Question about HP Compaq dc7100 PC Desktop
Hibernating I guess
I have a HP dc7100 tower and a 1530 monitor, i've recently moved and had to re-hook everything back up, in doing this the cpu comes on but the screen is blank it just says "going to sleep" so I am not able to do anything with the computer, the mouse does not activate anything or the keyboard, what is wrong and what can I do to get it back up and running, again, I can not see what's going on on the screen.  Thanx for any help.
  • ynotbbad Jun 17, 2008
    Okay, there is no Fn key on my keyboard.  The only thing plugged into my computer is the monitor, the keyboard and mouse.  both the green lights on the computer come on but the one on the right stays on, which never does, and the left one continues to flash.  The monitor says "Going to Sleep".  I can hear the word program come on with the music.  I do not have vista, the system is 4 years old, it was pack and moved and unpacked it sat for about 2 weeks with no activity.  The monitor is a hp 1530 and the light turns amber after about 10 seconds of turning it on.  I have tried and changed several plugs and outlets, there is no disc in the drive, I do not believe there is anything wrong with the keyboard, I just think it's in the suspend mode and I can't get it out.  HELP!  Thanx
    An expert who has written 2 tips or uploaded 1 video tip.
  • 69 Answers
May be your keboard is falty ... check weather the sleep button is pressed or damaged...
if yes then change keyboard.
Posted on Jun 13, 2008
  • Yoges Maharjan
    Yoges Maharjan Jun 17, 2008
    if this doesnt work thn try the combination of keys
    Fn + F4
How to coonect HDMI CABLE from CPU to Monitor of HP Pavilion
Look for an HDMI port that fits the cable on the back of the computer tower and monitor, also look on the video card outputs on the back of the desktop itself.
Dec 30, 2013 | HP Pavilion Computers & Internet
Compaq FS7600 Computer not turning on
what tower? model, the monitor has nothing to do with power and dead fans in the tower.
'Sounds, (and silent to) means the PLUS in the PC is dead.
all things can be repaired, that is what technicians do.
here is the chain of events, ! to get noise (fans)
power in the wall 120vac , usa
power to the PSU,
the power button goes to the MOBO, and standby power is there
now and pushing said button the MOBO commands the PSU on
if the PSU is happy (PWROK) thinks PSU IS safe the PSU tells the PC its ok, and power stays up.
and fans run.
so my guess bad PSU, its easy to test with anyf $10 voltmeter,
tower PSU, 101
May 21, 2017 | HP Compaq FS7600 17" CRT Monitor
My Acer Aspire M5100 get power but will not turn on
Does the CPU fan come on ?
Does the power lead that plugs into the cpu fan on the motherboard supply the required voltage ?
This one is a bit harder and once you check it you most likely need to apply thermal paste - but is there sufficient thermal paste between the CPU and the heat sink on the CPU ?
Does the power supply box in the tower case have its fan spinning when power on ?
Is the motherboard bent ?
I have seen this one - poor installation with different sized mounting screws. When motherboard gets hot the motherboard went faulty.
Some motherboards need a rubber insulator under the screw maybe there is a short under one of the mounting screws !
Mar 12, 2017 | Acer Aspire M5100 AM5100-U5313A AMD...
Powered down my cpu (hp pavilion 1530 ) and about 5 hours later it would not power up. Hit he power button and nothing, no fans, no blue light, no cdrom bliking, but the green led is lit on the P/S.
Open your tower:
Remove first the video card if you are using a Add in video card. Of course connect your monitor to the built-in video card
Try now
Next remove ram and reseat them back ( if you have more than one stick, try reseating only one)
Try now again
Disconnect CD-rom, Hard Drive
Try now
Last but not least try a different Power supply
Good Luck
Apr 29, 2011 | Computers & Internet
I recently placed my computer into storage. When I took it out and set it up, the CPU seemed to be running but there was nothing on the monitor and the keyboard didn't seem to be functioning. The mouse...
unplug the power cable of the CPU
press the power button for about 5-10 secs
open the tower and reseat the memory
theres 2 white clips on each side press down the white clips until the memory pop out
check the memory if theres any dust and put it back the way it was before
push the memory back in with a small force until the 2 white clips snap in
hope this help
Sep 07, 2010 | HP Pavilion a1410n (ER890AA) PC Desktop
Mx75 monitor turns off when I awaken my computer
right click on desktop select properties(screen saver ) select monitor button in that select turn monitor never.(configure carefully)
Nov 24, 2009 | HP Pavilion MX75 17" CRT Monitor
Hibernating I guess
boot your computer in safe mode and in display properties>Screensaver>Power tab>Advance>
"When i press the power botton on my computer " select "do nothing" and " when i press the sleep botton on my computer " select "do nothing"......
then press ok and apply then restart your computer in normal mode it will work
Jun 12, 2008 | HP Compaq dc7100 PC Desktop
HP Compaq dc7100 PC Desktop Logo
197 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
