Question about IBM Infoprint 1512 Laser Printer
IBM Infoprint 1512 out of paper message
Our IBM Infoprint 1512 is not printing. I keep getting an 'out of paper' message even though there is plenty of paper. Our other printers are printing just fine. I tried to feed it manually and it started up as if it would print, then stopped and the same out of paper message came up.
I appreciate you help!
Thanks
Lisa
  • IBM Master
  • 2,794 Answers
It could be a problem with the paper feed roller above the tray or a sensor problem.
It should be looked at by a service technician.
Posted on Jun 12, 2008
I have a IBM Infoprint 1512 and on the display it says to replace photocon but it is printing fine. What is the problem?
Those photoconductors have a limited life and have to be replaced. The message is warning that it is near the end of its life and wants you to have one ready when it goes out. Most printers will prevent you from printing when it reaches the end of the service life, some will let you continue to print but you will get reduced image quality. Either way, you'll need a new one soon.
Feb 03, 2011 | IBM Infoprint 1512 Laser Printer
How reset photoconductor ibm infoprint ibm1512 thank you
The instructions for IBM Infoprint 1412/1512 printer's photoconductor is the same as the Lexmark E342.
The instructions are located here: http://support.lexmark.com/index?page=content&id=HO2564&locale=en&userlocale=EN_US
Recap of Instructions:
To Reset Photoconductor page count:
1. Turn off printer
2. Press and hold the Select and Return buttons at the same time on the panel and turn the printer on (continue holding down buttons until printer screen displays "Performing Self Test" or "CONFIG MENU").
3. If "Reset PC Cnt" does not appear on screen, press the left or right menu button until it appears.
4. Press "Select" and the message "Resettting PC Cnt Value" should briefly appear indicating the page count is reset.
5. Turn off printer when "CONFIG MENU" appears again.
6. Wait 5 or more seconds and turn back on. Done.
7. It is suggested to check and verify that the PC Count is reset by printing a menu setting page:
a. Press left or right menu buttons until you see "Utilities Menu" and press "Select".
b. Press left or right menu button until you see "Print Menus" and press "Select".
c. This should print out the information. Look for "Cartridge Info" and the word "Photoconductor". It should indicate "OK" or close to 100%.
d. If not showing "OK", print 10-20 pages and Print Menu again to check. If still not, reset PC again and check again.
Jan 13, 2011 | IBM Infoprint 1512 Laser Printer
Infoprint 1512 prints blanks from int. and ext. print source
How to get on software to setup for printer , infoprinter 1512 ( Ibm ) .
tha for kind wondows ( wondows vista )
Aug 14, 2009 | IBM Infoprint 1512 Laser Printer
IBM Infoprint 1532
There is probably a small piece of paper in the back of the printer in the fuser. Shutdown the printer and wait a few minutes as this part is hot. You may need to remove a few screws to take off the back cover and check inside the fuser.
Jun 03, 2009 | IBM Infoprint 1532 Laser Printer
IBM InfoPrint 1612 Repeatedly erroring - Paper Jam
Check the FUSER, I think your exit sensor is bad.
If you open the rear door, look inside where the paper starts to come out of the printer, you should see a small lever that triggers the PAPER EXIT sensor. It might be hard to see. If it is not broken, you need a new FUSER.
Mar 18, 2009 | IBM Infoprint 1612 Laser Printer
IBM Infoprint 1532 Tray Selection
For tray linking to work, both Paper Size AND Paper type must be configured the same for both trays. You probably have the paper sizes the same but types could be different. The is no setting to make tray linking work.. it will do it automatically if the above settings are correct.
Feb 24, 2009 | IBM Infoprint 1532 Laser Printer
How to refill printer ibm laserjet infoprint 1512
If you mean you need to refill the toner for this printer, i would not attempt to do it yourself. Seek out a reputable remanufacturer or supplier of the toner cartridge
Nov 14, 2008 | IBM Infoprint 1512 Laser Printer
IBM infoprint 1422 won't feed through paper tray, only works with mp loader
Ok.... I have these printers at work...and i think i have figured this one out :
Under setup menu , goto configure mp , then switch the settings from cassette to manual. You see these printers are used at Hotels where the bottom tray is for legal size paper used to make key packets and the mp is used for regular sized paper printing reciepts....Hilton family hotels use them for example....the next thing I'm trying to figure out is how to set it so I won't have to push the go button every time I print something
Oct 22, 2008 | IBM Infoprint 1422 Laser Printer
IBM Infoprint 1512 Laser Printer Logo
229 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
