Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
AutoCad LT 2006 incompatible with Windows Vista
I recently purchased a new HP laptop computer from a Best Buy store. When attempting to install AutoCad LT 2006, I get an error that says the AutoCad software is incompatible with Windows Vista. I tried the support topic list and tried to use the fix described for error 1606 but it failed. Is there an update that will fix this situation?
I have intalled vista home premium, there is an incompatiable issue.
Kindly solve the problem
Posted on Nov 08, 2008
  • 75 Answers
Some of the older versions of autocad does'nt tend to work in vista.try installing autocad 2008 or 2009.it is recently released and well compatible with vista.REMEMBER, if u r using it for architectural purposes,try downloading autocad architecture 2008.it is especially made for architects.try downloading it on torrentz.com
Posted on Jun 17, 2008
4 Suggested Answers
  • 81 Answers
SOURCE: error 1721
What Is Error 1721? This is an error commonly witnessed when you try to uninstall a program using the "Add or Remove Programs" in Microsoft Windows XP. The message itself will read: "Error 1721. There is a problem with this Windows Installer package. A program required for this install to complete could not be run. Contact your support personal or package vendor."
Resolution #1: Reregistering the Windows Installer service It is known that if the Microsoft installation engine malfunctions or is internally corrupted, there is a possibly that you will not be able to remove programs that you used the Windows Installer, the service that administers the installation and configuration of programs, to install with. Thus, in the case of error 1721, it is necessary to unregister and then reregister the Windows Installer service to fix the corrupted parts of the engine. This can be accomplished through the Safe Mode by:
  1. Enter your computer in Safe Mode by:
    • Restarting the computer and pressing F8 after the BIOS information is shown
    • Select Safe Mode and Enter
    • Select your computer and Enter
  2. Log on as the local administrator
  3. Open up the command prompt by clicking Start, Run, and then typing cmd.exe and Ok
  4. At the command prompt, first unregister the service by typing msiexec /unregister and then hitting Enter
  5. Reregister the service by typing msiexec /regserver and then hitting Enter
  6. Type Exit to exit the command prompt safely
  7. Try to remove the program once again using Add or Remove Programs
I hope this helps you out. Thanks
Posted on Sep 04, 2008
  • 51 Answers
SOURCE: Driver & software for webcam presario c700 for hp compaq laptop
your webcam is external or built-in in your laptop? just plug your webcam and it will automatically detect by wyour windows and will be ask a driver for installation of your webcam....if you have a cd driver of your cam insert it to cd-drive and follow the instructions on your screen...
Posted on Mar 10, 2009
rhojojoe
  • 93 Answers
SOURCE: safeboot corrupted (error 92h)
Safeboot corrupted. Run the Recovery Console by doing the following;
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
  4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation.
    For a list of commands that are available in Recovery Console, type recovery console commands or help at the command prompt, and then press ENTER.
    For information about a specific command, type help commandname at the command prompt, and then press ENTER.
  6. To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Posted on Jun 24, 2010
I have a hp ellitebook 8440p and it shutsdown when running autocad lt2009
1. Autocad uses a lot of memory. Make sure you the maximum ram installed. You can check the virtual memory if that does not work.
2. Shutting down in the middle of an operation can be that the unit is overheating. Use a cooler, docking station, or stand the book on the side with the laptop lid open about 45 degree angle. Leave it on to see if it shuts down within the same time as when it was laying flat with Autocad running. If it takes longer, the problem may be a fan not cooling properly or allow more cooling during the use of Autocad.
Mar 07, 2011 | Autodesk AutoCAD LT 2009 Full Version for...
Autocad in vista
Installation process of all softwares are same (The wizard format) except if you are getting any error message.
Aug 30, 2009 | HP Pavilion dv4000 Notebook
I want to run autocad on genuine on vista home basic
its better u buy new software but if u r learner then best way is u use trial version and there is no problem of any type with vista, but remember piracy is not good thing, :-)
Aug 24, 2009 | Microsoft Windows Vista Home Basic Edition
Unable to load autocad 97 on windows vista
I don't believe Autocad will work at all on Windows Vista.
The only other solution I can think of is to download Virtual Box from http://www.virtualbox.org/
You will need to have an XP cd to install, and basically you will be installing an XP virtual machine, at which time you can then install Autocad 97 onto that virtual machine.
Hope this helps!
Jul 19, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
I have the 7570 model and just recently got windows vista installed on my computer and now my computer states that there is no communication between the sewing machine and the computer I have an adapter...
I went to a computer store (Rabbit Computer) that repairs computers and purchased a new cable. They said that some customers had a problem with Vist and the more expensive brand of cable so I bought the cheap one. I had to install drivers on my compter and everything thing worked on my first attempt to download to the machine. The cable was half the price of the one at Best Buy.
Jul 03, 2009 | PfaFF Creative 7570
Autocad 2006 on Vista home premiun 64bit
This will not work on vista 64 BIT you will need autocad 2009 64 bit version.
May 04, 2009 | Autodesk AutoCAD 2006
Incompatability between hp scanjet 3970 and Windows
Hi, just go to HP drivers and solutions, i have Vista 64 bits.
Rgds, Auke.
Mar 20, 2009 | HP scanjet 3970 digital flatbed scanner
How to Autocad LT 97 install to VISTA PC
I have autocad 97 and want to install it on windows 7 can you help please
horriel
Jul 19, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
PLEASE HELP
some of the older versions of autoca does'nt tend to work in vista.try installing autocad 2008 or 2009.it is recently released and well compatible with vista.REMEMBER, if u r using it for architectural purposes,try downloading autocad architecture 2008.it is especially made for architects.
Jun 06, 2008 | Autodesk AutoCAD 2006
Problem printing with Deskjet 1280
pls install plotter dirver for autocad .
bye
Dec 01, 2007 | HP DeskJet 1280 InkJet Printer
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
1,428 people viewed this question
Top HP Computers & Internet Experts
Tony
mukhtar21 shaikh
mukhtar21 shaikh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
