Question about Acer Computers & Internet
Laptop display is going off intermittently. - Acer Computers & Internet
  • 129 Answers
Back light inverter.What is the model?
Posted on Nov 02, 2010
HDMI from new laptop is causing intermittent flickering.
i would suggest a different refresh rate. should be in display properties.
Jun 17, 2015 | Sharp Televison & Video
Monitor
The cable between the motherboard and display brobably is routed through the hinge and has become damaged
Mar 17, 2014 | Lenovo G570-4334 -24828
Monitor 1707fpt
I would suggest you try this to fix your problem. Go to Control Panel from the start menu if you are using Windows 7 and Windows Vista. Click on the Display Setting and adjust the screen resolution to the recommended Screen resolution. On the Display Setting at the top of the you should see number 1 and 2 with a large box ,on the right side of these boxes there is a menu that you can click on, these menu are {Detect and Identify} click on Detect first and then Identify. I hope this solves your problem.
Jan 05, 2014 | Dell Computers & Internet
Why do i have an intermittent problem with my laptop freezing up during startup? startup?
You may have a bug. You may start by going to control panel and see how many programs are trying to start up at the same time. When my laptop does that I normally go to the control panel and stop programs and keep them from turning on at start up. you really dont need all programs to start up at the same time. This may cause freezing and longer times to start at start up.
Dec 31, 2011 | Toshiba Satellite A665-S6086 Laptop
My hp pavillion tx2000 laptop do power on bt doesnt display. it sometimes displayed bt not displaying any longer.pls what can i do.the syst. is touchscreen.
I think it would be better if you're going to isolate the problem on your machine. I believe the machine intermittently having a display problem. Try going to this link and follow the steps on how you can resolved the problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00828604&lc=en&dlc=en&cc=us&product=3658348
Hope it helps.
AnEspera
Apr 28, 2011 | HP Tablets & eReaders
Inspiron Core i5 Laptop. Error: Display driver stopped responding
Hi there!
You mentioned that's a 2 month old laptop,
From what i'm seeing here you should at least have 1 year of warranty with it if you purchased it online,
For the issue you have there,
Might want to specify what video card you have there.
For the drivers, go to support.dell.com then enter your service tag, make sure your select the right operating system, then you'll be able to see the drivers, update the video card driver and the BIOS,
If the problem persist go to nvidia and check your video card if they have released a new driver update,
Worst case scenario is replacing the video card.
Hope this helps!
May 27, 2010 | Dell Computers & Internet
No heat coming out fan blows but no heat
there's a blend door actuator behind the dash. they are going bad all the times. however, check your coolant level first.
Feb 28, 2010 | 1996 Lincoln Town Car
Screen problems
Hi:
The next time your laptop screen is messing up, try to hook the laptop up to an external monitor. If the picture is bad on the monitor too, you have a laptop video card issue. If the picture is good on the external monitor, then you have a problem with your laptop LCD/ inverter.
Nov 11, 2009 | Dell Computers & Internet
Sony vaio vgn nr160e laptop - no display (intermittent). Attached monitor shows display fine and laptop works fine. Screen used to flicker intermittently (last few days).
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 20, 2009 | Sony VAIO VGN-NR160ET Notebook
Dell Vostro 1710 display problem
Hello My Dell Vostro Laptop Display Not Working Correctly it showing Dim but in other desktop when i connect to the Laptop Of Mine it showing Correctly With No Dim Problems? How can I fix the Problem?
Nov 19, 2008 | Dell Vostro 1500 Notebook
Computers & Internet Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
