SOURCE: pioneer AVH-P5700 instalation
You can find a wiring diagram for your 87 monte at http://www.modifiedlife.com/1987-chevrolet-monte-carlo-car-audio-wiring-schematic/ You can refer to the installation manual for your deck at http://akamaipix.crutchfield.com/Manuals/130/130AVHP570.PDF Since you are removing a shaft style radio and installing a DIN style you will need to perform extensive modifications to your dash. The Pioneer manual provides the dimensions.
SOURCE: watch a dvd while driving pioneer AVH-P4000 DVD
Hi Dave
No ....go to a hardware store buy a toggle switch than get a single speaker wire (small wire) attach it to the red wire on the back of your pioneer deck (make sure to leave the red wire in back of deck as well) and attach it to the power on the toggle switch do the same with the black wire (ground wire) the black wire will go into the toggle switch under the power wire. finally install the parking break wire from the pioneer unit to the last slot on toggle switch and this should do the trick if not swap the ground spot for the brake spot on toggle switch >>>> MAKE SURE THE TOGGEL SWITCH HAS 3 HOOK UPS to do this correctly (your system will provide sound with the toggle switch off (Blue Screen) but when toggle switch is on you get video while driving) good luck
SOURCE: best buy soild me a
the unlock code should be in the hand book if not you can get it from best buy
ground the wire to a hot (ie power comes to the wire) switch in your dash, like a rear window defroster or seat heater. turn the switch on then off and it will trick the system into thinking you activated the parking brake.
