Sony SLV-679HF VHS VCR Logo
Posted on Nov 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i buy new belts for this model SLV679HV
Anonymous
Level 2:
  • Expert 132 Answers
  • Posted on Nov 02, 2010
Anonymous
Expert
Level 2:
Answers
132
Questions
Helped
40672
Points
463
Now days it's all about trial and error w/ vcr belts. Your best bet is to find a tech that has several of the old belts in stock. It doesn't have to be exact, but needs to be very close in size to the original.
2helpful
2answers
My whirlpool large wasjer seemed the belt was squeeking .... then it stopped spinning.. Is it worth is to get a new belt repaired or buy a newer one.
Of course it worth to change the belt, is more cheap then a new washing maschine.
After 7 years of usage my Samsung washing machine was doing same problem. I change the belt with a new one about 3 years ago, and it's working fine.
All the best !
What's the number of teeth on the timing belt for 3s-fse engine
I know, , experience talks.
we buy new belt and the clerk gabs abox
1: wrong belt in box, last customer returned it like that.
2: clerk gave you wrong box used wrong engine table(GATES)
3: you told clear wrong and he did it wrong.
4: learn that some engines even same 1.6L displacement had 2 head types that year. or series of years.
my car here, has 3 belts sold for it, 2 are wrong, per above.
no belt brand told just 164 code (gates?)
OP never told it is a toyota , nor the year, wow no year.
3s-fse =1987 to 2000 year made. no car model told what can go wrong, answer ALL. that.
DOHC engine 2 cams. CR = 9.8 (3S-FC, 3S-FE, 3S-FSE)
2.0L engine 1,998 cc, 121.93 cu-in
step one make sure both belts new and used, laid top of each other have same number of teeth and pitch. (viewed) if not WRONG belt.
OOPS? (the new belt can be touch tighter.,old belt stretched be longer or even a wreck)
some models have VVT, in the head and may change the T belt USED, no car told no year, no VVT told.
1990 turbo?
1990 camry is gates T138
1990 turbo T125
if you buy a belt for the wrong 3s-HE engine you fail
learn what is there, first, under hood. exact engine
turbo or VVT or what, make and model and year not old.
we can only beg cars model.
Toyota Avensis (T220) Toyota Celica (T160) Toyota Celica (T180) Toyota Celica (T200) Toyota Camry (V20) Toyota Camry (V30) Toyota Camry (V40) Toyota Vista (V50) Toyota Caldina (T190) Toyota Caldina (T210) Toyota Carina (T170) Toyota Carina (T190) Toyota Corona (T170) Toyota Corona (T190) Toyota Picnic (XM10) Toyota RAV4 (XA10)
Where to buy 55-3554-4 drive belt
Applied Industrial Technologies Brampton they also have several other location just google the name
Hi I need a new serpentine belt put on my 1999 alero however I do not know how many grids the belt is supposed to have can you help me please
drive belt has 6 ribs.to buy a new belt take old drive belt with you you so you will get the right size belt.tell the auto parts store the year and model type car.tell them your engine size.and they will find the belt size you need.
My deck belt broke and I am unable to measure it to buy a new one. How many inches is the deck belt for a craftsman 1000?
If you don't have the broken belt, and you don't want to buy 2 or 3 wrong belts. Go to a lawn and garden supply company or sears and buy it by model number of the mower. Then when you have the new one, find the numbers on the belt, and write them down. http://www.searspartsdirect.com or
5answers
THE BELT ON OUR MACHINE IS BROKEN CAN I BUY A REPLACEMENT AND HOW DO WE FIT THE NEW ONE ON ?
The treadbelt can be installed by removing the front roller, the drive belt, rear roller and screws in the siderail. You do not have to remove both sides, just lift the deck and slide new belt on. To save yourself some agravation, you may cut the old belt off.
Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly... 877-805-1030
1helpful
Drum does not turn. Cannot see belt (if this model uses one) anywhere upon opening top. Have not opened up further. This item is about ten years old. Weighing options of fixing or buying new machine.
the belt is borken and laying in bottom of dryer . they all use one . buy the belt and replace it its easy job and belt is only 15 to $20.00 .. clean out lint exc and lube things up /. probably get another 50,000 miles out of it . mm feed back pls .
Dec 22, 2009 • Dryers
Small belt driving the brush...stretched out with hair accumulated in groove beneath belt. Is there a clutch or other means of tightening the belt. Went to store found belt...same size, therefore...
You do not by a belt by size, buy it by model only. A new Hoover belt will generally be very snug when installed. As heat builds from use it stretches and becomes worn sometimes as much as 30% oversize. Good that you have cleaned out the hair. Check the end caps of the brush as well. Go to a Hoover service center or retailer and buy the matching belt by model # on the package and you will be set.
Needs new belt
you should be able to buy it at any walmart store. they sell the belts separately by two's. they usually range about three dollars for two. Pay special attention to the make and model and the belt type that is required. Thank You .
Please indicate if this helped at all..much appreciated
26helpful
3answers
Need belt for Everstar 5990 vacuum cleaner
I just replaced the belt on my Everstar VC-9550 and it works fine. I found it at Home Depot for $3.99. The belt is sold under Vac Belts item No. 51007 (Designed to fit Bissell Uprights, Style 7,9,10).
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
