Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Central honeywell air conditioner
Mt Honeywell central air conditioner unit will not turn on, neither the fan or the the air conditioner. We returned from vacation and the unit seems "frozen".
Thanks!
    Novelist:
    Champion:
  • 230 Answers
Sounds like it may have lost power. Check the breaker and the fuse at the furnace. If they are all in the on position and working then it sounds like you may need a technician. If the display is blank on the thermostat you may also want to replace the batteries.
Posted on Jun 17, 2008
Carrier oil furnace model 58BMA155-20(FORCED HOT AIR)i had changed the blower motor & honeywell st9103a128 fan control board.now the blower motor won't shut off until the breaker is turned off.i...
You need to check the wiring to the limits and safety devices with are in a number of locations, make sure all connections are tight.The most common cause for the blower to run is the high limit device which is the one mounted above the burners on the flat metal panel with two wires.
Nov 03, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
Air condition won\t come back on i hav a central air made by honeywell.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 27, 2011 | Honeywell Heating & Cooling
Not sure what type of thermostat to hook up to run it
Hello, most programmable thermostats will work with your unit. Honeywell and white rodgers makes good quality thermostats. Here is a link to some thermostats....http://yourhome.honeywell.com/home/Products/Thermostats/
Apr 02, 2011 | Ruud Central System Air Conditioner
The wall mounted thermostat in a condominium unit (central HVAC in a high rise) is defective. I need to know 1. how to take out the existing thermostat (Honeywell T6069A1008) and 2. what replacement is...
i think you may have a fan/control board problem, if the thermostat turns on the fan, and you dont touch it, then the fan stops in a short time...
plus the fan is connected to a control board, like i said those thermostats hardly go bad...
Dec 19, 2010 | Honeywell Heating & Cooling
I put in a new honeywell thermastat my heat works but not my central air no power at all. when I turn it to cool will not even turn on air
What da ya got electric heat or gas heat? Did you buy the correct base for the thermostat? Who connected it? Honeywell is awesome but you need a pro to hook that sucka up.
Jun 25, 2009 | Weather King 10AJA2501AH Air Conditioner
I'm trying to turn on the central air conditioning in my new apt, and it's not working. I'm flipping the switch on the bottom right to Cool. It's blinking "Cool On" but also says...
Remove the front cover off the thermostat and jumper the power wire= r- to g==fan & r-to y==cool if it works, then its the thermostat!
Sep 01, 2008 | Honeywell Heating & Cooling
My central heating system comprises a worcester bosch system boiler and honeywell smartfit controls. The problem I am having is that the central heating doesn't seem to knock off at the preset temperature...
You could possibly have an ignition problem. The controller will go into a lock-out condition if flame is not established. Turning the temperature control down and then back up may be serving to reset the control system so it tries again.
May 21, 2008 | Honeywell Heating & Cooling
Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Oct 12, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
409 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
