Question about HP Compaq Presario SR1950NX PC Desktop
I turn my laptop on and the lead light comes on but blinking abnormal, the display screen does not come on, I try to restart but still no display from the screen. what could be the problem.
  • 305 Answers
Hello, Try removing the battery and fix it back after 5 min. If the problem not solved it has to be the problem with your display adapters or ram.
Posted on Nov 02, 2010
  • Joe Philip Nov 02, 2010
    I am in the office now, my laptop is at home and I will try your recommendation and let you know, thanks for your help.
My 2hp Panasonic is blinking when turn on and the compressor stop working while the outdoor fan will be blowing cool air.
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
Jan 26, 2016 | Panasonic Heating & Cooling
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
stops the operation.
unit.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
The green light on front of my HP computer comes on for a couple seconds and then it goes to red light blinking and beeping try to turn off and back on several times and go right back to blinking red
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jun 04, 2012 | Computers & Internet
All the lights come on as they should when you push the start button but I get a black screen with nothing on it.all the lights go out for a sec and come back on about every 17 sec. and it keeps do'n that...
Hi
you could try to restart laptop and press the F8 key at the same time holding down for a few seconds
hopefully this will bring up a repair options box
then you could try maybe
clicking on
last known good configuration
or repair my computer
you may be lucky
Mar 12, 2011 | Computers & Internet
When i try to open the only respond i get was the continue blinking of the laptop no picture is benig showned in the monitor
Shut down your laptop and try pressing the center of the keybord just center of your screen firmly gently and then start the system if its ok the display comes back you are having problem with the heat sensor of the display card and not coooling properly .so loosing the display.
BUT if you mean there is a cursor blinking on the screen and dosent have display then your boot devices are configured improperly and so its searching for boot device .
also it happens when usb boot is enable in the bios and any usb device is connnected like flash or usb hard drive try to remove them and restart the pc.
Dec 13, 2010 | HP Compaq Presario CQ50-110US Laptop
My tv sony wega dont turn on an the standby light blinks 16 times model KV-32FV310
Hello
Standby light on Sony TVs blinks 16 times is abnormal I thiks. It may come up to 8 blinks or so. You jsut switch off the set by AC mains switch at the front panel, switch it again with it and count the exact numbers. Never switch it On_Off by remote hanset.
If it happens even after this process, you just do the following
Press the following button on your remote control as stated
"Display"_"Channel"_"5"_"Vol Minus" [not plus] then "Power".
You may get "OVP" "OCP" "V STOP" etc displayed on the screen.
Just report the result to me through Fixya. Ok.
Nov 04, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
It turn on but is a blank screen.
for acer aspire one
This is bios problem. need to update bios.
Downlaod the bios file from this site.. extract into a formated usb .. plug the charger ... and plug the usb .. keep pressing FN+ESC button then turn on the laptop u can see light is blinking .when light stop blinking relase buttons wait for 5 min ..system will restart.. and u can see display.. Thanks
http://macles.blogspot.com/p/acer-aspire-one-bios.htm
Oct 08, 2010 | Acer Aspire One PC Notebook
My aspire aoa150 wont start up. turns on but screen remains black
Oct 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
Blink screen
do the lights on the laptop come on (does it have power?) if they do connect the laptop to an external monitor if you get a normal display thats good its sending a signal try pressing FN + F4 it should toggle between normal and external display modes... if that doesnt work you may have a problem with the motherboard.. either an unseated cable or short circuit...
Feb 03, 2009 | Compaq Armada 7400 Notebook
Turning on
take out the battery
remove the power lead
press and hold the power button about 20 seconds
replace power lead only
try and turn on
if this works - then you can replace your battery as per normal
Aug 13, 2008 | Acer Aspire 3690-2196 Notebook
HP Compaq Presario SR1950NX  PC Desktop Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
