases they will lead you to the battery.
I have been in the boating business for a long time and never heard of a manufacturer named Balt. To verify who built your boat, look for the Hull Identification Number. It is a 12 digit combination of letters and numbers located on the transom, or back of the boat. All boats built since 1973 are required to have this number. Once you have the HIN go to this link:
www.uscgboating.org/recalls/mic_database.htm
At this website you can enter the HIN and find the name and address of the manufacturer.
Jul 25, 2008 | Boating
Furuno navnet 1723 C
go into installation mode (hold menu during power on) find radar setup, go to next page, do heading alignment. also tune video, your unit was reset!
Jun 09, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Pantech Duo Smartphone Logo
182 people viewed this question
Top Pantech Computers & Internet Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
