Question about Nintendo Wii Console
Black screen Whenever i turn my wii on the light will turn green and I can hear the normal noises it makes but there is no picture or sound and i have it plugged in and every thing
  • Anonymous Jun 12, 2008
    I turn on the wii... wait until the green light turns on but the normal wii menu dosen't shoe up.... all I see is a black screen
    Problem Solver:
  • 8 Answers
MAYBE, and just maybe, there is something wrong with your wii on the inside. if you seriosly do have all of the cords plugged, then i really dont know what's wrong. if its new enough, then the warranty should still be active and you can return it to the store you bought it from and get a new one. OPTION # 2: you can bring it to game stop and see if theres anything wrong with it on the inside. if you still have problems, then i'm lost
hope anything i said helped.
Posted on Jul 23, 2009
Also if you are hearing sound try using Component/High Def cables.
Posted on May 27, 2009
  • 111 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqrtyctr-107
    Problem Solver:
  • 9 Answers
I have the same problem.... What I tried doing is making sure that the cables are put in correctly and that you are on the right channel. If that doesn't work... you should call nintendo cand ask for answers or a replacement wii
Posted on Jun 12, 2008
  • 132321 Jun 12, 2008
    i just fixed my wii with the same problem. If your wii is plugged into
    a VCR, go to the vcr settings and check if the cooresponding locations
    of the video and audio cables are correct. I plugged my wii into the
    front of the vcr. In the setting, it was selected as rear. When I
    swirched the settings from rear to front, all worked perfectly. hope
    this helps. And if you did not plug your wii into a vcr, makes sure
    that the settings on your tv are corresponding with the location of the
    aduio and video settings.
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
My Magnavox TV give sound but no picture. When I turn it on the light in the bottom right hand screen goes green, then flashes to yellow and goes back to green. The screen does not change it is constantly...
You need to replace your backlight inverter.
Check that all voltages are coming from the power supply as they should. The power supply will be stamped with the correct amounts, and you just read with the multimeter to confirm.
After those check out ok, you will need to replace the inverter to "light" your screen again.
You can hear sound because the tv is ON, but the inverter isn't lighting the screen!
Hope this helps, please rate!
May 11, 2011 | Televison & Video
Black screen..no sound or anything.
Try replacing the cords. I don't have a Wii but tHIS WORKED FOR MY ps2
Nov 26, 2009 | Nintendo Wii Console
My wii wont turn on the power does not show a light
Try a different outlet to make sure the outlet you have it on is good or not.
If a different outlet didn't make it turn on then at that point, try another ac adapter for the Wii. If a different adapter doesn't work then you know the main board inside of the Wii is bad.
Aug 08, 2009 | Nintendo Wii Console
Green light but no picture, no sound
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
WII CONSOLE
When you turn the Wii on, and the light goes from red or orange to green, press A a few times (this would be to get through the warning/safety screen) then wait a minute. Then when you wave your remote about, you will feel it vibrating as it goes over the channel icons on the wii menu screen. Plus a blue light will be lit at the bottom of the remote to denote player 1.
If all of this happens, it is just a lead or TV input issue. If these things do NOT happen, the Wii is broke and needs fixing by Nintendo!
Dec 25, 2008 | Nintendo Wii Console
Green light stays on, black screen, no sound, no connection w/ remotes
Go to the tv settings and check to see if you blocked any incoming devises. If you did block the devides, your tv will not read the wii
Jun 11, 2008 | Nintendo Wii Console
Tv goes black and the green light stays on and the sound also works
Try Shining a bright light at the screen. can you see any images on the screen? If you can, then the backlight on the tv has gone, and can be replaced. If you cant then it may be a fault with the inverror (power) board on the TV
Dec 26, 2006 | Maxent MX-42HPM20 42 in. Plasma HDTV
Nintendo Wii Console Logo
307 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
