Question about APC Smart-UPS 1500VA Shipboard (SUA1500X93) UPS System
Get 2 messageges constantly: server01 : Insufficient Runtime Available on Agent server01 PowerChute Business Edition has detected the following event: Insufficient Runtime Available on Agent server01 server01 : Communication Lost on Agent server01 PowerChute Business Edition has detected the following event: Communication Lost on Agent server01 What's wromg?
3 Suggested Answers
SOURCE: insufficient Runtime Available on Agent
If the UPS display is indicating runtime at 6 mins, and software is saying insufficient, seems like a communications issue. I'd try downloading the latest communication software for the UPS and reseating the communications cable at both ends, making sure no bent pins, etc. could be causing a comm glitch.
Posted on Jun 30, 2009
jvpacoin
  • 91 Answers
SOURCE: insufficient runtime available on agent
Try to do a runtime calibration using your powerchute software or SNMP agent. Check what is the runtime there, or check the runtime setting of your Powerchute software, maybe it set to more than the actual runtime of the UPS.
Posted on Aug 14, 2009
Can a Box Switch Record Logs and Alarms After a Loop Detection-enabled Interface Detects a Loop?
A fixed switch (such as S2309TP-EI-DC) can record alarms but not logs after a loop detection-enabled interface detects a loop. The configurations are as follows:
In V100R005 and V100R006, you can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection. If snmp-agent trap enable has been configured globally, the alarm function has been enabled.
Loop detection and loopback detection have been available since V200R001. You can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection and run the snmp-agent trap enable feature-name lbdt command to enable the alarm function for loopback detection.
You can run the display trapbuffer command to view alarms.
Jul 18, 2016 | Computers & Internet
How to monitor Matrix 5000 UPS via email?
Try using use the agent and server of the Powerchute plus and the console of powerchute business edition run from another PC.
You may need version 9 or later of PBE.
Jul 29, 2014 | APC Matrix-UPS 5000 UPS System
Runtime upgrade
According to Intuit most of QuickBook Runtime error resolved by restarting a computer so go for this and if still face the same issue then try to contact intuit official support follow http://support.quickbooks.intuit.com/Support/. if need any guidance for any technical specification follow Intuit Customer Service.
Mar 03, 2014 | Intuit QuickBooks Pro 2007 Full Version...
I need a program for my computer run a ups es 350
Powerchute personal edition is available for free download from APC. Does your ups have a USB port? The software is useless without it.
Nov 21, 2013 | APC Computers & Internet
APC 1100CI-IN UPS NOT EORING ON GENERETOR WHAT I DO? PLZ SEND SULATION E-MAIL singhpintu987@gmail.com
Hello Sing,
There is a possibility that your UPS doesn't like the voltage or frequency that the generator is feeding it. As per an APC knowledgebase article, the size of a generator should be 3 to 5 times higher that the total Watt/VA load that it would be supporting.
There are also instances wherein the sensitivity threshold of an APC BackUPS is set too high that a slight change in voltage/sensitivity would cause the unit to switch from online to on battery too frequently. This can be addressed by lowering the sensitivity either by their APC PowerChute Personal Edition Software or via the front panel switch.
If you are going to do it via the software, it needs to be installed on your computer. Prior to downloading it, make sure that your operating system is compatible with it. Suppose that your operating system is compatible, once the program is installed you will need to open it up and look for the Sensitivity option and from there you could select Low, Medium or High.
If you are going to do it via the front panel switch/button the UPS should then be turned off but plugged in to an input source. Press and hold the On button until you see that the LEDs are flashing. Once the LED is flashing, press the button again to set the desired sensitivity. Low sensitivity would show the On Battery LED flashing. Medium is On Battery and Overload LED while High is On Battery, Overload and Replace Battery LED flashing. If you'll see a flashing Online LED it means that you are cancelling or exiting the program mode of the UPS.
Below are some helpful links from APC
*** You will need to login in APC before you can download the software. Choose the correct PowerChute Personal Edition Compatible with your OS and create an account online.
Jul 22, 2011 | APC Back-UPS CS 500VA UPS System
Jun 25, 2009 | APC Smart-UPS 1500VA Shipboard...
Insufficient runtime available on agent
Jun 05, 2009 | APC Smart-UPS 1500VA Shipboard...
Desktop runtime error
You need to call the maker of your computer. There is something wrong with the Motherboard of your computer or the hard drive. Call the maker of your computer this would be HP, Acer, Dell, Gateway, or any other maker. Their tech support team will help you. If you have HP go to www.hp.com and speak with a live agent, it helps to avoid a 50 dollar diagnostic fee.
Apr 05, 2009 | Microsoft Windows XP Home Edition
APC Smart-UPS 1500VA Shipboard (SUA1500X93) UPS System Logo
742 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
