Question about Kyocera FS-3900DN Laser Printer
New maintenance kit
I have fitted a new maintenance kit but can not get the install mk message to reset. How do i reset it and get the message to disappear?
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Hi Did you run up the developer unit? Menu button down to Other then to Service and press enter on developer and switch off and turn on will run for a while. In the service menu after you run up the dev unit you may have a option in there to press enter on the MK Symbol.
Posted on Jun 27, 2008
Install MK Kit Kyocera FS-9130 How to reset MK Kit Counter
you can reset the counter but on the falcon engines if you go past the maint. cycle they will eventually fall down and print solid black copies.
Feb 04, 2016 | Kyocera Office Equipment & Supplies
How do I get rid of 'Install MK' message?
Missed something, Part of the maintenance kit is the developer and also the drum unit, you will need to change the 1/8th amp fuse in the developer assembly, and also the chip inside the drum unit.
Farnell stock both, the fuses are p/n: 446-816 and the serial eeprom chip is p/n: 690-650
This isnt the exact chip that kyocera use as they use a 93LC56B, but the ones that i have fitted before are 93C46 -these seem to work just the same.
Hope this helps.
Jun 02, 2015 | Kyocera FS-1135MFP
Kyocera FS1370 reset
Press Menu button, then press the up arrow until you find the Adjust/Maintenance. Press the right arrow and search with the up arrow the Service choice. Then press the right button and search with the up or down arrow for Maintenance. Press the OK twice and the Install MK will disappear.
Mar 26, 2014 | Kyocera FS1370DN Laser Printer
Kyocera FS-4000DN is showing install MK; Can the problem be fix without buying a Maintence Kit for $532?
> without buying a Maintenance Kit ?
Either you buy the kit, or you sell the printer "as is" on eBay, after buying a new printer.
Jan 19, 2011 | Kyocera FS-4000DN Laser Printer
HP laserjet 3600 error message 50.9 Fuser Error
Thank you for the inquiry.
Yes you will probably have to replace the fuser. If this is a new printer still under warranty and the page count has not reached the service life of the fuser, contact HP for warranty replacement. Once the new fuser in installed you will need to restore the service count.
Fuser Kit Part Number: (Sometimes Called a Maintenance Kit)
RM1-2665 This fuser is compatible with the following printers: HP Color LaserJet 2700, 3000, 3000N, 3000DN, 3000DTN, 3600, 3600N, 3600DN,
Link to Installation pictures and instructions:
Restoring the maintenance count after installing new fuser.
This printer tracks the number of pages printed on the fuser, and a reminder message will appear when the fuser reaches a certain page count. The message will instruct you to replace your fuser. Whenever you install a new fuser, you should reset the fuser page count so the warning message will not appear prematurely.
To reset the fuser count :
1. Press MENU to enter the MENUS.
2. Press Down arrow to highlight Configure Device.
3. Press Checkmark to select Configure Device.
4. Press Down arrow to highlight RESETS.
5. Press Checkmark to select RESETS.
6. Press Down arrow to highlight RESET SUPPLIES.
7. Press Checkmark to select RESET SUPPLIES.
8. Press Down arrow to highlight NEW FUSER KIT.
9. Press Down arrow to select NEW FUSER KIT.
10. Press Down arrow to highlight YES.
11. Press Checkmark to select YES.
The fuser count will be reset and then the printer is ready to use.
Thank you for being a FixYa Valued Customer.
Hope this helps helps. Please keep us updated and remember to rate this answer.
Jan 19, 2011 | HP LaserJet 3600 Printer
Printer is asking us to 'install MK 700' What
It is telling you that it needs a Maintenance Kit fitted.These are fitted every 500,000 A4 pages.
Nov 22, 2010 | Kyocera Mita FS 9100DN Laser Printer
KYOCERA fs-1920 Has the message instal MK coming up? Dopes this mean order a maintenance kit?
It means the page count has triggered this message.
You _should_ get a maintenance kit.
But if you simply can't take the time/money, you'll find a new menu item in the menus after service. the new item is 'maintenance', get to there and press enter. (May need to press enter twice), the menu item, flashing light, and install MK message will all disappear.
Sep 08, 2010 | Kyocera Office Equipment & Supplies
We have a Kyocera FS3830N - message install MK -
MK is the maintenance kit. You can check the Kyocera site to find out where to get a new kit and how much they are:
Most of the time the message is just displayed because the machine has reached a certain number of pages, but it should still let you use it normally.
May 27, 2010 | Kyocera Mita FS-3830N Laser Printer
Install MK? What does this mean?
Its because you've gone past a certain number of pages printed.
Its asking you to install a new Media Kit
To reset the message -
1 Press the MENU key.
2 Press the or key repeatedly until Life Counters > appears.
3 Press the > key.
4 Press the or key repeatedly until >New Toner Installed. appears
5 Press the ENTER key. A question mark (?) appears.
6 Press the ENTER key.
The toner counter is reset. The message display returns to Ready.
Mar 01, 2010 | Kyocera FS-3830N Laser Printer
Message stating install MK
You have done more than 300,000 pages. I wouldnt waste your money on a Maint Kit, just stretch it out by doing the following.
Press Menu/Ok (Main menu)
Go into [>>Service]
Then press the right arrow.
Then find [>> Maintenance]
Press the ok key, then it will show [>> Maintenance?]
Press the ok key twice, and it will reset all the counts on your consumable components (Drum, Developer, Transfer Roller, ETC)
Oct 07, 2009 | Kyocera Copystar CS-1620 Black and White...
Kyocera FS-3900DN Laser Printer Logo
2,756 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
