I have water but no ice. light turns on but then slowly dims after a second, then flashes back to bright, then dims, bright, dim, bright, dim, etcI have water but no ice. light turns on but then slowly dims after a second, then flashes back to bright, then dims, bright, dim, bright, dim, etc
Ice and Water not working, and the light doesn't turn on, that lights up the glass in the door. Once again does this sound like a problem I can solve. Thanks
I have the same problem water dispenser doesnt work nor does ice dispenser.Front panel lights turn on but motor doesnt sound to dispense ice.contact [email protected]I have the same problem water dispenser doesnt work nor does ice dispenser.Front panel lights turn on but motor doesnt sound to dispense ice.contact [email protected]
Ice and water dispenser stopped working soon after installation. Water sometimes resumes operation, but ice has never worked again. Never makes ice as internal reservoir is empty. Ice and water dispenser stopped working soon after installation. Water sometimes resumes operation, but ice has never worked again. Never makes ice as internal reservoir is empty.
Hi
You have not supplied the make or model of your fridge and so I can only offer a generic response.
Most ice-makers, chilled water dispensers are reliant upon a water stop valve that make a distinctive click when operated.
Does it click when you dispense water?
If not, then assuming the ice dispenser works (indicating the activate button is working), then the water valve has possibly failed (or less likely the wiring somewhere in between).
The button lock switch along with the other switches on the door use one common return wire for power to the solenoids. The freezer door light switch will stop power to the buttons if it has failed.
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Has someone pressed the lock button on the front of the fridge just above the dispenser, next to the crushed & not crushed ice button, if so there is also an unlock button next to it.
same here, no power to dispenser?
