Question about Printronix P7005 Matrix Printer
Barcode damaged reverse spools - Printronix P7005 Matrix Printer
2 Suggested Answers
SOURCE: showing barcode damaged reverse spool
my printer model printronix P7-500 ser no 6I705000229 barcode damaged
Posted on Jan 04, 2011
Printer given barcode missing install new ribbon
There are two styles of P7000 a spool ribbon style and a cartridge ribbon style. You are getting a barcode error then your printer is looking for a ribbon spool not a ribbon cartridge.
Cartridge Ribbon:
PRINTRONIX 255048 402 P7000 EXT LIFE CARTRIDGE RIBBON New
Spool Ribbon:
PRINTRONIX 179499 001 ULTRA CAPACITY RIBBON 6 PACK New
Jan 03, 2016 | Printronix Office Equipment & Supplies
I have printronix p7220 problem in after initialized massage "barcode damaged" please help and support
Check the bar codes under the ribbon spools as they can become damaged, it's these barcodes that the printer uses to work out the ribbon life, also clean the barcode sensors under the spools that read the bar codes.
May 13, 2011 | Office Equipment & Supplies
8110 printer stops printing after running the yellow and red colors...will not feed paper back in to finish with the rest of the printing...not sure what to do
It sounds like you may have a damaged ribbon (transfer film)
Take out the cartridge and with the barcode side facing you, turn the left spool (takeup spool) counterclockwise until you have seen a complete square of cyan (blue) and magenta (red) and yellow (actually yellow) go past, and then reinsert the tri-color cartridge.
Feb 27, 2011 | Kodak Picture Maker Kiosk Printer
Showing barcode damaged reverse spool
Sep 24, 2010 | Printronix P7005 Matrix Printer
How to install typewriter ribbon on a Sears typewriter model no 2
I believe this T/W takes a Gen. Ribbon T5 or T7. Check to see which way the spool turns over 90% wrap to the outdide of the spool. Put it on to wrap in that direction, the ribbon will have an eyelet about 6" from the end be sure that is wrapped on the spool. From either side put the ribbon tru the reversing arm, tru the lifter, tru the other reversing arm and back to the other spool.
DickyO
Jan 19, 2010 | Office Equipment & Supplies
I'm trying to thread a ribbon through my old underwood 11 typewriter. Does anyone know the steps to doing this?
First, type a few letters to find out which direction the spools wind the ribbon (either to the inside or outside). Make sure the spools are installed to wind the ribbon in the correct direction. Second, make sure there is some ribbon wound in the empty spool so the eyelette on the ribbon for automatic reverse does not cause a jam by getting on the carriage side of the reverse guide. Take one spool in each hand, and let just enough slack in the ribbon to insert it behind the ribbon guide next to the platen. Note: the ribbon must go behind the two middle fingers of the guide and in front of the two outward fingers of the guide. If the guide has downward hooks on the outward guides, make sure the ribbon goes under the hooks to prevent the ribbon from bouncing out of the guide during typing. Next, make sure the ribbon passes through the metal guide fingers in front of the ribbon spool holders (these are for the automatic reverse - make sure the metal eyelettes in the ribbon stay on the spool side of the fingers or you will not get a reverse, and the ribbon will jam). Place the spools on the spindles of the spool holders. If the spool is hard to mount, check to see if there is a slot in the ribbon spool to align with a lever or mechanism on the spool holder of spindle. Hope this helps.
Apr 06, 2009 | Office Equipment & Supplies
304 barcode damaged
Try one of the following:
1. Turn the printer off, then back on
2. Reverse the ribbon; perhaps it is upside down
Once the printer is powered on and the ribbon is in correctly, the printer should work.
Mar 13, 2008 | IBM Infoprint 6500 Matrix Printer
Printronix P7210 Ribbon problem
Call 800-854-3181 to talk to a LIVE tech support which is located in the US.
Mar 03, 2008 | Printronix Line Matrix P5210 Printer
Printronix P7005 Matrix Printer Logo
305 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Harrie
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
