Question about Kenmore 21.7 cu. ft. Side-by-Side Refrigerator with Thru-the-Door Ice & Water with Water Filtration 4659267
Need help with ice maker
I have a kenmore side by side that has an ice maker and water dispenser, the water works but it won't make ice. any ideas?
  • 77 Answers
Thr tube leading to the ICM may be frozen. this can be removed through the back and cleaned. if it continues to freeze up it is likely the water valve.
Posted on Jun 13, 2008
Ice maker not working, 2005 kenmore side by side
could b couple of things wrong tstat inice maker may b bad motor may b bad. best solutionis to replace ice maker
Oct 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water will not dispense to ice maker
The water dispenser in the door of my Kenmore side by side will not work. The ice dispenser does work. What do I need to do to fix it?
Thanks Kel
Sep 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice dispenser not working water does
I need help in solving this problem. The ice dispenser is not working but I still get water. Thank you please let me know what to do.
Aug 11, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore side by side water dispenser has stopped
Most likely need to replace the water inlet valve. The water supply line should be directly connected to it. There are 2 valves bracketed together, 1 for the ice maker and 1 for the water dispencer. You will probably have to buy both valves, but want to do this anyway as the second valve will fail soon. Hope this helps.
Jun 14, 2009 | Refrigerators
Water dispenser works, but ice maker not working.
i have the same problem right now.. water supply is goodand water dispenses from dispenser. tray that makes cubes not getting any water. looking for help also.
Dec 27, 2008 | Kenmore 53642 / 53644 Side by Side...
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Ice maker
poss a problem with a blocked filter?
Jan 20, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
165 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
