Question about Dell E173FP 17" LCD Flat Panel Monitor
Final Answer to Dell E173FP blank screen problem?
Ive done alot of searching. When I turn on the screen, it goes blank after 1/2 second and the green power light stays on.
I replaced the 4 transistors on the inverter board and it didnt fix the problem.
Are there any other solutions to the problem?
  • 1 more comment
  • normq Jul 03, 2008
    The monitor goes blank and the power button flickers after an unpredictable amount of time (a minute to several minutes) passes. Sometimes the monitor works fine for an hour. If I tilt the monitor forward, if often resolves the problem when I tilt it back. Go figure!
  • Anonymous Jul 16, 2008
    I have a Dell E173. I turn it on and the screen is the WinXP desk top with a white lock on it. Then it goes black, but the on (green light) stays on. I need answers for this, or a how to to fix it. Thank you
  • Anonymous Mar 02, 2009
    I have the same problem, when I turn it on, after about a second it goes blank, but the green power light stays on. I can still hear everything. If I turn it off then on again, it goes blank again in a second. This problem started after I did a reformat and system reinstall with drivers from Dell.com
  • 46 Answers
Check out this link http://www.lcdrepair.us/Installation.html
They have help videos on that model and sell repair kits as well as the whole board.
Posted on Jun 21, 2008
Hello Sir, I am using DELL E173FP LCD monitor. My CPU absolutely fine I see initially booting thing on my monitor display then it gets black. I can hear starting sound of Windows XP, that too is fine. When...
You might need to change the screen refresh rate. Go do Control Panel> Display> Setting> Advance, choose 60 Hz. In order to make your Monitor able to display, restart the PC, press F8 on the keyboard frequently upon splashing ( 1 or 2 seconds after PC restarts). Select enable VGA mode by pressing up arrow of the keyboard> press enter. The display should look bigger, then you can start adjusting the screen refresh rate to 60 Hz
Apr 09, 2010 | Dell E173FP 17" LCD Monitor
Monitor screen goes blank at intervals. If I turn
You may have to open it up and look for bad soderling works, see my pictures to see what bad solderign joints look like. Also check fuses, connectors, etc.
See what goes wrong with Dell monitors here:
http://s807.photobucket.com/home/budm/allalbums
I assumed that it does the same with other PC also.
Apr 05, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
When you turn it on, you will see a picture for about 1 second, then it goes blank
try self test on the screen to do that unplug the blue cable from the tower and turn on the monitor and if you could see 3 or 4 bars then the monitor is ok if not then you need to replace the monitor if it passes the self test then try to boot in bios and see if it comes on if yes then its your windows issue try system restore
Jun 26, 2009 | Dell E173FP 17" LCD Monitor
Dell F1703 17 in. Flat Panel... Problem
There may be problem of heating the inside components. see him to expert.
Mar 03, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP: Screen Washes out
not a happy machine...
1. Check in systems manager, device manager, to see that the monitor is clean, with no ? mark or ! point.
2. Reinstall drivers..
3. check all connections to monitor for fit. Unplug and check the connectors for grit or crud.
4. Get a new monitor.
Got backup?
Feb 10, 2008 | Dell E173FP 17" LCD Monitor
Screen goes blank when I move the mouse
please be specific, your question is not understood properly??
Oct 26, 2007 | Dell E173FP 17" LCD Monitor
Monitor blackout thought green powerlights on
When your dell e173fp lcd monitor black out, the led power light are still green color. Normally, this will be the inverter board or ccfl lamp problem. May i know, after this monitor black out, do you have try use the torch light to see any display on the screen? (sometime the display are darkness only and not totally no display, you need see it clearly). Any details on repair lcd monitor please goto this website, http://www.fastrepairguide.com
Sep 01, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP
HI Jamil , I'm french technician and I solve this problem yesterday .
For your problem yo cans change capacitor C6 , C26 220uF 25V 105°(105° is important for longer life of you'r screen).see this vue
Jan 24, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP - After sometime the screen switches off
Sorry not a solution - but I have started experiencing the exact same problem over the last month although sometimes, on switching on again, it will run for 10-15 minutes before the problem re-emerges. Initially I put it down to the v. hot weather in July but it still continues. So I would also appreciate any solutions!
Aug 06, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
692 people viewed this question
Alun Cox
