Question about Brother MFC-7820N Printer
Printing from XP to a Brother 7820N as a networked printer
Printing from XP to Brother 7820N. It's configured on the network, with its own static IP address, and is visible to the laptop. The error message: Error - Printing - Printer Busy or keeps on appearing. A Vista laptop on same wireless network prints to it without any issues. Any thoughts?
    Problem Solver:
  • 7 Answers
We have multiple 7820s in our office. This would be a configuration problem with your windows XP computer. From the XP computer, open a command prompt and type "ping x.x.x.x" where x.x.x.x is the ip address of the 7820n. Make sure you get four successes. I would then uninstall the brother software and drivers and go to "printers and faxes" in the control panel and manually add the printer.
To manually add a network printer, with it's own print server, on Win XP:
1 Click "Add Printer"
2 Select "Local Printer Attached to this computer"
3 Deselect "Automatically detect and install my Plug and Play printer" then click "Next"
4. Click "Create a new port" and select "Standard TCP/IP" from the drop down. Click "Next". this will open TCP/IP Wizard
5. Type in Printer IP Address next to IP Address (Port name will autopopulate) and click "Next"
6. If wizard finds printer, it will show you "Finish" button. If you get a "Additional Port Information Required" window, something is wrong with your printer or windows xp network configuration.
7. When the TCP Wizard window closes, it will take you back to Add Printer Wizard. Select "Have Disk" and navigate to the \USA\WXP\Addprt directory on your Brother Drivers disc.
8. Select brxpadd.inf and click "Open" then click "OK"
9. Select "Brother MFC 7820 N Printer" from the list and click "Next"
10. Select name of printer, whether you want a default, print test page and DONE!
Posted on Apr 30, 2009
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Apr 16, 2013 | HP Color LaserJet 2600n Printer
Tip
INSTALLING A NETWORK PRINTER These instructions generally apply to all network...
These instructions generally apply to all network printers with built-in network cards (print servers) such as HP Laserjet printers, IBM Infoprint laser printers etc.
This example is for a network HP Laserjet printer.
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network).
If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer’s network configuration accordingly.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
on Dec 06, 2009 | Computers & Internet
Set up wirelessprinter hp
Jan 28, 2013 | Office Equipment & Supplies
Wireless printer configura
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc.This example is for a network HP LaserJet printer.To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly.
2. Install the HP printer driver onyour computer/s using the LPT printer port.
3. Connect the printer with a LAN cableto the network hub/router.
4. Click on Printers and Faxes - rightclick on the HP printer and click on Properties.
5. Click on Ports and click on AddPort.
6. In available ports - click onStandard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IPaddress of the HP's printer IP address.
8. Click OK and tick Enablebi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printerprints correctly.
Install the HP printer driver on every computer on your network and configurethe printer's TCP/IP port as previously detailed.Do a test print page to check the printer.
Jul 31, 2012 | HP Office Equipment & Supplies
Unable to find printer sharing for mfc6890 over window xp
To set up printer sharing in your home network, you need to configure printer options in the control panel of Windows XP Operating System. You could get a menu while right clicking the printer icon in the Control Panel. From this, you need to select the sharing option. You also need to make sure that you have enabled printer sharing option in the network card properties. To connect a printer in the network you need to set an IP address for your printer. If you have any troubles with printing with your printer in the network it might due to the errors in the network. So, you need to make sure the network connection.
Apr 06, 2011 | Brother MFC-6890CDW Printer
Will not print
The Simple Network Configuration capabilities of Mac OS® X can only find devices in the local network segment. If your Macintosh® and devices are not in the same network segment or are connected via a router, you cannot use the Simple Network Configuration capabilities of Mac OS® X.
In these cases, I recommend you use IP printing.
May 23, 2010 | Brother MFC-8460N All-In-One Printer
I want to connect my SCX 4500w to a new network (wireless). when i try to use a web page to configure the printer settings it doesn't response... I check the IP and write in in my Internet Explorer,...
You could try having your Samsung SCX-4500 print out a network configuration sheet. It will have the printer's IP address, default gateway etc.:
1) Press the <Menu> button on your printer panel
2) Scroll using the (<) or (>) navigational arrows until "Network" is displayed
3) Press the <OK> button
4) Scroll using the (<) or (>) navigational arrows until "Network Info" is displayed
5) Press the <OK> button
Your printer should print out a network configuration sheet. The IP of the printer appears in the TCP/IP information on this configuration sheet.
Note: Your printer's IP assignment should be "Static" not "DHCP" (You may skip the following steps if your printer's IP assignment is already "Static")
To change your IP assignment from DHCP to Static:
1) Open up your Windows browser
2) Type in the printer's IP address in the address (location) bar of your browser:
Example: http://192.160.0.100 (use the real IP you found above from the network information sheet)
3) SyncThru should load - Click "Network Admin" or "Network Settings"
4) Click on the "TCP/IP" option on the left side
5) Change the IP address METHOD to "Static"
6) Click <Apply>, then <OK> or <Exit>
Now your printer is ready to be added to your network. You have the information you need from your network configuration sheet. Your install should now proceed smoothly.
I hope this information was helpful!
Mar 07, 2010 | Samsung SCX-4500 Laser Printer
How do you print a configuration page????
there are two method to find out configuration page
on the menu button
select printing option and print configuration
connect to network
configure ip address
http://<ip addr> on the browser
you can print configuration from the menu
Nov 25, 2009 | Brother HL 1440 Laser Printer
I have a brother printer, Model Number HL-2700cn, serial no u60767M4S142278. I just bought a lap top and wireless broadband router. In order to connect the printer to my wireless lap top I need the IP...
The Automatic Private IP Addressing (APIPA) protocol
automatically assigns an IP address from the range:
169.254.1.0 to 169.254.254.255. If the APIPA protocol is
disabled, the default IP address of a Brother print server is
192.0.0.192. To change it, use the printer control panel (if
applicable), the BRAdmin Professional, Web BRAdmin software
or let your DHCP server allocate an IP address to the printer.
2 Refer to chapter 10 of this User’s Guide to learn how to
configure the IP address on your printer.
3 The default password for Brother print servers is access.
4 Windows® 2000/XP users can print using TCP/IP using the
standard Network Printing software and IPP protocol software
built into any Windows® 2000/XP installation.if you need manual just email me at repagenserv@saipan.com or romeo_palencia@hotmail.com
Mar 27, 2008 | Computers & Internet
Brother 845cw printer is offline -
Had same issue and here is what worked for me.
1. Go to Printers and right click on Brother printer and choose 'Properties'
2. Click the 'Ports' tab and with proper Brother printer port highlighted click 'Configure Port'
3. In second field titled "Printer Name or IP Address" enter the IP address of printer*
4. Click 'OK' as need to exit out.
I'm using XP so this may be slightly different depeneding on your flavor of Windows. The main thing is to name the port with the IP address and not rely on name resolution.
Hope this works for you too!
* If you don't know your printer's IP address then you can go to your printer and under the 'Reports' section print-out the Network Configuration report to find IP address.
Feb 29, 2008 | Brother MFC-845CW multi-function...
Brother MFC-7820N Printer Logo
732 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
