Question about Vector VEC043 750-Watt Power Supply
Vec1024 Hi, I have a vec1024 that is not working. When I plug it into the DC car terminal, the yellow light comes on and it makes a solid beeping noise. Any idea what could be wrong? Randy
  • Laven205 Jul 23, 2008
    same model, same problem: When you plug it in, the yellow light comes on and it makes a solid beeping noise.
  • 144 Answers
Dear
Please check the owner's manual you must have got alongwiththe product. Check under the "Troubleshooting" Section. That can solve the problem..
Posted on Jun 22, 2008
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
Apr 24, 2014 | Shoprider Health & Beauty
Phoenix 3 battery charge idicator
Hi, is it possible for a picture of this ??? the reason being they used two diif versions so I want to be sure...
By the way you say you changed the batteries but what about the charger, are you 100% sure that working okay as in charging the batteries to a ideal voltage level around 27.5 DC ,max voltage should no more than 28.2 volts DC, this will give you a 100% usage of the batteries in question...
Regards
Rob
www.gewizrepairs.co.uk
Feb 01, 2014 | Drive Medical Phoenix 3 Wheel Compact...
I have a verbatim 320GB externam hard drive the model is CLON320GB. One day it just stopped registering on the computer. At first it woulod make a constant beeping noise when I plugged it in but would not...
From the information provided, it appears to be a direct hardware failure. Verbatim appears to not offer much on providing information on such issues, so it would be safe to say is have it replaced.. I am not 100% sure but some external drives come with a 7 year warranty, you could also try to have your data recovered from a local computer service in your area so you do not lose the data. But, in all it would be advised to replace it.
Jul 13, 2011 | Verbatim 96823 320 GB USB Portable (Blue)...
I have a 1999 Beetle and When I'm driving My dash beeps like 10 beeps in a row and the inside lights come on but nothing so up on the dash to tell me the problem
Ok, so are you saying NO LIGHTS come on to tell you what issue is on the dash? The beeping you hear is a low oil pressure warning beep. Its telling you that you are either low on oil or that the oil pump is not delivering oil properly to the motor (car is sensing low oil pressure but on these cars there is no oil pressure gauge on dash to look at). Check your oil level and make sure you are not low. Best time is in morning on flat surface start car and let run 5 minutes. Stop car, let sit 5 minutes and then pull dipstick and check level. Also make sure you are using the correct oil and viscosity for this motor. VW's require VW certified oil and a certain viscosity. You can go to www.mobil1.com to find the correct oil available in the states for your vehicle. Too thin or too thick a viscosity could cause similar issue. Otherwise please clarify the light comment as I have never heard of the lights coming on automatically after a beeping noise and I will research.
Jun 05, 2010 | Volkswagen New Beetle Cars & Trucks
Laptop will not turn on and when you plug in the
You may have a DC Jack issue and needs to be replaced. Common with Acer models using the yellow DC jacks.
And since the battery will not charge, it is most likely a component issue. Shorted MOSFET in the charge section.
May 02, 2010 | Acer Aspire 5500 5570-2609 Laptop
Why isn't my ps3 not working. I plugged it into my HDTV in my living room, then plugged it into my normal TV and now it's not working?
You need to reset the A/V out settings.
Have your PS3 in standby mode (solid red light). Press and hold the power button, you will hear one beep (power on), then you will hear another beep (reset). Release the button at this point and the video should reset and work on your standard TV using the red/white/yellow RCA cord.
Thank you!
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
Overloaded my inverter -now only works when hooked to car battery
It sounds like the fuse that protects you cigarette lighter is blown.
After you have replaced the fuse, check the voltage again. 0.015vdc would not have powered anything that in manufactured to operate on 12vdc.
When powering anything over about 250W, I would suggest connecting directly to the battery to avoid overloading the lighter circuit.
Nov 07, 2009 | Vector VEC1024 400 Watt Power Inverter
Solid amber power light
Your Monitor is not connected properly
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Connecting Your Monitor
1. Turn off your computer and unplug the power cord.
2. Connect the white connector end of the DVI cable attached on the monitor to the connectors on the computer.
3. Connect the USB cable that was included with your monitor to the computer and the upstream USB connector on the monitor. Once this cable is connected to the computer and the monitor, you can use the USB downstream on the monitor.
4. Connect any USB devices.
5. Connect the power cord.
6. Turn on your monitor and computer. If you do not see an image, see Troubleshooting Your Monitor.
NOTE: The Monitor will display full screen in White, Black, Red, Green and Blue color rolling pattern on screen if the DVI cable is not connected. This self test pattern will be displayed continually when Monitor detects that DVI cable from Monitor to PC is not connected.
* Check connection integrity at both ends of the video cable.
* Ensure the monitor and computer are plugged in to a working electrical outlet.
* Ensure power button is depressed fully.
Aug 14, 2008 | Computers & Internet
System does not start
The beeps are error codes and if you listen carfully you will hear a pattern of short and long beeps. If you can identify the pattern we can help you figure out whats going on....
Feb 14, 2007 | Dell OptiPlex GX110 PC Desktop
Try pressing F2 or Del to get into bios and see if the system time and date are correct. if not the cmos disc shaped battery found on the motherboard may need replacing. You can also reset the bios by locating the 'JBAT1' terminal on the mobo and put the jumper cap from pins1-2 to pins 2-3 for a few seconds, then back across pins 1-2 again, and reset time and date next time you boot up the pc. Although, i recon the continues beep noise can refer to a processor fault but trying the above is the cheaper first step to take, good Luck
Vector VEC043 750-Watt Power Supply Logo
202 people viewed this question
Top Vector Computers & Internet Experts
Jonathon summesfield
janman
Are you a Vector Computer and Internet Expert? Answer questions, earn points and help others
