Question about Microsoft Windows XP Home Edition
A USB Device has exceeded the power limits of it's Hub port
This started popping up when I put the computer in Standby. So I clicked unplugged/replugged and reset. Now the keyboard, mouse and printer won't work? I just had the motherboard replaced so I downloaded new drives for all. The printer still does not print. I used the trouble shooting and followed all directions even checking the firewall. The printer still does not work. The new message I get is Printer designed to work with USB cables only. The current software and setting is not set to USB port. Does this mean I should go purchase a new cable?
  • 2 more comments
  • Anonymous Jan 01, 2009
    i have same problem its fresh xp installed
    all drivers updated even put driver genius driver scanner again nothing is it usb hub port defected i think not it sdriving me crazy help
  • Rachel Jean Feb 08, 2009
    Same message, and the screen just went blank. So I unplugged the computer from the wall, now I can see my desktop with everything on it, but nothing
    works : mouse, printer nor keyboard.
  • Anonymous Mar 31, 2009
    the power exceeded its limit and its no more working
  • Anonymous May 16, 2009
    thank you bill! it works my friend just got this problem, and i told her what you have posted it's working now thank you very much
I have desktop and its prompting me usb power limit exceed how to solve this problum
Posted on May 23, 2009
My dell D800 usb storage exceed power limit
plug memorex MRX-600 LE
Posted on Jan 05, 2010
  • 3 Answers
Make and model number would help me. The voltage output of USB ports is +5 VDC. "Standby" on a computer is a is a power saving feature that is really only needed for Laptops.
If this IS a laptop: try unplugging it, remove the battery and press the power button to drain residual voltage from the system. Do the same thing with your printer and any other USB peripheral devices.
If it is a Desktop, unplug the power cord that is plugged into the wall ie kill the power to everything and do as described above.
If this doesn't work, some damage may have occurred to one of the peripherals or the system itself due to the voltage drop.
A workaround after all the above fails to resolve the issue is to purchase an inexpensive USB pci card and install it into one of the open pci slots inside your computer. For a laptop, plug in cards are available but you need to check the specs before purchasing.
Hope this helps.
Bill
Posted on Jun 12, 2008
Thank you bill! it works my friend just got this problem, and i told her what you have posted it's working now thank you very much
Posted on May 16, 2009
  • 16 Answers
I have no usb plugged in still I get this error and plus my laptop freezes after a while. I assume this is the problem. If I fix this the laptop should work again fine.
Posted on Aug 06, 2012
2 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: a usb has exceeded the power limits of its hub port
Simply put its what it says.
you have too many devices drawing power from the USB ports of your laptop.
A fix for this is to use a USB hub but it MUST be one with its own power supply.
Posted on Sep 07, 2009
When we turn the printer on the menu window just flashes and we can't see the menu. can't do anything other than print.
Seems as though the menu needs to be reset. Unplug printer and then replug after 20+ seconds. If problem persists, reinstall the print driver from the Device Manager. In Windows 7 you would go to Start, Devices and Printers, right click mouse to reveal drop down menu, select remove device. Now, unplug your printer's USB cable and turn off your computer. Wait the 20+ seconds. Turn on computer. After fully loaded, turn on printer and plug in its USB cable. Computer should conduct "plug & play" search for printer driver and reinstall the printer. Hope this solves your problem.
Oct 09, 2014 | Office Equipment & Supplies
Windows XP Professional, can't log in, try to type
Which model of laptop ?
Nearly every device in your computer system can be turned off and on by accessing the Windows Device Manager with a few clicks of the mouse. It gives you plenty of flexibility and allows you to customize your computer on a whim. The Device Manager will allow you to enable your factory keyboard and mouse and disable your current ones, effectively resetting them to the default settings
Make sure that your default mouse and keyboard are plugged into your computer. Click on the Windows "Start" button in the lower right corner of your desktop. Type "Device Manager" in the "Start Search" box. Click "Device Manager" under "Programs." Click "Continue" if the Windows permission window pops up. Click the "+" next to "Mice and other pointing devices." Right-click the default mouse and click "Enable." Switch to your default mouse then right-click your other mouse and click "Disable." Click "Yes" in the warning popup window. Unplug the other mouse. Press the "+" next to "Keyboards." Right-click your default keyboard and click "Properties." Click the "Driver" tab then click "Enable." Click "OK." Right-click your other keyboard and select "Properties." Click the driver tab then click "Disable." Click "Yes" in the permission window then click "OK." Your computer is reset to the default keyboard and mouse.
