Question about Pinnacle Pentair High Flow Pump Seal 354545
When pump is turned on. it is extremely loud and somewhat high pitched. Can you tell me what this could be.
    President:
  • Pinnacle Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Your motor bearings are failing. It is most often caused by a leaking pump seal. It is a relatively inexpensive repair if it is caught early enough; before the shaft is damaged from the corrosive water eating into the steel. Take it to a local electric motor repair shop for inspection. It will likely need a set of 203 bearings for the motor and a mechanical seal for the pump. All told, depending on the labor rates, it should be less than $75. You could try to repair this yourself however if you are not familiar with the process it is money well spent having someone who is do the repair for you.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Nov 02, 2010
Secondary air pump located on frame under driverside on 2004 Envoy makes a loud hih pitched noise after cold start. Goes away after about 5 seconds. Can this be repaired or does it have to be replaced. ...
The pump is designed to run when engine is cold to clean up the exhaust, they do make a high pitched noise and this is not abnormal in any way. They are very much like a high speed blower dryer in the way they move air. You can't replace parts in them, they are sold as one unit cost about $210.00 US. A new pump will be somewhat quieter but is it worth the cost and time to replace it? Here is a picture of the
pump. Just click HERE
Nov 16, 2011 | 2004 GMC Envoy
Decreased suction and high pitch whine in motor
clean out suction tubes ther is something caught in them
Dec 13, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a loud engine noise--somewhat high pitch whine--except really loud and only after so many rpms. The noise happens when I am running my air conditioner. Ten to 15 miles after I first noticed the...
So when you turn off the air con the noise stops ..
If yes then its the bearings in the Air Con pump which is driven by the same belt and when turning the r13 coolant around the bearings being dry and worn out will start to make the noise Same as the water pump does when it goes, but yours is Air Con Pump.
DONT TAKE IT OFF YOUR SELF. RON
Nov 11, 2009 | 1996 Dodge Caravan
Dishwasher Making Loud High Pitched Noise.
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
High pitch noise when tv warms up
High pitch noise is created mostly by a Coil or a transformer,is not easy finding the source if you are not familiar with this type of coil since there many sizes and shapes,the set needs to be on while trying to find wich part is doing it SO if you dont know where and how better call a Technician and you will be safe.
Sep 12, 2006 | Philips 55P8241 55" Rear Projection...
High-pitched noise
Could you specify if noise is coming from : - The freezer - The outside back of the refrigerator - The bottom of the refrigerator
Jun 13, 2006 | Smeg FAB28
Pinnacle Pentair High Flow Pump Seal 354545 Logo
Top Pinnacle Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pinnacle Pool and Spa Expert? Answer questions, earn points and help others
