Question about NEC AccuSync LCD22WMGX LCD Monitor
Monitor powers up and i get a no signal message but none of the buttons on the bottom will work so I cannot change the input format, adjust sound, or enter or exit menu
No vga input on working monitor
Turned on computer (Pavilion a1657c), HD light operates, Monitor has little window saying:
HDMI Input: No Input Signal
VGA Input: No Input Signal
Recommended Settings: 1920x1080 - 60hz
Changed from the monitor that came with it (HP f2105 digital ouyput) to my Samsung analog and same message comes on dark screen.
Hope It's resolve all Your Computer Problem,
Or
Still having Problem Then follow Us For Computer Support
Mar 21, 2014 | HP Media Center m7657c home PC - RC640AAR...
I have a samsung syncmaster 930b attached to an HP Pavilion Slimline s5660f Desktop PC, plugged into the DVI port of the PC. However, I cannot get the monitor to come up. There is power to it. I get the...
from user manual troubleshooting section
(When connecting D-Sub cable) Check the signal cable connection. (When connecting DVI cable) If you still see an error message on the screen when the monitor is connected properly, check to see if the monitor status is set to analog. Press Source button to have the monitor double-check the input signal source.
Source button Activates a highlighted menu item.
/ Push the 'SOURCE', then selects the video signal while the OSD is off. (When the source button is pressed to change the input mode, a message appears in the center of the screen displaying the current mode -- analog or digital input signal.) Note : If you select the digital mode, you must connect your monitor to the graphic card's port using the DVI cable.
https://images10.newegg.com/User-Manual/User_Manual_24-001-063.pdf ninth page in user manual
source button fourth from the left when facing monitor. looks like a box with an arrow pointing left.
Mar 05, 2018 | Samsung SyncMaster 930B 19" LCD Flat Panel...
The monitor is black with a error message :input signal out of range We are connected to a Mac Mini This problem seemed to happen after the monitor was accidently disconnected and then when it was...
Can you please get me the make and model of the monitor? Also did you check to see if the refresh rate of the monitor matches with that of the mac mini?
Nov 21, 2010 | Hannspree Computers & Internet
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Monitor issue
Just sounds like the monitor cable is loose or bad or the input mode on the monitor is set wrong - set it to auto or step through the modes.
Aug 10, 2009 | Envision H191W Monitor
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
The screen will not come up but gave this message 'No input signal, go to power save
To isolate the problem, you need a friend with another computer since right now, we don't really know if the video section (or card) of the PC is at fault or the monitor.
You need to swap displays with someone so you can be certain what is actually not working.
The monitor is obviously capable of scanning inputs for a signal and not finding one.
Oct 26, 2008 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
Onscreen controls don't respond
You have five buttons at thee right-hand bottom of your screen (just under thee edge). They are (from
left to right) the Main Menu button, the Down button, the Up button, the Input button and the Power
button (under the light).
To adjust your screen press the main menu button. Once the main menu screen is up, toggle
through it using the Up/Down buttons. Once you see what you want to adjust, move over to the
right side of the menu by pressing the Input button. Now use your Up/Down buttons to highlight
what you want to change. Once it is highlighted, press the "Input" button again. Now use the
Up/Down buttons to adjust your settings.
Once you have adjusted the settings, simply press the main menu button to exit.
Sep 10, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
NEC AccuSync LCD22WMGX LCD Monitor Logo
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
