Question about Compsee Apex II
Error 20 When I try to retrieved information through Apex Appliation Manager the progress bar gets to 34 percent and then freezes. The scanner displays * Error 20 *
Sometimes i can get it to retrieve on another station. Maybe its a communication issue and taking too long to retrieve so it timed out.
also you can change the program to wait longer before timing out.
Posted on Jul 14, 2008
Cant download games from play store
please describe the issue. Is it not downloading the apps like the download bar is getting stuck or do you get an error message. Please be as descriptive as possible.
Mar 25, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
Error message apex ii
retry and reset it and retry
Dec 10, 2007 | Compsee Apex II
Scanning- error: address data book error
uninstall and then re install the software, reboot before re installing.
vote for me inform me of your progress.
This is usually a computer scanner problem.
You didn't say what scanner you have or model number.
Sep 17, 2012 | Office Equipment & Supplies
P0068 map/maf throttle position correlation
Hi there:Here's the printout from the diagnostic tool. Year: 2006Manufacturer: ChryslerMake: DodgeModel: DurangoEngine Type: V8, 4.7LTransmission: AutomaticTrim Level: SLTMileage: 127555 KMs
=== Stored Error Code(s) ===Error Code: P2074Possible Causes: Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Higher LoadError Code: P0068Possible Causes: MAP / MAF - Throttle Position Correlation
Freeze Frame Information:1. DTC for which Freeze Frame was Stored - P2074.2. Fuel System 1 Status - Closed Loop.3. Fuel System 2 Status - Closed Loop.4. Calculated LOAD Value - 74.51 percent.5. Engine Coolant Temp - 199.40 degrees F.6. Short Term Fuel Trim - Bank 1 - -3.91 percent.7. Long Term Fuel Trim - Bank 1 - -3.13 percent.8. Short Term Fuel Trim - Bank 2 - 0.78 percent.9. Long Term Fuel Trim - Bank 2 - -4.69 percent.10. Intake Manifold Absolute Pressure - 22.21 Inhg.11. Engine RPM - 2,404.00 Rpm.12. Vehicle Speed Sensor - 73.94 Mph.13. Ignition Timing Advance #1 Cylinder - 25.50 degrees.14. Intake Air Temperature - 64.40 defrees F.15. Absolute Throttle Position - 31.37 percent.16. Time Since Engine Start - 1212 Sec.17. Commanded EGR - 7.06 percent.18. EGR Error - 0.00 percent.19. Commanded Evaporative Purge - 62.35 percent.20. Fuel Level Input - 93.73 percent.21. Barometric Pressure - 26.35 Inhg.22. Control Module Voltage - 14.35 V.23. Absolute Load Value - 0.00 percent.24. Commanded Equivalence Ratio - 0.00.25. Relative Throttle Position - 0.00 percent.26. Ambient Air Temperature - -40.00 degrees F.
Monitor Information:1. MIL - OFF.2. Misfire Monitor - Complete.3. Fuel System Monitor - Complete.4. CCM Monitor - Complete.5. Catalyst Monitor - Complete.6. Heated Catalyst Monitor - Not Supported.7. EVAP Monitor - Complete.8. Secondary Air System Monitor - Not Supported.9. O2 Sensor Monitor - Complete.10. O2 Sensor Heater Monitor - Complete.11. EGR Monitor - Complete.12. NMHC Monitor - Not Supported.13. Nox Adsorber Monitor - Not Supported.14. Boost Pressure System Monitor - Not Supported.15. Exhaust Gas Sensor Monitor - Not Supported.16. PM Filter Monitor - Not Supported.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Mar 04, 2012 | 2005 Dodge Durango SLT
My scanner/faxer won't scan for my mfc-490cw brother product. I always have to reset it and push 20 buttons so I don't remember how to do it. Can you help?
I have the same problem. It was working fine, then after not using it for a few weeks, all the sudden I couldn't scan. I'm hooked up wirelessly through my router. I can initiate a scan both from my PC and from the scanner itself, when initated from the scanner my PC responds and shows the progress bar, and the scanner actually scans. However for some reason no data is being sent back to the PC. And after a few minutes I get an error message saying that communication was lost (or something like that) error TW007. Yesterday I called into brother support and was on the phone for an hour and a half. they walked me through verifying connectivity, uninstalling and reinstalling the software and drivers, but to no avail. In the end we made no progress. I can print without a problem, and fax and photocopy. But for some reason it seems that the scanner is not transmitting the information back to the computer, even through the connection was established and the computer is waiting for the data.
Nov 29, 2009 | Brother MFC 490cw Color Inkjet...
Screen blinks
Check for the running processes in the task manager . See if is the same runs in the safe mode. See the processes and make sure unnecessary processes . And also try a diagnostic startup . Lookup the way to do that on the support.microsoft.com.
Oct 13, 2009 | Computers & Internet
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
Compsee Apex II Logo
327 people viewed this question
Top Compsee Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Compsee Computer and Internet Expert? Answer questions, earn points and help others
