Question about Home
Turn shower on and water does not go through hose. pours out through small plastick tube at bottom of shower box
    Problem Solver:
  • 6 Answers
Fhgdu
Posted on Nov 02, 2010
Fix water pouring from the inner pipe of it
The diverter may be stuck.
Jun 01, 2016 | Home
When i put my shower on theres water pouring out of the small pipe at the base of the shower behind the shower hose
sounds like you are missing the black rubber washer remove the hose from the shower arm see if its missing or crushed inside of the fixture.
Jul 02, 2012 | Home
Water coming from around the bottom of gainsborough 9.5E electric shower. I think its a pressure release device. Do I need a call out or a new shower. Or can I fix it.
Piece of P: youre prob right and its the pressure relief device, which is a silicone rubber ball that gets blown out of a branch of the exit pipe just behind where the hose screws on. If you are careful you can push it back with a small (non sharp) screwdriver etc, looking up from underneath. It would be easier to see if you unscrew the hose first.
Sep 05, 2010 | Home
Plastick water lines to brass shower handle i used teflon tape to try to seal. plastick threads are male to female brass
If the waterline is plastic then it may be PEX. Wrap the male plastic threads in a few wraps of teflon tape. Screw on a Brass PEX fitting onto the plastic threads and then connect the PEX pipe with a crimping tool.
Is that what you were looking for? If not let me know a few more details.
Thanks,
Jan 06, 2010 | Delta T13420 Chrome Classic Single Handle...
Water pressure to main hose has ceased, with water now pouring out of a small outlet pipe at bottom of unit next to fixing for main hose.
Sounds like your outlet at the top has clogged with grit/dirt. Turn the shower off, remover the entire shower head hose from its base (where it screws into the wall or pipe. Turn water back on. If you get a steady flow (as you should) the problem is isolated to the shower head/hose. Detach the shower head from the hose and clean the screen inside, attach hose back on first, try water again, if this flows then your blockage is in the head itself. After removing and cleaning the screen inside the shower head, reattach and run water, this should fix your problem, if not, you may need a new shower head. If the water will not flow to the outlet pipe alone, either your shower switch is broken or you have a serious plumbing problem.
Apr 16, 2009 | Home
1/2 water through shower head 1/2 through tube
patmac make sure the clear hose is a overflow first. then make sure all connections are correct,sounds like an areator problem,some after market shower heads don't come with one you can purchase one at your local plumbing store.
Apr 05, 2009 | Home
I have a top-mount refrigerator that is leaking from the air vent
I had the same problem with a whirlpool refrigerator with freezer on top. TURN OFF & UN-PLUG IT. To access the freezer drain you must pull the refrig out from the wall and take off the bottom-back panel, it uses some (7) small nut headed screws. The drain is the white tube on the left going into the drain pan. You can push a long wire or plastic hose up the tube, however that will probably only hit something solid (ice) and blowing air may not clear it, until you let the freezer completely thaw out, which may take several days. The following may help experienced do-it-yourself nuts, it is not for the faint of heart! I took out all the freezer items and placed them in coolers to keep them frozen. Then removed the back panel in the freezer, two nut headed screws at the top center. The bottom of this panel was frozen to the bottom of the freezer compartment, so I used a hair-dryer to thaw it enough to loosen it. (Be careful: water and electricity do not mix well!) The left side of this panel has some electrical control wires attached, so the left side will not come out, just rotate the panel and lean it against the left side of the compartment. Now use the hair dryer (or pour hot water on it) to melt the ice along the bottom back of the compartment under the freezer coils. BE CAREFUL: The fins are sharp and will cut! Do not bend them. If they are all frozen up your heating element-defroster may be out. If there is only ice along the bottom, the hair-dryer or hot-water will help melt it to the point it can be removed. If the drain hole at the back-bottom-center-right is plugged with ice, poor hot water on it to speed up its melting. The hair drier will not do this very fast and you cannot chip it out without damaging the plug hole. Mine was solid ice about 2 inches into the tube and hot water finally thawed it. Then pour water through the hole to flush it out. Clean the bottom drain pan & re-assemble. Good luck.
Dec 16, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore elite washer model 20952992 pouring water
We had the same problem. The bleach dispenser tray is located on the drum below the bleach storage pan. The dispenser tray has very small holes that were plugged by rust from the hose clamp that attached the dilution water supply hose to the bleach storage pan. I removed the top of the washing machine to discover the problem, but it may be solved by attaching a flexible tube or small hose to the end of a vacuum cleaner hose and cleaning out the dispenser tray. There is room between the dispenser tray and the storage pan and is located in the front right corner.
Dec 10, 2008 | Kenmore Elite HE4 Electric Dryer
Home Logo
56 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
