Question about Steinberg Nuendo 3 for PC
Stops my work!!!
I m Pushon from Bangladesh.....my problem with nuend is that very often wahen i open a project an error messege tells the followings:
"A serious problem has occurred: Please try to save your song under another name and then restar Nuendo3.exe. If this problem presists please contact Steinberg Technical Support with a description of what you do to create this problem, and the created file C:\Program Files\Steinberg\Nuendo 3\Nuendo3.LOG."
this problem started very suddenly......it ruons my daily wok.....plz anyone help me to solve thim problem.
  • 3 more comments
  • Pushon Jun 20, 2008
    okey....and thanx a lot....but I have the updated AVG antivirus.....should i need to change my antivirus software??
    thank u verrrrry much....i didn't know that Kaspersky is useful from that side......i'll start using it very soon.....wioll let u know what happened.....thank u....take care!!
  • Anonymous Dec 01, 2008
    same problem
  • mosiqaar Dec 08, 2008
    i have problem
    nuendo can not open the project files >?
    i need help>>?
  • mcbessi Mar 07, 2009
    I have the same Problem with than even with cubase when i add a effect to my vocals example the API from waves and i mixdown it than it shows that error try to save to another name .....
    can Anybody help me please?
No,it's not a virus nor a worm.I had the same probem.After few checks I notised that it's caused by by Waves API plugins.Try to unisntal them or remove'm from your project and yo'll see that the problem will dissapear.I'll write here if I find the way to get rid of that issue.
Posted on Oct 10, 2009
  • 75 Answers
It's surely a virus attack. Make sure u have a very good antivirus like kaspersky and update it and scan the computer.First,backup all ur important data at the earliest possible to a external pen drive.May be u can download kaspersky on torrentz.com. THANK YOU!!!
Posted on Jun 17, 2008
  • adamya s Jun 20, 2008
    If u are using internet and doing some important project works and loading data to ur pc from external devices, we always recommend kaspersky 6 or 7.In fact, it is the best antivirus existing on the planet till today.But, once u install it, make sure u turn off proactive defence and anti hacker features in kaspersky's settings, so that it does not notify u for every program that u use.
I NOW THIS PROBLEM >>
AND I FIX IT >>
PLEESE GO TO UR LANGUGE IN CONTROL PALNAL >>
AND TRY TO FIX UR LANGUGE THERE ..
CAUSE IT NEED TO DO THAt
Posted on Dec 08, 2008
Pressed menu and input on front of wd-60735 blinking light 3 times then 4 times
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
Lamp is first suspect followed by Ballast that drives it.
I also suggest the following answer I posted for a similar set be considered:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
May 25, 2012 | Mitsubishi WD-60735 Projection Television
Just moved my 52 inch sony wega and when we plug it in and try to turn it on it blinks red three times and does nothing
Welcome to fixya.com!
3 Red blink error shows that lamp cover is not fixed properly after lamp replacement.or either its moved, replaced Etc .
Please check Lamp Cover and put it back properly as it should be .
I hope that helps you. do comment if its not
Fixed tell us if there is any error message showing we will help! just comment with a messege
Apr 30, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
When I open my sony vegas 9 project, it begins to load, but when it reaches 17% a pop up comes on with the following messege: "An error occured while loading the project back to chernowitz.veg. The file...
The file is most likely corrupt. I would recommend trying to reinstall Sony Vegas Pro if the problem persists. If you are trying to open a file within Sony Vegas Pro then i would recommend searching or asking for ways to fix the corrupted file format, however their are plenty of good file fixers online.
Aug 13, 2010 | Sony Vegas Pro 8 for PC (SVDVD8006)
Error messege on startup
you might need to reinstall windows because of a registry error
May 29, 2009 | Microsoft Windows XP Home Edition
System error E007
plz open out fixing assy.then see the fixing film.if it is not well plz change it then your problem may be solved
subrata sen
assistant service engineer
flora ltd bangladesh
07124064585
Mar 28, 2009 | Canon iR 2016i Black and White Copier
Red blinking lights
Here are sample paragraphs from the user manual : hope it helps !
The new message LED on the handset flashes when you have new messages in your
answering system. The LED stops flashing when all new messages are played back.
3) To delete all messages, press delete messege in standby mode. Press delete
messege
again after the announcement "To delete all messages, press delete
again."
When you try to delete all messages without first listening to your new messages,
you hear several short beeps followed by an announcement "Please playback all
messages." This protects you from accidentally erasing messages you have not yet
reviewed.
Important:
When you press delete messege, you are permanently deleting the message. Once
deleted, the message cannot be replayed or retrieved.
Nov 20, 2007 | Uniden TRU8885-2 Cordless Phone
Messege errors
It sounds as though there is an email stuck in your outbox. I don't know which email program you are using, but you should be able to open your email program, wait for the error messages to appear, close the error messages & delete whatever is in your outbox.
Nov 13, 2007 | Microsoft Office Outlook 2003 for PC
Steinberg Nuendo 3 for PC Logo
748 people viewed this question
Top Steinberg Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
 Grubhead
Grubhead
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
