Question about Hoover F7220900 SteamVac V2 Upright Vacuum
The brushes will not turn. How do I open the unit to put the belt back on?
I have a Hover Steam Cleaner, Model F7210-900, Seral #Z 12.0. The brushes will not turn. How do I open the unit to put the belt back on. I suppose that is the problem. I have taken the unit in several times for this problem and I was told the belt was off. I would like to fix this problem myself rather than driving 30 miles on way to get it repaired. I do not have a manuel for my cleaner.
    President:
  • 1,673 Answers
Hoover doesn't use belts on their steam cleaners. Either the shaft that is on top of the brush block broke off, or the turbine is bad. The turbine is what turns the brushs.
Posted on Jun 12, 2008
I have a hoover F5853-900 steam cleaner.Everytime i lift it up the brushes turn but when they are on the carpet they quit.I got told that this model does not have a belt.I really love this steam clean
The brushes are turned by a motor. No belt. It's possible the gears on the brushes have a flat spot on them which would stop them from turning under a load.
Dec 06, 2014 | Hoover Vacuums
No steam comming out of my h2o x5 cleaner
see the causes and proceed with common sense. and fix it. God bless you
If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on a steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly
  • Sep 22, 2012 | H2o TR220002 Steam Cleaner
    I have the SAMSUNG WA80V3 washing machine and I have tried many detergents but they all clogg. I also put a filter but still the problem remains. Is it the water quality? I live in Oman.
    see the causes and fix it. God bless you
    stopped spraying. If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly from
  • Sep 22, 2012 | Samsung CASE-DETERGENT;WA80V3 -...
    Hover steam vac Model #F5897-900
    When I use my Hover Steam Vac, it smells like rubber is burning. How do I fix this?
    Jun 16, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
    How do i put belts on a bissell powerbrush steam cleaner?
    If this is the model i'm thinking of. Make sure the units unplugged from the wall. There should be about six phillips head screws to remove. The motor should now be exposed. This is a good time to clean up the inside of the unit. Use liquid wrench or WD-40 and lubricate any moving parts. Make sure the brush is in good shape some require you to rotate or flip the brush to even out the wear. I hope this has been helpful.... : )
    May 07, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
    Problem putting on flat drive belt on Hover Vaccun cleaner model # U6434-900. Also how do I get the belt on? Do you have tool to help put the belt on.
    the best way is to use an flat blade screwdriver. Attach to motor first than but screwblade into belt holding it aginst the brush holder drum and roll the brush forward inching the rubber belt onto the spendle that drives the belt
    May 09, 2008 | Vacuums
    Bissell Proheat Carpet Cleaner
    First remove the some cover on the lfet side that is on top, then turn unit over, remove the red lock plate, has 1 screw, pull it out, then you can pull the end cap out, remove it, the cogged belt is there. If while you have the brush roll off, the pump belt can be replaced also. REmove old belt, put new belt over the bigger round part of the pump pully, feed it thru opening, then from the top, grap it and stretch it over the motor shaft. Then put the cogged belt on and reinstall the brush roll and the red lock.
    Jan 31, 2008 | Bissell 1699 ProHeat Clear View Upright...
    Need help putting back together
    With out seeing it, it will be hard to figure out what isn't right. Must be a different model then 1699. which model is it?
    Nov 08, 2007 | Bissell 1699 ProHeat Clear View Upright...
    Hoover F7220900 SteamVac V2 Upright Vacuum Logo
    91 people viewed this question
    Top Hoover Vacuums Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
