Question about Sharp R-1480 Microwave Oven
Microwave door latch
I saw that you commented on the problem with the door latch/spring being broken off. If you want to save money and have the problem fixed, you can make a hook out of something that is hard plastic, and glue it back where the original hook was. I used a piece of plastic from a old floppy disk holder, and then just cut/broke it into a hook shape. You can then get a tube of epoxy for about 5 dollars, mix it up and glue your hook into place. If you let that sit for a day or two, and reinstall the door you'll be good as new !
MicrowaveSvc
  • 9047 Answers
SOURCE: Broken door latch
The latch head (the part you describe) is ref # 5-7 in the parts list and is part # LSTPPA169WRF0 (that's a zero on the end, not an "oh") You can get it from Tritronics at http://www.wehaveparts.com We have the entire service manual on our site: http://www.microwavedisplay.com/r930ak_aw_sm.pdf I appreicate your rating. Good luck!
Posted on Feb 10, 2007
  • 619 Answers
SOURCE: Sharp Microwave model R-1850A door won't open
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
Posted on Jan 14, 2008
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Microwavesvc, that's what I've had happen with my sharp also, I carved a hook out of a piece of plastic and then epoxied it in, and haven't had any more problems with that.
Another problem I've had with the sharp (that just reoccured, I'm trying to figure it out) is that the micro-switches that the door latch push have gone bad. Originally just one went bad and I replaced it, now the micro has the light and fan on, and won't recognize being closed...
Posted on Jun 11, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: door latch on sharp 1480 microwave over the range oven
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have the service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
Normally you have to separate the door panels (as shown in the manual) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order Sharp parts is Tritronics.
Posted on Aug 09, 2008
SOURCE: Broken latch microwave door - won't open
I have a semmins microwave working in great condition, last night the latch mechanism inside the microwave don't allow the door latch to close.Only the top portion, bottom portion is ok.
Posted on Dec 07, 2008
How to repair kitchen aid door springs
proceed according and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Nov 01, 2013 | KitchenAid Microwave Ovens
I'm unable to open the microwave door on model Sanyo EM-S8586W as it appears the spring is broken. How do I remove the cover so I can replace the spring please?
make this steps and fix it. God bless you
Oct 26, 2013 | Sanyo Microwave Ovens
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Door doesn't latch
Can you move the latch in the door? This is spring loaded, maybe the spring is broken
Mar 09, 2013 | Maytag MMV1153A Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
I have a frigidaire model fmv156dbf and the door latch will no longer operate. when i opened up the door i saw that the spring that is supposed to operate the latch was no longer attached. where the spring...
We have the service manual and have uploaded it to our site here to help you.
You can order parts here if needed.
May 26, 2010 | Frigidaire Microwave Microwave Oven
Microwave broken door latch
The door latch head (hook) is pretty easy to replace or repair if that's the issue.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Sep 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
MIcrowave
check the door latches inside the oven, open the housing and spray some lubricants on the latches.
Feb 21, 2008 | Frigidaire FMV145K Microwave Oven
Microwave door doesn't shut
I answered this personally via e-mail (and I do not mind peopke writing me personally). I think you may have a broken tab which holds the door latch head spring in place.
Oct 19, 2006 | Sharp R-1481B Microwave Oven
Sharp R-1480 Microwave Oven Logo
128 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
