Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
Posted on Jun 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Saeco Primea Touch
Hot water drips from hot water spout when grinder is operating. Is this normal?
Anonymous
Level 2:
  • Expert 74 Answers
  • Posted on Jul 11, 2008
Anonymous
Expert
Level 2:
Answers
74
Questions
0
Helped
53073
Points
146
Anonymous
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jul 31, 2008
Anonymous
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
5
Questions
0
Helped
5816
Points
6
Hi there
You can run a diagnostic check from the Service Menu.
To enter the Service Menus please see 0505's post on the Saeco threads here.
Paul
2answers
My Saeco Odea Go makes coffee very slowly
If the water pressure coming out of the steam/hot water arm is fine, then the issue is likely with the brew unit or the grinder. Here are a few things you can check:
  1. Clean the brew unit: A dirty or clogged brew unit can slow down the flow of water. Remove the brew unit and clean it thoroughly, making sure to remove any coffee residue or buildup.
  2. Check the grinder: A dull or clogged grinder can also slow down the flow of water. Make sure the grinder is set to the appropriate setting for your coffee beans and check that the grinder is not clogged.
  3. Check the water flow meter: The water flow meter measures the amount of water flowing through the machine. If it is clogged or damaged, it can affect the flow of water. Try cleaning the water flow meter with a soft-bristled brush and see if that helps.
  4. Check the water filter: If your machine has a water filter, it may be clogged and affecting the flow of water. Replace the filter if necessary.
If none of these solutions help, it may be a more serious issue and you may need to bring your machine to a professional for repair.
5helpful
Error 1 on saeco primea touch plus
The grinder motor is not working,,better to take it to the service center to replace a new one under warranty if the machine is new.
Hi, I have the Saeco Primea Cappucino Touch Plus , and it syddenly gives the error code 5 - Call assistance. I have just changed the primea Water Filter - same way as always ! What can I do ?
Need to prime the machine. The new water filter is causing the air lock in the system.Remove the filter and startup the machine it should prime by itself, when it's ready,fit the filter back and press hot water until the water flows steady. Hope it helps.
2helpful
Grinder jammed
I'll explain how to in general, you have to work out the rest...first remove 3 screws on the coffee container...and 3 again underneath.To remove the sides..undo 6 T10 screws on RH side and 3 on LH.Then pull the front knob off and remove the coffee spout.Remove the top cover.Check the grinder whether itis accessible from the top ,if not remove 5 phyllips screws that hold the top half.Lift up and pull the grinder out. Good luck!
Primea ring hot milk
if you go in the menu there a temperature setting for that machine pierre
Saeco Primea new machine - slow dripping
look in manuel how to ajust the coffee grinder its grind the coffee to fine when you ajust the leveler of coffee move it only when the grinder work do a few ajustment it will be fine pierre
Flow
Check your grinder to see if the grinds may be too fine. Increase the grinder size and see if the coffee speed is increased.
If not, Contact saeco usa for support at 800-933-7876.
Out of warranty repairs can be completed by Cerini Coffee located in New York.
www.CeriniCoffee.com
Replacement parts for your saeco espresso machine located at http://cerinicoffee.com/Saeco_replacement_parts.asp.
Saeco Primea Cappuccino brewing very slowly
Try to descale the machine.
Try to adjust the grinder little.
/Mirran
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
