Question about JVC GR-FXM40EK Camcorder
Gr-fxm40 wont play back
I have a problem with playing back a recording its just a blue screen and it wont fast forward or anything I have recharched the battery but nothing seems to be working it recorded but it wont play back
  • 2 more comments
  • ctorrie Jun 12, 2008
    I dont have a vcr i had but now have sky plus
    no I have just tried that none of the controls buttons work play or fast forward or rewind but when you record it seems to be recording it just wont play back
    nothing its still a blue screen every other function works bar the playback
    THanks for helping its the top button functions that dont work when you press play ,so will take it to someone to have a look at it thanks again for your help
  • 4,234 Answers
The blue screen indicates that there is no video signal received. This can be either dirty heads or bad video heads. In most cases cleaning the heads will resolve the problem. Try inserting a blank tape and playing it all the way through. Then while in play mode, hit the rewind as if doing a reverse search. After that, try the original tape again. The blank tape will act like a head cleaner. If that fails to resolve the problem, the heads may need cleaning by a pro that will use a solvent.
Dan
Posted on Jun 12, 2008
  • 2,794 Answers
Have you tried playing the tape in a regular vcr with the VHS-C adaptor?
  • 1 more comment
  • Tim Babcock
    Tim Babcock Jun 12, 2008
    Does it playback if you plug the Camcorder into an electrical outlet?
  • Tim Babcock
    What happens when you plug it into an electrical outlet?
  • Tim Babcock
    That should be taken in to have someone look at it.
    It isn't a dirty head issue. You have have playback to fix it anyways.
    It has something to with motor engaging properly
My DVM70 will not play back the tapes. I can record and the screen looks like it is recording just fine, everything looks normal. When I go to play the tapes back on the camcorder the lcd screen is blue...
ES MUY POSIBLE QUE EL CABEZA L DE VIDEO SE ENCUENTRE
SUCIO LO IDEAL ES USAR UNA CINTA LIMPIACABEZALES O USAR UN SPRAY DE LIMPIEZA DE USO ELECTRONICO (DE LOS QUE NO DEJAN RESIDUOS OLEOSOS) ,APLICANDO PEQUEñOS CHORROS SOBRE LAS GAPS DEL CABEZAL ROTATORIO , ESPERAR ALGUNOS MINUTOS Y CARGAR EN LO POSIBLE OTRA
CINTA EN PLAYBACK ,TAMBIEN SE PODRIAN LIMPIAR LOS CABEZALES AVANZANDO Y RETROCEDIENDO RAPIDO UNA CINTA
Oct 02, 2009 | JVC GR-DVM70 Mini DV Digital Camcorder
I recorded an interview on my Sony HDV camcorder, about 15 minutes in the screen goes blue but keeps playing. While in play mode, if I fast forward the interview pops back up but disappears as soon as I...
The heads are dirty and you are getting sufficient digital dropout to cause the blue screen. Try a cleaning tape. If that fails to correct hte problem, then the alignment needs to be checked by an authorized service center.
Dan
Sep 14, 2009 | Sony HVR-A1U Camcorder
Jvc wont play back at all
please i am umber and we buy panasonic dv nv-ds5 please send me english languge manual this model and change the japniss language thankx
May 31, 2009 | JVC GR-D850 Mini DV Camcorder
Camera plays in fast forward-like speed
Though I don't know the details of your camera and the tape you are playing, one explanation could be that the tape was recorded in "extended play" EP rather than "standard play" SP. Some VCRs and some cameras are incapable of playing back in EP, a mode where the tape moves at half speed so you can record more on the same tape. The result is that the tape playing back at regular speed appears twice as fast and fast forward will be even faster.
Unfortunately, unless your machine can be manually set to play back in EP (usually it is automatic) the solution is to play it back in a machine that can handle EP.
Dec 04, 2008 | Electronics - Others
Cannot play tape.
Sometimes that happens to me too. What I do is just push play, then fast forward, and normally if you watch it, the picture starts to come back. Just keep fast forwarding until you can see all of the picture, and you should be fine.
Mar 24, 2008 | Panasonic PV-GS19 Mini DV Digital...
My camera wont play back in play mode
frist try to clean itor professional cleaned.
Feb 11, 2008 | JVC GR-D270 Mini DV Digital Camcorder
No Picture on playback
alignment is offset, should be easy fix with you local electronics repair place....if you need a cost estimate let me know model
Jan 20, 2008 | Video Cameras
JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
JVC GR-270U Blue screen with playback
a 1394 cable is specified for the GR - D - 270 but the GR - 270 U , not listed ( does your camera use VHS/c , or mini DV tape ? )
Aug 15, 2007 | JVC GR-AXM710 Camcorder
My GR-AXM18 JVC Compact VHS w/LCD Screen isn't recording!!
Blue means that there is no signal. It can be that the head is dirty. Use a cleaning casette, (do not use cotton swab and alcohol)
May 25, 2007 | JVC GR-D250 Mini DV Digital Camcorder
JVC GR-FXM40EK Camcorder Logo
233 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
sonic boom...
sonic boom...
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
