I have a acer laptop with windows xp. i try to connect my simlpedrive 96300-40001-001 and its telling me that it has malfunctioned. how can i fix this???
Following are the drivers needed, just copy them to a usb drive and then run them on the laptop: Ethernet Sound Cd driver can be downloaded after you reestablish an internet connection.
Make sure the firewall software on the acer allows the wireless connections, try turning the firewall off for a moment and also disable the wired connection.
Make sure the network is safe or allowed most likely firewall blocking.
You Need To Boot From The XP CDrom...
Press Power Button To Boot, Hold Down F-12, Choose To Boot From CDROM, Go Through The Windows Setup Process, Remove Vista (delete it), then Format and Install XP...
Your 7520 can use the drivers from another acer model, for instance, try aspire 3000, or 5000 drivers.. or try another model...
If it's not the correct one, it will not install and throw up an error telling you it is incompatable and not going to install....
Here is a help article that goes into the detail of your issue. It will show you possible cause's and fix's. Following this guide should fix you right up! This guide is for Windows XP/2000...http://www.computerhope.com/issues/ch000465.htm
1). you must have Windows XP setup disk.
2). If your HDD is SATA interface then error message will be raise...No Hard Disk Found. To fix this problem goto BIOS setup and Make SATA disabled. then try to install.
