Question about Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
When i connect my 250 gb hard drive .... it says found new hard ware and tries to install the drivers for it but it cannot find any drivers... so it says your new hardware might not work properly... i need to download drivers from where can i do so thanks, Vinay
  • Peter Wharton Nov 02, 2010
    What OS are you using?
  • 305 Answers
Hello; Download the software through the link given.
Link:http://www.transcendusa.com/Products/SJelite2.asp
Driver:http://www.transcendusa.com/Support/DLCenter/index.asp?LangNo=0&ItemID=TS120GSJ25T&axn=SRH1_RLT&DLKeyWd=TS120GSJ25T
Posted on Nov 02, 2010
My computer does not recognise my WD element portable drive and I have no soft ware to install it, what can I do?
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Note that W.D. has a "Customer Loyalty" program; buy a new disk-drive from the W.D. web-site, at a good discount.
Oct 28, 2010 | Western Digital WD Passport 250GB Portable...
The computer is not recognizing this as a hard ware
right click on my computer and go to property then go to hardware then device manager then uninstall all usb drivers then right click any then clik on scan for hardware changes then it automatic installe driver then restart computer then connect your harddisk to computer again then check .
Also check your usb cable is working fine.
Jul 15, 2009 | IO Magic Corporation GigaBank (I250HD35)...
WD 250 G hard drive will not turn on at work
If that is the case and it works on another PC, your office PC may either..
Not have USB driver installed, and therefor cannot connect to it. I suggest running Windows Update>Custom Update, and under HardWare I imagine there should be an USB driver of some sort. That may fix the problem.
Another issue could be that the USB port has a hard ware failure. Try the other USB ports, if still nothing then it is most likely going to be a driver issue or maybe... all your USB ports have a Hard Ware failure of some sort.
You can check if you need drivers by going to Start>(Right Click)My Computer>Properties>Device Manager Tab. If there are any yellow or ! drivers, you will need to find them via Microsoft Updates, Manufacture/PC Brand Site (I.E HP) or google the driver needed for your particular modeled machine.
I hope I have been of some assistance.
Jun 30, 2009 | Western Digital My Book Essential Edition...
HDD is not dedected.
the first thing that pops up in my mind is a power problem. check if the hard disk starts making a 'spinning' noise when you plug in the power chord and turn the disk on. when you hear a ticking noise instead, it means the disk is broken. be sure it only makes the spinning noise. if it does, connect the usb-cable between the disk and the computer. if the disk is not recognised, replace the cable. if still not ok, post what you did as a comment, and please be as accurate as possible, because this problem may have several causes.
Jun 22, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
USB Hard Drive wont open
Make sure you have installed the software drivers first before connecting the USB hard drive. USB is Plug and Play, and when you connect hardware that requires drivers to be installed first, it will not function correctly or not work at all sometimes..
May 21, 2009 | Fantom (FDND250) 250 GB USB Hard Drive
My WD portable 250 gb hard drive
Had similar issue with my WD passport , it turned out that it didn’t like my USB 2 ext lead, as i am unable to access my PC’S USB socket i was a bit stuck ...... i have now found that a low cost “POWERED” USB hub solved the issue .....good luck
Apr 22, 2009 | Western Digital WD Passport 250GB Portable...
Installing new sata drive in HP pc
a clean xp installation does not recognize sata drives at all. you can either use nlite to build a custom install cd, press f6 during setup to load additional drivers, try to change your sata mode from native to compatible in your bios or use your restore cds.
Mar 18, 2009 | Western Digital WD2500BEVSRTL Scorpio...
Transcend 250 GB Hard Drive not recognized by Windows XP SP2
u may got installation cd for storage device.if not download software from www.transcend.uk  ......... otherwise try for this..
goto control panel...
then goto add hardware...
overthere check out for connectivity
Jan 28, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Logo
179 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
