Question about HP 35s Scientific Calculator
My HP 35s set keeps saying Memory Clear, I tried taking out the batteries but nothing works. Please assist
  • kakima Nov 02, 2010
    After turning on the calculator, pressing the ON key does not erase the Memory Clear message?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
Hold down the C key and press the GTO key.
If this doesn't do it, use a thin, pointed object to press the RESET hole. It's on the back of the calculator, near the right edge of the ID plate.
Posted on Nov 18, 2010
  • needsHP35s Jan 12, 2011
    I have the same problem. "C
My HP35s keeps flashing MEMORY CLEAR. I removed the batteries and reset it with a paper clip. Nothing works.
I'm not sure if it is the only solution, but I had the same problem and I replaced the batteries. My HP35S works fine now.
Previously, however, there was no "battery" annuciator on the screen. This calculator went four years without a bettery change. My HP48GII, on the other hand won't go two months without a change. Go figure.
May 11, 2011 | HP 35s Scientific Calculator
How to fix a none responsive button in hp 35s calculator
Resetting the Calculator
If the calculator doesn't respond to keystrokes or if it is otherwise behaving unusually, attempt to reset it. Resetting the calculator halts the current calculation and cancels program entry, digit entry, a running program, a SOLVE calculation, an ∫ FN calculation, a VIEW display, or an INPUT display. Stored data usually remain intact.
To reset the calculator, hold down the C key and press GTO . If you are unable to reset the calculator, try installing fresh batteries. If the calculator cannot be reset, or if it still fails to operate properly, you should attempt to clear memory using the special procedure described in the next section. If the calculator still does not respond to keystrokes, use a thin, pointed object to press the RESET hole.
The calculator can reset itself if it is dropped or if power is interrupted.
CLEARING the MEMORY
If the calculator fails to respond to keystrokes, and you are unable to restore operation by resetting it or changing the batteries, try the following MEMORY CLEAR procedure. These keystrokes clear all of memory, reset the calculator, and restore all format and modes to their original, default settings (shown below):
  1. Press and hold down the C key.
  2. Press and hold down the R/S key
  3. Press i (You will be holding three keys simultaneously)
  4. When you release all three keys, the display shows MEMORY CLEAR if the operation is successful.
Mar 02, 2010 | HP 35s Scientific Calculator
I have a control for my mitsubishi tv it just says mitsubishi on it its old and it has a button on the side that lights up everything but nothing else works as of a hour ago how do i reprogram it
One thing you can try is to remove the batteries and then press every button on the remote. While you have the batteries out you can use a paper clip to short the contacts where the batteries touch. This will clear the memory of the remote and set it back to the factory setting.
I hope that this helps you out.
If not, please respond to this post and I will try to assist you further.
Thanks.
asnowman
Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Memory full on LG Renoir but nothing on phone, Help ???
go into phone settings - memory manager - handset common memory and tap clear all. This worked for me i took my memory card out just to be on the safe side
Feb 24, 2009 | LG KC910 Renoir Cell Phone
Computer turns on, but won't work afterwords
Nev, the two loud beeping sound of the system when turning it on could be a problem with the memory or the system board.
Try disconnecting the power and take out the battery, then press and hold the power button for 5 seconds then look for the memory comparment and reseat it.
Keep me posted.
Thanks.
Nov 16, 2008 | HP Compaq Presario V2000 Notebook
Memory full hp 3055 laser jet
This is about send fax resolution problem, refer with this article:
http://www.topresource.net/info/103/hp_laserjet_3055_low_memory_problem_while_send_fax.html
Nov 12, 2008 | HP LaserJet 3055 All-In-One Printer
Can't reset
Batteries:
Make sure to replace the "battery backup" too the little lithium ion battery
Try Adjusting contrast:
Hold down "[2nd]" key press up or down arrow repeatedly to lighten or darken contrast.
First attempt reseting:
Step 1: Remove all the batteries
Step 2: Hold "Clear" key down
Step 3: Still holding "Clear" key reinstall batteries
Step 4: Still holding "Clear" key press "On" key until home screen is displayed.
Second shot reseting:
remove all batteries including lithium ion (backup battery), wait 3 hours and reinstall batteries.
Third Shot reseting:
Step 1: Remove a battery
Step 2: Hold down "DEL" key reinstall battery
Step 3: Possible msg pops up saying "Waiting ... Please install software" IGNORE msg and take out battery again
Step 4: Reinstall battery do not hold down "DEL" key
reseting will cause the handheld to loose all of its stored memory.
Hope that helps!
Jan 23, 2008 | Texas Instruments TI-83 Plus Calculator
HP 35s Scientific Calculator Logo
842 people viewed this question
Clive
Clive
