Question about Kenmore 4292x Front Load Washer
Blinking red lights and no washer operation
I cannot get my washer restarted after interupting its early normal operation to add an item. I hit the cancel/puase button and when I heard the lock release, I opened the door and added the item. I didn't realize there was a bit too much soap in the washer, so when I opened the door, some suds rolled out, but no big deal.
Anyway, now a I get a blinking red light on any choice, and when I push the start button, nothing happens.
I removed the clothes, some water remains in the washer, and tried the manual drain function, but it too blinks and refuses to respond to the start button.
Any suggestions?
  • niacc Jun 16, 2008
    Thanks, Lumpy816. The pin is indeed gone and that is the problem. I cut a little off a genuine BMW plastic pin like thing and it fit the hole just right, with the door pushing it fully in, all works as it should.
    I'll check out the proper replacement part price and take care of it.
    Great help. Much appreciated.
    Dave
  • Toby Norton
    Toby Norton May 11, 2010
    Have you checked your door latch? When you opened and re-closed the door you may have broken your latch assembly. Open the door. There should be 2 holes on the door frame. A suare one where the latch goes and a black round one that has a pin sticking out of it. If that pin is missing/ broken, the machine won't run.
  • 246 Answers
Dave, glad I could help, I'll mark this one as solved.
Posted on Jun 17, 2008
Blinking cancel light, that won't cancel out, and won't allow other functions to be started.
While the door is closed, try pressing and holding the cancel button for about 10 seconds to see if it will clear.
Mar 31, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
I stopped washer while soap washing to add another item. Now it is stuck and the time is still blinking and nothing will reset it including the reset and start button. Help.
I would unplug the unit. Then plug it back in, let it spin the water out and restart the machine, do not add more soap and see it that fixes the problem.
Jan 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When I take the computer out of the standby mode
Try this:
  1. Update the BIOS and Video driver to the most current on http://support.dell.com
  2. Disable the screen saver
  3. Enable HIBERNATE instead of standby in Power settings, set the LCD to go off in 10 minutes, HDD to 15 and Hibernate in 20.
Select Shutdown, Hibernate
then try and restart
If no GO, disconnect all peripheral items except KB
Try hibernate again and restart.
If all works OK, add items back one at a time till you find item causing issue. If no go, replace power supply if issue still occurs, replace MB
Oct 13, 2009 | Dell Inspiron 530 Desktop Computer
Normal cycle started normally, paused to add item
Unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the problem reoccurs, or if an error code is displayed, please let me know so I can assist you further. I hope this helps you.
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stuck in cycle
unplug the unit. wait 30 secs. and repluge, youll have to restart cycle. but should work DO NOT add more soap
Mar 18, 2008 | Kenmore Elite 45986 Front Load Washer
Washer interupted while running
Try pressing "end of cycle". Then restart your normal wash.
If helped pl rate me................................
Jan 23, 2008 | Whirlpool GHW9100L Front Load Washer
Kenmore dishwasher wont start blinking clean light
today January 9, 2009...blinking clean light, kenmore dishwasher would not run,,,the solution on Fixya ..."keep hitting normal -heated wash-normal -heated wash buttons over and over...unlocked the blinking green light problem. Dishwasher is running as I type this....will post again when I see the results of another washing tomorrow. H.T. Las Vegas Nv
Jan 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Blinking lights
Press "end of cycle" to get machine to normal. Then plug off the wall. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 04, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 4292x Front Load Washer Logo
171 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
