I have a dell inspiron 6400. However, I have a problem here. When I press the button on, the screen does not remove the picture. moreover, the hot wind does not come out directly from the laptop. However, I can hear the fan spinning ...
    Genius:
  • 1,325 Answers
It will require removing dust from the inside .. remove the back of the unit, plastic cover .. take a air can and clean off the dust from around the fan and inside where the peripherals are.
DO NOT UPDATE THE BIOS for this computer , it may not help you , but make it worse.. go to www.dell.com to confirm this information.
here are some links to help you
http://support.dell.com/support/edocs/SYSTEMS/ins6400/en/sm/index.htm
another fix could be boosting your registry and quicken your start up ...
i use a program that senses the temperature of cpu, gpu, hdd and chipset and controls the fans speed acordingly. it costs about $30, but its worth every penny !
http://www.liutilities.com/products/campaigns/affiliate/offer/gen/rb/
so:
1.install the program
2.set it up to take absolute control regarding the system fans(top right - 'automatic fan control' - 'enable temperature control')
3.click 'options' - right menu
4.click tab 'temperature control'
5.create a policy that suits you best, considering the sorounding temperature and the future load
6.return to main menu and select that policy
7.set the program as the single startup program and restart the windows
the program shoul dtake control as soon as it loads on startup and shut down the fans if the temperature is ok(which is, considering the cold boot)
and if this doesn't work, at least you can shut down the fans yourself from the program.
Posted on Nov 02, 2010
I have a dell inspiron 6400 was working but all it does now is when i press the power button, the leds comes on for about 5 seconds, no display, and cuts off no sound. can someone help me please?
turn off the system, remove memory and start the system and if you hear beep sounds , try using it on one memory and check if the memory is ok
Dont forget to say thanks
Aug 18, 2010 | Dell Inspiron 6400 Notebook
My inspirion 6400 does not start.
you just have to press power button once and then remove your hand , you should not wait for it to power on , just press once and remove your hand , it will automatically power on , if you keep on pressing power button and as soon you remove your hand it wil turn off the computer.
Jul 15, 2010 | Dell Inspiron 6400 Notebook
Power jack replacement Dell Inspiron 6400
When you press the power button, no lights, fans, beeps, anything?
Is the power jack moving around? If not, I would check the charger and cord to make sure power is getting through to the plug that goes into the jack.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 14, 2010 | Dell Inspiron 6400 Notebook
Inspiron 6400 is not getting started
Adapter should be faulty,kindly check with one another.
if again you are facing the problem might be short circuits in the motherboard
regards,
pp
Nov 26, 2009 | Dell INSPIRON 5000E (969PG) Motherboard
Dell Inspiron 6400 shuts off at randomly
STEP: Run the Preboot System Assessment (PSA)
Additional Information
  1. Ensure that the computer is powered off.
  2. Press and hold <Fn> and press the power button to power the computer on.
  3. Release both buttons. The PSA diagnostics sequence begins.
  4. Make note of any PSA beep codes or PSA error codes
Check for PSA Error codes on support.dell.com.
If all Test Passed. Then Perform Dell Factory restore or OSRI.
Nov 21, 2009 | Dell Inspiron 6400 Notebook
Got a new battery for Dell Inspiron 6400 but it won't charge
well if it's a new battery and you're having issues send it back, you may need to calibrate your new battery with the laptop
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Nov 06, 2009 | Dell Inspiron 6400 Notebook
Screen wont turn on , i have a inspiron 6400 .. I rang dell & my extra 3yr warranty ran out just 6 weeks ago & * They WONT HELP*
when you say screen will not turn on it means we do not have display right? now, try this. turn off laptop, press and hold D key then press power button, check if the LCD will display colors if yes then it might be your video card causes the problem which needs motherboard replacement. if no colors appear then LCD needs replacement.
Oct 15, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 problem in switching on
hi there so once you see the dell logo keep on tapping f8 and check if you can enter the safe mode, if not tell me the lights because that means thats its a no post issue and we might need to reseat your memory.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
Facing problem with battery of Dell Inspiron 6400
1. Shut down the system, remove the battery and the Ac adapter from the computer.
2. Press the power on button for 10 seconds
3. Reinsert the battery
4. Power on the computer and as soon as you see the dell logo press the f2 key a couple of time
5. Using the up down arrow keys , go to the option that says battery info. If there is an error message listed kindly post it back
6. Otherwise shut down the computer reconnect the ac.adapter and check if the problem is solved
Also the battery has a diagnostic lights on it , remove the battery from the computer and press the button on the battery a set of lights would glow. If they are steady and come in a series the battery is good , If some lights are missing the battery is bad and may need replacement
Thanks
Proton
May 15, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 screen problem
I had the same problem. You need a new graphics card.
Jan 08, 2009 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
