Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
Asus motherboard M2N-E will not power up
I just put together a new PC consisting of
Asus M2N-E motherboard
AMD Athon Dual Core processor
500W power supply
IDE harddrive
3 gigs RAM
ATI PCI Express Video Card
When I connected all the powersw, resetsw, etc..., the motherboard bulb lights up. I press the power button, and the case fan and the process fan only goes on for about 10 sec and stops. I tried the same connection on my old Asus motherboard and everything works...
I tried a 750 W powersupply, same results
a new motherboard, same results
I noticed that this motherboard is built more for the SATA device, but I have not install a SATA HD yet..
I am hestitate to think that it is the processor..but I am assuming that it may have went bad....
Any help is greatly appreciated to get it powerup and see the video of the ASUS logo on the monitor.
Thanks,
CR
  • 4 more comments
  • comicrage Jun 12, 2008
    I removed the RAM and place only the 2GB in the black slot to the far right. I line up the ram to fit and press down. The clips on both ends pop up and snap the RAM in. The motherboard still will not power up correctly.
    I disconnect the IDE harddrive, but no video. the motherboard, cpu fan and case fan only comes on for about 5 seconds and turns off....
    sweet_rascal,
    I said something about placing the screws down on the motherboard to fasten it to the case. I added all the mounting screws on the metal case. Then I place the motherboard on top of these mounting screws and added new screws to fasten them to the mounting points. You said that I may be shorting something out... Should I remove all the screws and try to powerup with only the processor? What should I look for which may cause a short?
    I just removed all the screws and laid the motherboard on top of the antistatic cover with only the processor..
    The only powers up for a few sec..
    do you think it may be the processor?
    I checked the processor and remount it. I placed the fan on top.
    The motherboard still will not power up or any video signal..
    Anything else to try
  • comicrage Jun 13, 2008
    I was able to get the MB to power up, but I can't see the video signal. It should the bios booting up and the video signal disapear. I tried rebooting, but there is not video signal. Any idea?
    Genius:
  • 1,142 Answers
Try to turn on without connecting the hdd sata and see what happens it should give you the display atleast.
Posted on Jun 12, 2008
    Guru:
  • 1,894 Answers
Did u put the RAM properly?
  • 6 more comments
  • dewan nafees ahmed Jun 12, 2008
    i think you could have made some silly mistake.
    it can be this way. (bcz it was my previous experience)
    usually mother boards rest on cabinet in special type of screws.
    like.
    u screw in a base screw and then keep mother board above it and then put another screw to fit the board between them.
    while installing the new mother board u may have missed removing any one old screw or some old item.
    this is shorting the board somewhere which prevents the board from booting.
    u mentioned about SATA stuff.
    there is nothing to do with sata stuff at this stage.
    because the system and show the bios screen alone at this stage.
    when the bios itself does not load u need not worry about sata.
    make sure that u are not shorting the mother board anywhere.
    this can be a prime reason.,
    dont put the rams and hard disks.
    just boot the board with processor.
    if u dont get started its not the faulty power supply.
    i am sure that u are shorting somewhere.
    u need to look out
    yes.
    then sure short that there is some problem in assembly.
    do this way.
    remove the board from the cabinet.
    then place the board alone with the processor in some cushion or something.
    now connect all wires. now boot up.
    if u find same problem tell me.
    yes
    maanita is also correct.
    make sure if u had applied heat sink properly over the processor.
    below the fan it comes pre applied
    nope it wont be the processor.
    because if it is the processor it wold be the last option.
    u need to try different try before arriving at that.
    did u ensure about the heat sink paste we said?
    the paste is also a critical item to be noted.
    if there is any air space the processor heats up very soon and so it shuts due to thermal protection.
    dont forget to accept the solution if u go by it.
    thank you
Support processor for upgrade to higher processor
This are the comptible processor that you can use for this motherboard if you plan to do a upgrade on it. AMD Athlon 64, AMD Sempron, AMD Athlon 64 FX, AMD Athlon 64 X2
Here is a link that contain all the details about this motherboard.
http://www.dealtime.com/xPF-ASUS-Asus-M2N-MX
Aug 04, 2010 | ASUS M2N-MX Motherboard
CPU Upgrade
Hi there.
Here is a list of processors that board will support >>>>>
http://www.cpu-upgrade.com/mb-ASUS/M2A-VM.html
Good luck and thanks for choosing FixYa!!
May 27, 2009 | ASUSTeK M2A-VM HDMI Desktop Board - Athlon...
Iam useing asus M2N-MXSE PLUS Motherboard with AMD Athlon x2 Processor but now i want to change my processor with replaying it whih Intel core 2 duo. is that mother board support it or not. pc for...
Your motherboard is for a AMD processor not Intel. You need a motherboard for a Intel processor before you can proceed.They are so different. Core Duo chips don't even use pins.
Dec 20, 2008 | Intel Biostar P4TSE-D2 865 Chipset...
It could be a memory card too. I would start by pulling the memory cards and see what happens.
Is there a connection on the motherboard for your hard drive?
Jun 12, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
No Output to monitor, no beeps, fans all OK
Hi karanda,
The green led on the board shows green letting you know there is power to the borad.
Does your GFX card have dual outputs? Try plugging into the other output.
If your monitor light goes from green to amber than your PCI-E is not putting out signal. Pull & re-seat video card.
Did you check Asus to see if your CPU is supported & check what bios version you may need to run CPU?
Chcek here: Check what your M2M-E supports.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
Your board only supports these two CPU's
Phenom 9500 (HD9500WCJ4BGD),2.2GHz,95W,SocketAM2+,Quad-Core
Phenom 9600 (HD9600WCJ4BGD),2.3GHz,95W,SocketAM2+,Quad-Core
You need Bios version 0802 in order to run the above CPU's.
Good Luck & kind regards!
Mar 10, 2008 | ASUS M2N-E Motherboard
Compatibility
A8V-MXs are built for AMD processors. You will need a board made for Intel processors if you want to purchase the above processor. If you want to stick with Intel and Asus check out the P5 series of boards. If not, buy an AMD chip...I've had AMD in almost every one of my computers, laptops and desktops.
Good luck.
Dec 20, 2007 | ASUS A8V-MX Motherboard
AMD Athlon 64x2 can't install, help!
which version update did you do?
only after 0804 will work
FAQ from ASUS
My system may refuse to boot under AMD Althon64 x2 6000+ CPU (OPN :ADX6000IAA6CZ) with 2x DDRII-800 memory combination.
The same problem does not happen with other CPUs, nor would it happen with memory modules of any lower specifications.
How can I solve this problem?
Please kindly update motherboard BIOS to version 0406 or later to resolve this problem.
BIOS 0406 can be downloaded form the link below:
ftp://ftp.asus.com.tw/pub/ASUS/mb/socketAM2/M2N-MX%20SE/M2N-MX-ASUS-SE-0406.rar
Dec 02, 2007 | ASUS M2N-MX Motherboard
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
114 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
