Question about Samsung HLP4663W 46" Rear Projection HDTV
Sporadic Hum on HLP4663W
After reading other posts, I'm guessing this is a color wheel issue but would love an expert opinion:
Starting about a week ago, my Samsung HLP4663W has a sporadic hum (not a high pitched squeal as others have said) emanating from the back of the TV. The picture is fine and this hum doesn't always happen. When it starts though, it does not go away. The only solution is to turn the set off and leave it powered off for 10-15 minutes. This isn't always a sure bet to make the sound go away either. When the TV is turned off and the picture immediatly goes black, the hum still exists. Its not until about 8 seconds after the TV is powered off and after (I believe) the fan stops that something else turns off and the noise goes away.
I would welcome any advice on what part needs to be repaired and if this is something a layman can do without paying an audio specialist $125/hour to fix it.
  • Samsung Master
  • 8,617 Answers
I would guess that its the fan for the lamp, as the color wheel will power down as soon as the power is cut. the cooling fans will continue to run
Posted on Jun 12, 2008
Have a Hum in the sound of the TV
If you mean there's a hum from the speakers it could be a disturbance in your AC line. Or a hum from a DLP projection TV could also be a bad color wheel. But if its from the speakers of the TV it could be noise in the power supply from a few warped capacitors.
http://tvtechwork.webs.com/
Nov 13, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Turbine/moaning sound and vibration
The grinding sound that you are hearing is your color wheel. They can make a noise from a buzz to a power saw type of noise. Usually the set will continue to play with the noise, but it is annoying. You will need to replace the color wheel now.
This is not as easy as the lamp replacement, as you have to pull the light engine to access the color wheel. It is not hard just more work and be careful of the color wheel lenses.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 03, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
How do I access the color wheel on my Samsung HLP4663W?
Looking from the rear of the set, the color wheel is just to the left of the lamp, underneat an aluminum heat sink. You have to remove 7 screws to get to it.
May 12, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W color wheel replacement
yes its true grt your self a pair of needel nose pliers and pull that jumper.
I had a tv set in my shop for weeks till i lerend that one
wat it was is that the new color weel motors are air cor and spin faster that the originals, so pull the black jumper it looks like a small hard drive just remove it
your set will auto ajust.
ther are sum small settings to add in the service menue to fine tune it.
but first pull that jumper..
seting can be found on google... i think i found it on tech assist.
and enterd model number.
Jan 12, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HLP4663W 46 in. fan noise when shutting off.
it is definately the color wheel, unplug it and don't turn it back on
Dec 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Color Wheel problem
Replacing the color wheel can sometimes switch Red With Blue. If you remove the jumper it could fix the problem.
Here's an article on it's replacement.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Aug 27, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung Color Wheel
Here's a good article on the Color Wheel
It says if your red and blue colors are reversed removing the jumper should fix the issue.
Your tv problem
sorry but the pop would be a lamp and not a color wheel. the color wheel would make the pic have not color or would keep the set from turning on
Jul 24, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
106 people viewed this question
Henry  Thomas
Henry Thomas
