Trying to setup wireless router on Qwest Modem M1000. Using the voice activated help and have got to part where it ask you to open window borrowser and type in 192.168.0.1 and then hit enter on your keyboard but when I do, it say's: Windows cannot find '192.168.0.1' Check the spelling and try again. I've typed in over and over and it won't take it, to continue. Can you please help me?
SOURCE:
ayamaya
  • 143 Answers
SOURCE: configuring paradyne 6211 adsl2
i assume that the physical conenction of the modem to the computer is ok. if so,
- you need to access the modem's setup page by entering http://192.168.1.1 on your web browser's address bar. the default username is "user" and the default password if :admin"
- click on "device info" and select "quick setup", you can check the box "DSL Auto-connect" that will automatically detect your PVC (vpi & vci) but if you already knew these info, you can just enter it on the screen and click on "next"
- then go to "advanced setup", select "wan"
- if you don't have any "wan setup", you can click on "add" but if you do have one, you can just click on "edit" if it's not the correct internet settings
- then it'll promt you to select more settings like the "vpi" and the "vci", the "service category" (note: for the service category, you can select "UBR w/o PCR" but to make sure that it's the correct setting, you can ask your ISP). click on "next"
- select now "pppoa" or "power over atm"
- then select "vc/mux" for the "encapsulation mode"
- then click on "next", then click on "finish" to save the settings
hope this'll help you.
ciao!
Posted on Jun 19, 2008
sandrew
  • 2961 Answers
SOURCE: Cannot connect to internet via Actiontec M1000 (Qwest)
open internet explorer, go to tools, internet options, then the connections tab and make sure ' never dial a connection' is ticked, assuming you had a dial up connection before using the router, other than that you need to check the routers settings, like the password /username for your ISP connection and assuming you originally set it up using an RJ45 lan cable (supplied) before using the wireless.
Posted on Aug 23, 2008
  • 35 Answers
SOURCE: d-link 614+ will not connect with Qwest M1000 modem
Well what everybody really doesnt know is that if Qwest provided you with a modem named Actiontech that modem has the same ip address of router so just change routers ip address to 172.16.0.1 and subnet mask to 255.255.0.0 and the problem should be solved.Im a product specialist for dlink.
Posted on Aug 27, 2008
govinda123
  • 2276 Answers
SOURCE: How do I connect to a qwest dsl m1000 modem
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on Aug 20, 2010
eastpole
  • 22 Answers
SOURCE: set up router/modem as instructed
Problem can't be solved as described, a fixer would need more details.
What kind of modem/router is it?
What instructions are you working from so far (you say, "as instructed" so I take it you're looking at a Quick Start Guide of some sort?)
How are you connected to it?
What http address are you going to (E.g. some routers use 192.168.1.1, others 192.168.1.254 or various alternatives)
What happens when you enter that address on a browser?
Have you set your computer's address to a nearby address so it can talk to the route?
If I had one guess with not enough information, I'd say you need to set your PC to an address one different from the target you're going to.
( http://compnetworking.about.com/od/workingwithipaddresses/g/192-168-1-254-d.htm )
Posted on Jan 10, 2011
Where can I get a quest m1000 mnual for a quest m1000 modem
Here's a link to the quick setup guide:
http://setuprouter.com/router/qwest/m1000/manual-596.pdf
and Centurylink help site:
M1000 Actiontec Modems
Note: Google searching for actual .pdf manual results in links to hacker sites, be careful.
Nov 11, 2014 | Actiontec M1000 Dsl Wifi Modem In Box W/...
Trying to connect dir-615 to qwest modem pk5000z. Can you help? We have two computers hooked up to pk5000z.
It looks like the Qwest modem is a modem/wireless router. It's hard to set up a router through a router. It's easier to connect multiple devices with a switch or hub going through a router then a router through a router. Other then me trying to guess at the problem below is a link to Qwest's support page. They have an excellent support page with troubleshooters, manuals and guides. I would try there first because the support page is so good.
If you don't need the second router then please don't try to set it up.
May 19, 2011 | D-Link DIR-615 Wireless Router
Aug 20, 2010 | Linksys Wireless-G WRT54G Router
Ethernet works, Wireless doens't Page Can Not Be Displayed
check ip setting and DNS setting of router and your wireless card
Jul 21, 2009 | Computers & Internet
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I need instructions for a Linksys Wireless G router to work
Call your internet provider they will walk you thru the process.
Jun 18, 2009 | Linksys Wireless-G WRT54GS Router...
Weird MN700 hassle...
can you tell modem has the 192.168.2.1 ip just chage into different
Mar 04, 2009 | Microsoft MN-700 Wireless Router (p5308j)
D-link 614+ will not connect with Qwest M1000 modem
Aug 27, 2008 | D-Link AirPlus DI-614+ Wireless Router
Aug 23, 2008 | Dell Wireless 2350 Router
Ip problem
It is common to have this as the default IP to connect to equipment.
I suggest you unplug your modem while you set up your router. You can also change the default IP for the router while in the settings. be sure to remember the new IP or you will have to do a factory reset to get it back to default
Jul 03, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Computers & Internet Logo
155 people viewed this question
Alun Cox
k24674
