Sears Kenmore HE2 front load washer
My washing machine has water flowing from just under the soap dispenser. I've removed the dispenser and checked the hose, and the little bit I can fee I don't feel a blockage. I'm not sure how to check the rest of the hose to see if a sock or something got stuck in there. Do you have any ideas?
  • 2 more comments
  • katito Jun 21, 2008
    My Kenmore HE2 is leaking from under the soap dispenser,can you help me with this problem
  • HE2overflows Nov 20, 2008
    I have the same problem with my Sear's Kenmore HE2 PLUS front loading washer.
    Do you have a solution to this?
  • DrManchester Jan 18, 2009
    I had the same problem in the first few months after I bought the machine. It was still under the manufacturer warranty. The repairman found a sock stuck somewhere. Now I have the same problem again and just cant find where the darn thing is hiding! Kenmore should aknowledge a design flaw as this seems to be a common problem. I am going to try to call them and see if they would offer me help over the phone or better yet, send someone in. It would probably be a good idea if everyone who has the same problem call them.
  • Anonymous Mar 26, 2014
    I have a samsung front loading silver care machine model wf448aaw. It has three hoses bringing water to the soap dispenser from the back of the unit, and an additional hose that connects to the soap dispenser on the side. This last hose has a connector that has the shape of a funnel and has a ball bearing inside it. That funnel burst open, and is spilling water. What causes this?
I found the problem. A piece of clothes is stuck between the rubber and the stainless steel revolving enclosing in the upper left area (11 o'clock area). In our case it was the newborn hat! The area is so tight and if your fingers are big, you will have difficulty finding it not to mention pulling it out. In my case only my wife's thin figers were able to pull it out. I called the factory to let them know that this is a design flaued, but they were not taking calls on Sunday. I urge everyone to call them 888-KENMORE and complain. Maybe one day, they will recall the machine! Yeah right!
Posted on Jan 18, 2009
  • lenahayward Sep 06, 2010
    Awesome! I found the osbstruction almost immediately, the kids sock! Thank you!
Dr. Manchester's suggestion was a bulls-eye! Went right to the area recommended and found a piece of clothing trapped exactly in that area. Tough to extract with fingers, but came right out with needle nose pliers. Great solution...saved us a call for repair.
Posted on Aug 02, 2010
  • fixlala Jan 08, 2011
    Yeah.............found a broken sock stuck in between............Now the washer make no sound.......and leaking doesn't exist under the soap dispense area anymore. Thanks!!
My kenmore he2t is spilling water out of soap dispenser
The dispenser is removable like a car ashtray. Put it in the dishwasher and run it through a cycle Or soak it in hot water and clean it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 09, 2012 | Kenmore HE2 Plus Front Load Washer
I want to bypass the soap dispenser on my Kenmore HE front loader.
There's no reason you couldn't just put powder HE detergent on top of the clothes before you wash. The water will still run through the soap dispenser
Sep 03, 2012 | Kenmore HE2 Plus Front Load Washer
How do I remove the soap dispenser from my Sears Kenmore frontload washing machine?
There's a lever towards the back of it push it down and you can remove the soap dispenser.
Jan 06, 2011 | Kenmore 43142 Front Load Washer
Kenmore front load washer is leaking water from soap
We had a similar problem with water coming out of the soap dispenser when the washer was run. I assumed that it was a problem with the water draining as everyone else posted here. I took off the front panel, got rid of the junk and drained it. Although this was great, it did not solve the original problem. It turns out that there was a sock stuck in between where the water comes out of the soap dispenser and in to the main compartment. Pulled it out with a needle nose plier and good to go. Thanks to everyone for their input here.
May 28, 2010 | Kenmore HE2 Plus Front Load Washer
Water is coming out of the soap dispenser, what do
We had water pour out of the dispenser of our Kenmore HE2 washer. hot water helped us for one load then i realize that a trapped rag was the problem We were actually able to pull the face cloth out of the intake tube without taking everything apart!
opened the washer door and feel around inside the rubber seals to find where the intake tube connects to the drum (upper-left side). felt a small bit of cloth sticking out of the tube and were able to slowly work it out by pulling back and forth. and pulled it completely out thats all it was try this
Oct 05, 2009 | Kenmore HE2 Plus Front Load Washer
F20 error on Kenmore HE2 front load for no reason
under top cover does it have flow meter? ck connection and resistence with ohmmeter, ck pressure sw.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
He2 front loading washing machine leak at the soap dispenser regi
Hi dlypooh, thought I would post the solution here as well for anybody who needs to do a search in the future...
Remove the dispenser, pour water into the opening and make sure water can get into the machine freely. Inspect the opening for soap build up.
If water goes down slowly (re: dlypooh), open the washer door and feel around the bellow for anything blocking the water inlet port into the washer (socks can sometimes get wedged up there and cause a blockage).
If it all checks out ok, make sure the machine is properly leveled and not leaning forward.
Hope that helps!
Jan 13, 2009 | Kenmore HE2 Plus Front Load Washer
there is a spring around door opening that holds bellows on remove it and pull back from inlet opening also possible if you use dry detergent a lump has become lodged in fill line working something from both ends may dislodge it
Nov 26, 2008 | Washing Machines
Washing Machines Logo
419 people viewed this question
Top Washing Machines Experts