Jan 30, 2013 | Computers & Internet
After the computer is left alone for awhile is will start flashing Acer on the screen and the power button will change colors from blue to an orange looking color. I have tried moving the mouse and...
The monitor is entering "standby" mode.
In Windows, click Start.
Click Control Panel.
Click Power Options.
Change the number of minutes before entering Standby Mode.
May 14, 2011 | Acer X193W LCD Monitor
I put in new batteries ! how do I reboot it
You can unplug the usb cable and replug it on the computer(the one for the keyboard and mouse) if that does not do the trick. On the wireless broadcaster there is a connect button to sync up the keyboard and mouse, press it (some models need it to be pressed for 3-5 secs) then press the same buttons under the keyboard and mouse. This should sync the mouse and keyboard and you are on your way!
Mar 07, 2011 | Micro Innovations Wireless...
The cursor on my pc freezes..
Temporary Solution
1) Click Start, then Click Control Panel
2) Double Click Mouse
3) Enable the cursor trail
You will be able to see your mouse, even after the original cursor freezes on screen.
Steps that can fix the problem.
This may also solve your problem. ONLY do if you are sure that you know how.
1) Right Click on MyComputer icon. Then Click Properties.
2) Click on Hardware Tab, then Click on Device Manager.
3) Uninstall your mouse AND keyboard. Connect your mouse directly to the USB.
Then reboot your computer (restart) and let the mouse reinstall automatically.
Keep your computer in shape and you will have less problem
May 31, 2010 | Computers & Internet
Wireless mouse stopped working.
Unplug the wireless receiver from the back of the computer. Wait 10 seconds and replug back in. Check connectivity. If nothing then check batteries in mouse, if still nothing try click the Connect button on the wireless receiever and then underneath the keyboard...repaet the process for the mouse. You should get something on the screen stating the channel 1 is for the keyboard and channel 2 is for the mouse. Hope this helps! - Erick :-)
Dec 19, 2009 | Microsoft Wireless Laser Desktop 4000...
Scorpius K3NT USB Keyboard prevents resume after standby in Win2K
When entering standby, the usb ports go to sleep. Most motherboards allow you to tell the bios that you are using a usb keyboard. That should solve the problem. I keep an old ps2 keyboard plugged in and on the floor as a 'just in case'.
Jul 24, 2009 | Mini iOne / Qtronix Scorpius K3NT PS/2...
Mx 3200 keyboard runs but won't type
windows xp info.
go to start,
control panel,
systems,
hardware,
device manger,
click on x at keyboard see your keyboard there right click delete keyboard shut down and reboot leave keyboard plugged in...and it should find and reload the keyboard.
if this does not fix the problem..shutdown the computer unplug the keyboard and mouse...reboot the computer and let load all the way...I know you can't do nothing about signing in or working on it
but let load all the way after finished loading push button to power it off are unplug it...then replug the keyboard and mouse and boot it back up should fix it...
Apr 05, 2009 | Logitech Cordless Desktop MX3200 Laser...
Media keys working but not letters, numbers
Right click My comp- Properties- Hardware Tab- Devicee manager- Look for Logitech Keyboard- Rght click and uninstall it- unplug and replug the USB dongle that communicates with ur keyboard.
It should start working.
Feb 04, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
New HP keyboard & Mouse not working
I solved this problem by
1taking off the tower cover
Jan 22, 2009 | HP P2360AA Keyboard/Mouse
Microsoft Windows XP Home Edition Logo
6,889 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
