Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Ice Maker Not Working
Hi, sorry it's been a while but I posted a problem I had with my ice maker and you were very helpful so I was hoping you could help me again.
I got a new module as you suggested but I can't get the ice maker to start working again. I tried jumpering it but it still won't start.
I tried it according to your instructions but I'm not sure if I'm following the procedure properly so I was hoping you could help me through it.
Sorry to bother but any help would be appreicated. Thank you.
    President:
  • 878 Answers
Vik, If this is a indoor Ice maker with the infrared boards, make sure that the boards are working correctly. With the door open, on the right side you should have 2 flashes with a pause, this should happen repeatedly. Now holding the left side immiter flap down, the light should stay on steady. This of course holds true when the ejector blades are in the home position, 2:00. If this checks out jump start the ice maker by removing the thing and setting it on the shelf, harness still attached. Unplug the refer. Insert a jumper to T & H and leave it in. Close the freezer door. Plug the refer back in and wait 50 seconds. Open the door and see if the module is cycling. If not, press the door switch in 3 times while holding the left side immiter blade in. You may have to try this several times to get it going. Once going, pull the jumper out and place the module cover back on and slide it back into it's rail. It has to work sooner or later. I have had bad modules sent to me and stood there baffled when I could not jump start them. Tried another module and it started right away. Let me know if it did it's thing, Catriver
Posted on Jun 12, 2008
I turned the ice maker off now I can't get it to turn on and work it freezes cubes but won't dump them in ice been
Ice maker harvest cycle is not working. Jammed timer in Ice maker unit.
Remove the wire harness of the ice maker and put it back after 5 minutes. See next day whether it is working.
If not still working. You did the right needed thing at the wrong time to shut off the ice maker. You will have to replace the ice maker.
Ice maker units are very sensitive units. Sorry to say.
Oct 23, 2017 | Refrigerators
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Ice Maker not working after replacing IceMaker and Inlet Valve. Any other ideas?
Hi. I am sorry that your ice maker is not working. Hereis a link to schedule a service call: http://bit.ly/yLv4Z5 . I hope this information is helpful. Sincerely, Melanie, Whirlpool Social media group.
Jun 19, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
My freezer is not freezing anymore please help as can not afford a new one ..thank you
Follow the steps mentioned below to solve the problem:
First remove the ice bin and look inside the mold of the ice maker to see if it is full of ice. If the ice sensing arm is down ( on position) and the ice maker is full of ice, there is a failure inside the ice maker and the ice maker should be replaced.
If there is no ice in the ice maker, look at the fill tube on the rear of the ice maker. If the fill tube is frozen up the ice maker can't fill.
You can defrost the fill tube with a hair dryer.
The water valve on the rear of the refrigerator supplies water to the water dispenser and the ice maker. Since the water dispenser is working, the only line that could be blocked runs up the back of the cabinet and attaches to the fill tube for the ice maker. The water valve could be bad and not sending water to the ice maker.
If the fill tube freezes again you should replace the water valve.
Hope this helps.
Shane
Mar 16, 2011 | Whirlpool ET8WTKXK Top Freezer...
The ice-maker in my Daewoo Fridge Freezer (FRS-U20DAI) is not working. The ice tray does not empty.
is there ice in ice maker but it wont empty?
the ice maker has built in heater underneath. thats how the ice detaches itself from the ice maker and the fingers rotate them out.. if you have ice in the ice maker then replace ice maker
hope this was helpful
Mar 27, 2010 | Freezers
Neff K3990 American style fridge ice maker is not producing ice
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards!
Jan 04, 2010 | Refrigerators
ICE MAKER NOT WORKING
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator ice maker stopped working
heatman101
mnnmbnm
Kenmore side by side refrigerator freezer not making ice
sorry if i sounded rude i just couldn't read the entire post it just trailed off...
if it not the water valve then it is either the ice-maker is bad or the waterline going to the ice-maker is frozen or clogged.
sometimes the water valve will slowly leak a small amount of water to the ice-maker and this will freeze in the large tube going to the ice-maker from the back of the refrigerator. this will block any more water from coming thru.
hope this helps
Jun 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Ice Maker
I just noticed you had posted a question to me. Apparently the FixYa notification thing is not working to notify me. I figure you have already gotten the ice maker working by now but if you have not I am happy to help.
Most likely cause of your problem is the ice maker motor MODULE probably is bad. If you remove the white cover and find the white driven gear is not flatly snug against the module face or if you remove the module and find any burned contacts it is bad. If you find burned contacts you probably will have to replace the whole ice maker. While you have the ice maker out of the refrigerator be sure to check the condition of the coating on the ice maker mold. If it is peeling you will want to replaced the complete ice maker.
I really hope this has been of some help to you.
supertechks
Mar 12, 2008 | Refrigerators
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
63 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
