Question about SanDisk Sansa e260 MP3 Player
Songs on computer, but not on Sansa
I've seen this question asked a number of times, but no one's given a good answer -- I was hoping you could. I upload songs onto the player, and they're there when I connect it to the computer and open the removable drive folder, but when I disconnect the device, they don't show up on the player itself. They're mp3 format, just like everything else on it, but they're just not showing up, even when I remove the songs, disconnect the Sansa, reconnect it, and put them back on. That method used to work, but it doesn't anymore.
  • Riplox Jun 13, 2008
    I don't use any special programs to put the songs onto the player for the fact that it makes things more complicated and makes way for more error. I drag-and-drop, and I've tried both USB settings. MSC mode is the only one my computer recognizes and is the only one I've used, but I've tried switching them after uploading the music, and the songs still don't appear -- except on the computer, of course.
    I sure hope the database isn't corrupt -- I had this one refurbished, and it wouldn't make my day to know that it's broken again. Though, if that's the case, so be it.
    I try not to use WMP whenever possible -- I've always used Winamp, and I set it to work with the Sansa. I've never had any problem with those two before, even using Winamp to play the device.
    Is there such a thing as uploading too much at once? The albums I've put on are large in number (2 albums of 29 each) but the songs are very short, some under a minute long. Could this still be an overload, and should I try uploading them little at a time?
    Thank you so much for helping, I really appreciate it!
    Man, now I feel like an idiot ><
    Alright, I've tried uploading less than 10, even going back and trying just one song, and it's still not showing up.
    I've even gone back, forgotten about the songs I'm trying to upload, and went to reorganize other songs (fixing the album names, track number, etcetera), and that's not even changing. Just like my other problem, it's changed and organized on the computer, but on the Sansa, the album and track number are like they were before I reorganized them.
    In the past, I was able to fix these solutions by simply deleting the song and re-uploading it -- maybe a few times -- and it would be fine. Now I could do that all night and it won't do a lick of good. Am I fried?
  • 8,596 Answers
Very interesting. What program do you use to transfer files to your Sansa? Windows Media Player? Windows Explorer (drag and drop)?
If they are Mp3 format, then the format is correct - we can rule that out.
Unplug, retry failed, so we can rule out read errors.
You could try switching the player manually from mtp to msd mode, or vice versa - see your manual for details. One mode displays music files - the other mode hides them (which is why I don't like dual-mode players).
The database could have become corrupt - this can occur for a variety of reasons, but one reason is that this player was loaded on a machine running Windows Media Player 11. Have you updated the firmware for this device?
Posted on Jun 13, 2008
  • Corey Knoettgen
    Corey Knoettgen Jun 13, 2008
    Yes, absolutely, transferring more than 10 songs at once is a bad idea. Even though the transferring program and computer can handle it, it places a great strain on the Mp3 player.
    It's funny, the Sansa forums basically direct customers having the Winamp issue to the Winamp forums, but there are no solutions other than what we have discussed there either. If we can figure this out, we could help a LOT of people.
I dont have sandisk driver for my sansa E260..i cant transfer songs..
Sansa Not Recognized: Try connecting it to the back of your computer or another computer the back straight to the motherboard this should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software when finished disconnect.... Sync to upload songs to the sansa......Hope this works
Dec 01, 2010 | SanDisk Sansa e260 MP3 Player
I hv sansa clip 1gb - in which i have some songs i.e aprox.850mb and that cannot be seen in my pc in sansa clip as a drive g.how to delete songs and add songs , is there any driver of software or...
1. First, check your device setting up on MTP or MSC? Turn on device, go to "settings" , press down or up to find "USB Mode", you can see the check mark at MTP (auto detect) or MSC mode. Change to another usb mode.
2. You have 2 ways to delete songs:
2.1. Delete songs by device: play songs, press down (sub menu) until you meet "delete song", select it and yes
If you delete all items in device: Settings, Format, and yes
2.2. Delete songs by computer: plug device to computer, double click on device icon, Music folder, and delete songs you want. If you don't see songs in there, unplug the device from pc, and then change USB mode, and plug device to pc to delete.
Good luck
Feb 01, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa Clip 2GB MP3 player won't let me add any more songs to it, even though there's 1.26 GB still available. I don't want to reformat the player, cuz that'll delete the songs I already have on there. ...
Hi there..
When you say having difficulty in adding the songs in CLIP, though you have enough space. I'd kindly request you to check for the number of songs that you have added.
Because when you add as MP3 player by default its bit rate is 128kbps so you can add up to 500 songs only. Kindly have a check on it.
I have given the number of songs that can be added with related to size of MP3 player..
Size of the player :512MB 1GB 2GB 4GB 8GB 16GB 32GB
Number of songs : 125 250 500 1000 2000 4000 8000
Kindly revert if any clarifications....
Jan 30, 2010 | SanDisk Sansa Clip MP3 Player
Need to unlock my telstra zte 165 phone to be able to use different sim cards
I`ll give you two answers for this.
1.Easiest : ring your supplier i.e orange,t mobile etc and ask them to unlock your phone.(itsnot illegal)
2.other
If you enter wrong password for more then 5 times,it ll ask you to enter the puk number....now call your customer care and
get the puk number...enter the puk number in the space given for password....thats it...problem is fixed
If you had locked your mobile then update the formware all saved passwords will be deleted
Hope i`ve helped.
Nov 27, 2009 | Cell Phones
Cannot delete any songs on the device or through the computer. do not have manual, my system is version 01.02.18A sansa sandisk
Go Sansa - Settings - USB mode and change it to the OTHER mode.
Songs put on in 'one' mode can't be seen on the computer when the Sansa connected via the 'other' mode.
Sep 18, 2009 | Audio Players & Recorders
Sandisk sansa e200
To get songs off of mine, I went to my computer, and then to Sansa e250R (though your numbers may be different), then to music, and I just deleted what i wanted to get rid of. Im not sure, but this may only work if you're in PlaysForSure mode, which is changed on the mp3 player itself. Also, it leftempty artist folders on my Sansa, and I'm not sure how to get rid of those.
Apr 27, 2008 | SanDisk Sansa e200 MP3 Player
Sansa bad track
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media1.gif, music and delete them from there.
Either under sync pane in windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
Hope this helps
If you still not able to delete it let me know so I can have you try something else...
P.S.Please rate accordingly...
Thank You
Computerrep
Mar 21, 2008 | SanDisk Sansa E280 MP3 Player
Deleting songs on player e250R
Step One
Connect the USB cable to your Sansa MP3 player, then hook the other end to a free USB port on your computer.
Step Two
Give the computer time to recognize the Sansa MP3 player. Once it has, double-click on the MP3 player’s icon to view the music files stored to memory.
Step Three
Scroll through the list of audio files until you find the ones that you wish to delete from the Sansa MP3 player.
Step Four
Click on single items or click and lasso multiple files.
Step Five
Right-click on the highlighted files to pull down an action list and from there select Delete. The computer will ask if you really want to throw the file away. Select OK.
Step Six
Exit from the window, then disconnect the USB cable from the Sansa MP3 player. The player will automatically turn off. The memory will update the first time you turn the player on after deleting songs.
I hope that helps!!
Jan 23, 2008 | SanDisk Sansa c140 MP3 Player
My directory where MP3 are stored in sansa m250 cannot be seen on the desktop
Gagan, Please see my answer here http://www.fixya.com/support/t149468-san_disk Formatting your Sansa should do it. Let me know if it didn't and please rank my answer. Thanks, D.
Jun 16, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
113 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
