Question about Williams 3003622 Ceramic Wall Mounted Panel Heater
Williams 3003622 Wall Mounted 30,000 BTU The pilot light goes out when the main flame shuts down. The pilot light will stay lit for days when heat is not called for but when heat is called for the furnace lights and the pilot stays lit but they both go out together. The burner control is 6A235. Garry
I'm having the same exact problem... At first we thought was the vent... but the way the flames goes out... it seems that there is "not enough oxygen" more than "blown out by the wind"... right after both main & pilot goes out, I can't even light any external flame inside the chamber... and it doesn't feel like the outside cold air coming in... it just feel like there is some sort of gas in the chamber that's so strong, it prevents flame... and the only thing I can think of is that it doesn't have enough oxygen, but too much natural gas, and flame can't sustain.
Posted on Dec 16, 2010
  • JerryCraker Dec 16, 2010
    Here is what I found so far... In the manual troubleshooting section says:
    Problem: Burner comes "on" but goes "off" after operating for no apparent reason.
    Cause:
    A. Tubes not properly installed
    Fix: Check vent tube and air inlet tube. Follow installation instructiojns. Be sure joints are tight and both tubes are in place. Use only tubes furnished. Do not extend tubes beyond original length.
    B. Furnace maybe overrated
    Fix: Check for high pressure at the valve. See rating plate for specified min. / max supply pressure. Check burner orifice.
    Here is the manual for the heater: http://www.alpinehomeair.com/related/Dir... vent wall furnace installation.pdf
  • JerryCraker Jan 06, 2011
    **FIXED** So it turns out that the back of the unit, the exhaust has 2 rings, the outter ring is around 7" round, the inner is around 4" round. In order for the unit to operate properly, the 4" inner pipe needs to be attach to the wall cap with a 4" piping while the outter ring of 7" pipe needs to be connected to the wall cap with a 7" pipe too...
    So, basically, between the unit and the wall cover outside, you need to have a 4" inner pipe in the middle of the 7" outter pipe.
Gas conversion lp kit 8927 has 2 pilot orifices...I only need 1, correct?
The smallest pilot orifice is used for LP. Make sure you read the instructions thoroughly. Usually the gas valve pressure regulator is disabled and the burner orifices are also changed. Good luck and hope this helps.
Aug 11, 2014 | Williams Wall Heaters: 30,000 Btu/hr...
Burnham boiler pilot light goes out when thermostat shuts it down
That unit uses a thermocouple 30mv or a pilot generator of 750 mv if the thermostat is a remote type and not integral to the gas valve.
A thermocouple or pilot generator makes power due to a temperature differential across the tip of the generator, if too much is impinged by the flame the generator gets hot across the entire tip, dropping power output.
You likely need a new thermocouple they are about $15 and easily replaced.
Nov 01, 2013 | Williams 3003622 Ceramic Wall Mounted...
It is a Williams circa 1985 gravity direct vent wall furnace mdel 30DV 5, 30,000 btu. Light pilot OK. Heat on OK. But when heat not called for (several hours) pilot must go out. There is a small penny...
That hole should only be a problem, if a strong draft comes thru and blows the pilot out. But that hole may also be for match lighting the pilot in an emergency. The older models like yours, had that feature. Check it closely, before you decide to block off the hole.
Hope this helped you.
Jun 19, 2011 | Williams 3003622 Ceramic Wall Mounted...
Williams 3003622 pilot light is on but heat doesn't turn on- there is a "Do It" thermostat connected. Is it a problem with the thermostat or furnace?
Try jumping out the thermostat (red and white wires) that run to the thermostat these tell the heater to come on. Jump them together if you have heat it is the thermostat, if no heat it is the furnace. Should it be the furnace I would first check the thermocouple or some manufacturers call it a flame generator. Clean this with steel wool and position it in the top center area of the flame as this is the hottest part of the flame. Good luck
Dec 26, 2010 | Williams 3003622 Ceramic Wall Mounted...
Williams debonair wall heater + pilot light problems
THE flame from the pilot should shoot past the thermo-couple and heat this up and make a small amount of mili- amps to prove the pilot light is lit. ..So if the flame doesn,t go past the thermo-couple it won, make mili-amps or its tme to change out the thermo-couple, They only cost lest than $8:00 and you can change it!
Dec 22, 2009 | Williams 3003622 Ceramic Wall Mounted...
Re Williams 3003622 Heater Please advise how to ignite pilot light.
You will first need to turn the control knob to pilot. Then depress the control knob button and hold it. Then press the push button piezo igniter several times until pilot lights or open pilot inspection cover and manually light pilot with match/lighter. You may need to hold the control knob for at least a minute. Then release the control knob and if the pilot stays lit then turn the control knob to on. If it does not light then repeat the process again.
Oct 27, 2009 | Williams 3003622 Ceramic Wall Mounted...
Need to turn on pilot light of Williams 3003622 serial # 400518D
Find the gas valve and turn it to pilot. (Or light) Use a long reach lighter. Light the lighter and press the knob in. Light the pilot and continue to hold the knob in for about 15 seconds. When you release it, the pilot should stay lit. If it doesn't, you need a new thermocouple. That's the small tube that the flame touches when the pilot's lit. They're inexpensive and usually not too hard to replace.
Jan 30, 2009 | Williams 3003622 Ceramic Wall Mounted...
Natural Gas wall heater
It sounds like the thermocoupler is either not adjusted into the flame properly, or you may have gotten a bad one. The thermocouple is the main thing that makes the pilot work.
Dec 22, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Williams 3003622 Ceramic Wall Mounted Panel Heater Logo
1,201 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Superior Maintenance
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
